285/75/17
Discussion in 'Wheels & Tires' started by Jason808, Aug 20, 2018.
  1. Aug 20, 2018 at 4:06 PM
    Jason808
    Jason808 [OP] "Thrust you can Trust"
    2012 Platinum crewmax
    What's up guys. Has anyone run this size tire with a 2 inch lift up front without chopping anything? Im running 275 60 20 now with no issues(stock rims). But, I just picked up some 17 inch Rock warrior rims and want to go up in diameter. I've search and couldn't find a answer.
    equin likes this.
  2. Aug 20, 2018 at 4:51 PM
    PermaFrostTRD
    Northern NY
  3. Aug 20, 2018 at 8:09 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    Jason808[OP] likes this.
  4. Aug 20, 2018 at 8:15 PM
    equin
    Ed
    DFW, TX
    I'm thinking of running the same size but with Icon Rebounds (+25 offset). My guess is that you'll be fine with the Rock Warriors with 2" lift. They might rub the skid plate with the stock wheel offset, though. Might also have to remove front forward flap and push in the front plastic lining, but that seems to be more of a concern when running aftermarket wheels with less offset than stock.
    Jason808[QUOTED][OP] likes this.
  5. Aug 20, 2018 at 8:35 PM
    Jason808
    Thanks, that is the kind of answers I was looking for. How big of a lift do you have? I wish they made a 275/75/17 though.
  6. Aug 20, 2018 at 8:47 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    My LT285/70R18 tires are the same size and fit just fine under articulation without any cutting. I have the TRD Off-Road package wheels (+60mm offset) and I believe that the Rock Warrior wheels have a +50mm offset. I have a 2" lift up front and stock springs in the rear.
    Jason808[OP], 14burrito and equin like this.
  7. Aug 20, 2018 at 8:53 PM
    Jason808
    That's awesome news!!!! Thanks man. What tires did you go with?
  8. Aug 20, 2018 at 9:46 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    Pretty sure @Bailey is running that size. On RW wheels, no less.
  9. Aug 20, 2018 at 11:33 PM
    computeruser6
    Dirk
    Escondido
    Nitto Exo Grapplers:
  10. Aug 21, 2018 at 3:11 AM
    PermaFrostTRD
    Northern NY
    Yup. Thanks for the catch.
  11. Aug 21, 2018 at 5:58 AM
    equin
    Ed
    DFW, TX
    I set my 6112s at the 1.9” mark. Since the offset in my rims is less than stock, I may have to do some minor cutting or pushing of the plastic liner up front. The RW offset is much more, so you’ll likely have to do less or none at all.
    If you get those tires, don’t forget to post pics and results.
  12. Aug 21, 2018 at 9:49 AM
    Bailey
    Bailey Enjoy Every Sandwich
    CO
    2011 DCSB Limited 4x4 “Clifford”
    :muscleflexing:
    285/75/17 Toyo ATII
  13. Aug 21, 2018 at 12:52 PM
    equin
    Ed
    DFW, TX
    I made the same mistake confusing that size with an 18” wheel. If I remember correctly, that size on 18s is around 34” and almost 35”.
  14. Aug 21, 2018 at 12:53 PM
    equin
    Ed
    DFW, TX
    Great photos. What suspension setup are you running?
  15. Aug 21, 2018 at 1:49 PM
    Bailey
    CO
    Thank You :)
    It's a spacer lift - somewhere around 2" in the front and a 3/4" block in the rear.
    Eventually I'll upgrade
    equin[QUOTED] likes this.
  16. Mar 11, 2019 at 9:56 PM
    03socaltundra
    03socaltundra New Member
    Anaheim
    2013 Rock Warrior
    Do you notice any difference in acceleration with this setup?
  17. Mar 12, 2019 at 12:01 PM
    Bailey
    CO
    I did notice a difference but mostly because this setup was lighter than the previous. The truck did feel a bit quicker. I can't compare it to stock though
