285/60/20
Discussion in '2.5 Gen Tundras (2014-2021)' started by Migue02, Jan 16, 2023.
  1. Jan 16, 2023 at 9:37 AM
    Migue02
    Migue02 [OP] New Member
    Miguel
    2017 silver tundra limited
    None-for now
    I was at discount tire and the salesperson said I could fit 285/60/20 fully stock. I tried to do some research and see that people are running that set up on the tss rim. I don’t have the tss rim I have the 20” limited rim. Will that be a issue or should I should just stick with 275/60. Thank you in advance.
  2. Jan 16, 2023 at 9:41 AM
    Fotnot
    Fotnot SSEM #69; LRCS#1
    Andy
    SW Louisiana
    Swimmers gonna swim
  3. Jan 16, 2023 at 9:42 AM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    My truck came stock with 285/55/20.
    285/60/20 would be a little over an inch taller and just as wide..
    After a 2.5 front lift, I now run 275/60/20s.
    I feel the narrower tire drives a bit better than the wider 285/55 did.
    The difference in offset between your Limited (might be +50) and TSS (+55) wheels is very small if any.
    Around .2 of an inch if they are different at all...
    Migue02[OP] likes this.
  4. Jan 16, 2023 at 9:43 AM
    Migue02
    Miguel
    None-for now
  5. Jan 16, 2023 at 9:48 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    if still want more....check this out.
    i've seen that size mentioned plenty before. search bar is your friend here:thumbsup:
  6. Jan 16, 2023 at 9:49 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Here is a wheel and tire size calculator if you want to compare the differences in tire sizes..
    Fotnot likes this.
  7. Jan 16, 2023 at 9:50 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    thanks...i forgot to link that.
    i use that more than i'd care to admit:anonymous:
  8. Jan 16, 2023 at 9:50 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Or you could just give him an answer if you know it..:thumbsup:
    The search bar will give a ton of irrelevant shit.
    It independently searches every work you type in...
  9. Jan 16, 2023 at 10:15 AM
    Migue02
    Miguel
    None-for now
    Witch i already did and noticed every post is on a tss rim. I have a limited. So hence my question.
    Fotnot[QUOTED] and 1lowlife like this.
  10. Jan 16, 2023 at 10:17 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
  11. Jan 16, 2023 at 10:22 AM
    Migue02
    Miguel
    None-for now
  12. Jan 16, 2023 at 10:25 AM
    Fotnot
    Andy
    SW Louisiana
    Swimmers gonna swim
    limited is +60
    TSS are +50
    10mm difference. so a little less than 1/2"
    M3Tundra-JK and Migue02[OP] like this.
  13. Jan 16, 2023 at 8:41 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I was going to run that size but tire choices are very limited.
  14. Jan 17, 2023 at 4:39 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    I thought about going 285/60's but I didn't want to mess with rubbing or having to trim anything yet. Also with stock suspension. I went with 275/60 and am happy with em.
    If I do a billy upgrade before I buy new tires, then I'll go bigger at that point.
  15. Jan 29, 2023 at 8:13 AM
    AdamDevoeJ
    AdamDevoeJ New Member
    2018 Silver Tundra CrewMax 1794 4WD
    Tinted windows. Upgraded LED lighting.
  16. Jan 29, 2023 at 8:19 AM
    AdamDevoeJ
    New to this site.
    I currently have stock 20” premium wheels on a 2018 1794 and it came with 275/55/20R.
    I’m planning on throwing a supreme 3” front/2” rear leveling kit on it and running 285/60/20R on the same stock wheels.
    Here’s a pic of how is currently sits.
    Any suggestions?
  17. Jan 29, 2023 at 9:41 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    Welcome to the forum.
    The truck looks nice..
    At the risk of repeating myself;
    I have a 2.5" front lift and 1" rear level on stock TSS (+55) wheels.
    I'd suggest a 275/60/20 for your new tires for a couple of reasons.
    It will be an inch taller and the same width as what you have now.
    My Tundra came stock with 285/55/20 which are the same width as the 285/60/20.
    I feel the truck drives and turns much smoother with the (only .5") thinner tire.
    Also, it really doesn't look that much different as far as the tire width.
    The 285/60/20 will only get you another .5" in height (.25" of lift) and .5" in width plus about an average of 6 pounds of weight for each tire compared to the 275/60/20..
    And they are quite a bit more expensive than a 275/60/20. (see below).
    Not recommending or saying you should purchase these tires, just examples of price differences.
    I had KO (285/55/20) and KO2(275/60/20), they both got louder as they wore and neither really wore that well.
    The same tire in the different sizes..
    The difference is $312 + tax for the set.
    The difference is $420 + tax for the set..
    I will recommend this tire, I've been running for a year and I've been happy with it.
    Goodyear Wrangler UltraTerrain AT | Discount Tire
    Good luck..
    AdamDevoeJ[QUOTED] likes this.
  18. Jan 29, 2023 at 9:44 AM
    Stumpjumper
    Fate, Tx
    2017 Tundra TSS 4x4
    You might want to go a little lower in the back. 1.5 will get you close to level. If you want more rake stick with 2". Tires choices are more limited in 285/60/20 then 275/65/20 and about 15% higher in price. The 275s will be about .5" bigger in diameter giving you a .25" taller ride height.
    1lowlife likes this.
  19. Jan 29, 2023 at 10:30 AM
    AdamDevoeJ
    Yeah that makes sense. I guess my options are 60 or 65 now lol
  20. Jan 29, 2023 at 10:37 AM
    AdamDevoeJ
    I’ll be going with 275/65/20 with the 3/2 level.
    Will post update soon.
  21. Jan 29, 2023 at 11:04 AM
    1lowlife
    DADA
    2014 MGM DC SR5
    I'm gonna agree with this as well.
    I had 2.5 of front lift with 6112s and the truck pretty much sat level.
    Although I had nanny warnings on sharp fast turns.
    It looks a little nose high but it measured level on the wheel wells.
    763B91DF-899D-4443-A7EC-B9CE39DA5452_zps_d6996a7c4c346b193c23d63e1851495611ed574d.jpg
    349075C4-F21D-499D-A426-2EB0A20AD69E_zps_e9f0cfe8c791a5c73910ac23e763a49160479282.jpg
    76E597A4-57CD-4D9A-832E-E048A0579BE8_zps_674c39b67f44bbd14977aba7dabe6d21768ab8b2.jpg
    I bought Toyotec shackles, they have a 1" and 1.5" setting.
    I first opted for the 1.5 and it was WAY TOO HIGH..
    3733DCB6-FAEF-49B9-BA41-7B5A43CDDC24_zps_a856f00b79cbd6acb51db2e262c338974f59d82d.jpg
    131C28E3-753D-44DC-ABE1-E54233F6AD4B_zps_f9fdbd3e4c49aa27e5efbd52cc2c06533796d13f.jpg
    I then put them on the 1" setting.
    Funny how an alleged .5" can make such a difference.
    It pretty much has the stock rake back now, maybe a little less...
    942B7FE5-470C-4383-9C30-59887BC9D6D9_zps_131d189a12d7686efd992b23f4106d96b5e09568.jpg
    5277AC80-D0B2-400B-A247-8B6FA62EEE5E_zps_b20ea45766b2a9f595703237dc97ae894bab8af6.jpg
