285/70 r17 or 305/65 r17
Discussion in 'Wheels & Tires' started by UTAHRTK, Feb 8, 2020.
  1. Feb 8, 2020 at 9:22 AM
    UTAHRTK
    UTAHRTK [OP] New Member
    SOCAL
    2017 MGM Tundra TRD CM
    Dirty Deeds 8" standard exhaust, King 2.5's/Bilstein 5160's, Built Right UCA,s, Method 701's, TOYO ATIII 35x12.5x17, TRD LED headlights, Pro Grill
    Just installed new shocks (6112 @ 1.3/ 5160) and preparing to buy tires during Presidents Day sales.
    Would love input on whether to go 285/70 r17 or 305/65 r17. BFGs...
    Wheels will be method 701 or 702 at o offset.
    Much appreciated.
  2. Feb 10, 2020 at 8:48 PM
    UTAHRTK
    SOCAL
    Hmmm?
  3. Feb 10, 2020 at 8:53 PM
    computeruser6
    computeruser6 Gott Mit Uns
    Dirk
    Escondido
    2008 Regular Cab Tundra
    I'm a fan of narrow tires, so I would go with the 285 set. They will weigh less, have less rolling resistance, probably be cheaper, and less cutting will be required.
  4. Feb 11, 2020 at 8:57 PM
    UTAHRTK
    SOCAL
    Appreciate it; I believe 285s it is.
  5. Feb 11, 2020 at 9:36 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    285/70/17 was the oe tire size for the rock warrior model trucks. Might look small if you lift the front
    14burrito and usaf.2012 like this.
  6. Feb 11, 2020 at 10:46 PM
    usaf.2012
    usaf.2012 New Member
    AK
    2010 Black CM Tundra RW
    10" BAMuffler // Bilstein 5100s all around & front on Mid setting // Toytec shackles // BHLM
    Agree with Hbjeff. I have 5100s on middle setting w/ the stock 285/70R17 on RW wheels, 32.7"x11.2". My next set will be 285/75R17, 33.8"x11.2". No difference in width but will gain about an inch in height.
  7. Feb 12, 2020 at 8:21 PM
    UTAHRTK
    SOCAL
    Thanks. So I measured again today- I have about 1" lean(driver); so I am at the crossroads- do I counter the lean by adjusting preload -drop passenger side down to lowest setting on 6112s or do I bump driver side up to 1.9. Other option is driver 2.6/ passenger 1.9. I really don't want to shim but now the lean is bothering me... This is turning into a learning experience. As far as tires- back at square one.
  8. Feb 12, 2020 at 8:51 PM
    usaf.2012
    AK
    From ground to fender well at the center of each tire what are your measurements on all four fenders? Standing behind my truck the drivers side definitely sits lower than the passenger but NMT than 1/4-1/2"...pretty much standard on these trucks. If it bothered me too much I would look at coach builder shims. I think changing the setting on your front shocks to be different on each side will throw everything out of whack. Also if you are not on a perfectly level surface I found those measurements will be exaggerated.
  9. Feb 12, 2020 at 9:17 PM
    UTAHRTK
    SOCAL
    Not sure what to do. I really want to get front dialed in before getting new tires. I will keep you posted. Thanks.
