285/70r18 Ridge Grappler on 2019 Pro
Discussion in 'Wheels & Tires' started by ctraut5, Oct 25, 2018.
  1. Aug 5, 2019 at 5:42 PM
    #61
    ctraut5
    ctraut5 [OP] New Member
    Germantown,TN
    2019 Black TRD Pro
    I'm running at 38psi right now, and have no issues at all with the TPMS. The tires are a touch louder than stock, but not bad at all. The ride is a bit rougher due to the E load rating and the addition of more unsprung weight, but it's also not that noticeable.
    2020SR5tundra likes this.
  2. Aug 5, 2019 at 7:07 PM
    #62
    Hammy68
    Hammy68 Peak Bagger
    New Hampshire
    2018 Silver Tundra TRD Off Road Crewmax
    RC 1.75” Front, 1” Rear, TRD Dual Exhaust, Nitto RGs 275/70/18, TRD Center Caps, Rugged Cover Hard Tonneau, Rhino Liner, LED interior/exterior upgrade
    Those look good- gotta get me some 1” spacers next!
    ctraut5[OP] likes this.
  3. Nov 1, 2019 at 3:47 PM
    #63
    GREENwithENVY
    GREENwithENVY New Member
    Knoxville, TN
    2020 Tundra TRD Pro
    Working on it!
    Tires look great! So, this size doesn't rub in reverse (as some others indicate)? I'm trying to decide whether I want to go with these but do not want to trim or install spacers.
  4. Nov 1, 2019 at 5:24 PM
    #64
    ctraut5
    Germantown,TN
    2019 Black TRD Pro
    I have had zero rubbing with this setup before or after the 1" spacers. This is with the pro suspension, and I'm not sure if it would rub or not otherwise.
  5. Nov 24, 2019 at 7:05 PM
    #65
    Pacer164
    Pacer164 New Member
    Southern Indiana
    2022 Toyota Tundra Crewmax 4WD 1794 TRD OFF-ROAD Long Bed
    How is the speedometer reading? Any major decrease in fuel mileage with the LT285/70R18 tires?
  6. Nov 25, 2019 at 6:39 AM
    #66
    ctraut5
    Germantown,TN
    2019 Black TRD Pro
    I’ve found that the speedometer on both of my Tundras read about 1-2mph fast on stock tires. Going to the 285/70r17s actually made it almost right on when compared to GPS. Maybe 1mph slow, but it’s really close to being right on. My mileage dropped about 1-1.5 mpgs after the tires.
    Pacer164[QUOTED] likes this.
  7. Nov 25, 2019 at 5:14 PM
    #67
    Pacer164
    Pacer164 New Member
    Southern Indiana
    Thanks for responding. This definitely helps me with my decision.
    Rica25 and ctraut5[QUOTED][OP] like this.
  8. Nov 30, 2019 at 5:28 AM
    #68
    Lablover71
    Lablover71 New Member
    Chester, VA
    2017 Gray Tundra TRD
    Looks Great! I too am running the Nitto RGs. Super aggressive look with a smooth ride and little to no extra road noise.
    Rica25 and ctraut5[OP] like this.
  9. Feb 8, 2020 at 9:00 AM
    #69
    CCLJ03
    CCLJ03 Tundra forever
    Craig
    2018 TRD Off-Road - Cement
    Rica25 likes this.
  10. Feb 8, 2020 at 9:10 AM
    #70
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    I called Nitto for this info since I run this tire. They call for 34 psi front and 32 psi rear.
    2020SR5tundra and Rica25 like this.
  11. Feb 12, 2020 at 7:30 AM
    #71
    Cake's Pro
    Cake's Pro New Member
    Ethan
    CA
    2019 Tundra Pro
    Tinted windows/tails
    This is all I have right now.
  12. Feb 12, 2020 at 3:28 PM
    #72
    I run 44 psi in mine.
    Rica25 likes this.
  13. Mar 16, 2020 at 12:58 PM
    #73
    jetsweeps
    jetsweeps New Member
    Are you running any spacers? What lift or level are you using and what offset are those wheels? did you have to do any modifications?
    I just bought a 14 CM and was thinking about running this setup with my stock trd wheels that are 60mm offset. I'm installing bilstein 5100 on all 4 with the front at the top setting.
    Rica25 likes this.
  14. Mar 20, 2020 at 10:44 AM
    #74
    RVR UBER
    RVR UBER New Member
    So Cal
    2018 TRD Sport
    Running 5100's on top setting with CoachBuilder rear shackles and went 295/70/18 RG's on BBS Forged Pro's, no cutting or modifying of liner or body chop mount needed. Had removed mud flaps with prior 22" set up, but might put them back on.
  15. Mar 21, 2020 at 1:43 PM
    #75
    Crews44
    Crews44 New Member
    Southern NJ
    2025 Platinum TRD MGM CM 3” TRD lift
    Looks nice.
    Rica25 likes this.
  16. Mar 21, 2020 at 2:39 PM
    #76
    buckeyeinlv
    buckeyeinlv International Man of Mystery
    Brandon
    Henderson, NV
    2020 Army Green TRD Pro CrewMax
    OEM Power Tailgate Lock, Peragon Tonneau Cover, S&B Intake, Bora 1” Spacers, ceramic window tint. Interior: OCD Organizer, AJT Designs Cup Tray and Shift Trim, JDMCar Rubber inserts. Tires: 285/70R18 Old Truck: Base:2017 Inferno SR5 CM 4x4 Mods: Interior- OCD organizer, Proclip USA iPhone X Mount, Wireless center console charger, TRD shift knob. Exterior- Backflip G2 Tonneau Cover, Amp Research Powersteps and Bed Step, Pop and Lock tailgate lock, Ceramic window tint, Blackout emblems, TRD Pro Grille, Stubby antenna, Vinyl American flag TRD graphics, Color matched and bullet lined bumper ends, 18x9/+25 Method NV305 Bronze wheels Engine- Stock
    I have the same tire and size on my pro. Considering adding the 1” spacers to widen the stance. Right now it’s just about flush with the body.
  17. Mar 21, 2020 at 11:02 PM
    #77
    buckeyeinlv
    Brandon
    Henderson, NV
    For you guys that run spacers, did you do an alignment after?
  18. Mar 24, 2020 at 4:41 PM
    #78
    jetsweeps
    I ended up going on middle setting. I bought 20 inch oem limited wheels and put 285/60r20 toyo at2 on. Had to trim skid plate that's it.
  19. Mar 27, 2020 at 8:33 AM
    #79
    GCWTRDPRO
    GCWTRDPRO Death TRD PRO
    Austin, Tx
    TRD PRO Tundra
    None yet in search
    May I ask how do they look straight on front and back?
    Are they much wider?
    And did you lose any turn radius?
  20. Mar 29, 2020 at 12:29 PM
    #80
    jetsweeps
    They are 11.5 inches wide and personally I like the look of the tire. Straight on they are just inside of the well but can see tread in the mirrors. I haven't noticed any difference in turn radius. I might get some cb shims to raise the front up a little more. After it has settled I'm about an inch higher in the back. Or take apart and move to high setting. I'm not sure which way to go yet.
  21. Mar 30, 2020 at 11:00 AM
    #81
    lonelydriver
    lonelydriver New Member
    have em on my pro with the spidertrax 1.25 and they have the perfect amount of poke. no alignment needed
    KERNEL_DALE likes this.
  22. Mar 31, 2020 at 1:31 PM
    #82
    Cake's Pro
    Ethan
    CA
    2019 Tundra Pro
    No spacers, stock 19 PRO suspension. Everything stock besides the tires.
  23. Apr 1, 2020 at 3:56 AM
    #83
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    Same. Running 1.25” boras with 295/70/18’s on my stock pro wheels. Stick out just enough with the rokblokz flaps. I did add a 1” coachbuilder shim with #3 shackles and the bumper shim.
  24. Apr 11, 2020 at 2:56 PM
    #84
    SR5beatsF150
    SR5beatsF150 New Member
    2016 toyota tundra sr5 4x4
    Hey guys, question
    I have a 2016 SR5 with stock suspension,
    If I buy 285/75/18 falken wildpeaks, will they fit without rubbing?
    Anyone running that type of combo on that model or had any prior expieriece with it?
  25. Apr 21, 2020 at 8:33 PM
    #85
    redhat
    redhat Leadfarmer
    Jacob
    Sacramento
    2019 TRD PRO
    Nothing but good stuff.
    Anybody running these with aftermarket wheels?
  26. May 10, 2020 at 7:36 PM
    #86
    Sancho1
    Sancho1 New Member
    Army Green 2020 Tundra Pro
    Sir are these 285/70/18's?
  27. May 11, 2020 at 10:32 AM
    #87
    Greenmacheen
    Greenmacheen New Member
    Is this stock otherwise ? No other modifications just the tires ? Looks awesome.
  28. May 11, 2020 at 11:23 AM
    #88
    buckeyeinlv
    Brandon
    Henderson, NV
    They are
  29. May 11, 2020 at 11:25 AM
    #89
    buckeyeinlv
    Brandon
    Henderson, NV
    Based on when I posted this picture, yes, just the stock TRD PRO Fox suspension and Nitto Ridge Grappler 285 70R18 Tires. Since then I have added 1" Bora spacers.
  30. May 11, 2020 at 11:45 AM
    #90
    KeetAz
    KeetAz New Member
    Gilbert AZ
    2020 SuperWhite PRO
    Finally pulling the trigger on 285s. Are backordered from Nitto, but my discount tire guy found some in Oregon. Shipping and should be here by the end of the week! Toyota should be ashamed of putting these street tires on! Can’t wait!
    Ely010606 and buckeyeinlv like this.
