285/55R20 vs 285/65R18
Discussion in 'Wheels & Tires' started by Blindf8th, Apr 18, 2018.
  1. Apr 18, 2018 at 7:53 PM
    Blindf8th
    Blindf8th [OP] New Member
    Hello,
    Recently purchased an 18' Tundra and was wondering what the primary difference is when it comes to deciding between these two tire sizes? Just started researching and I'm more interested in understanding the reasons why someone might choose one over the other. Is it mainly about more road or off-road driving? Are there other factors that I should consider that might fit my needs better?
    Thank you for any light you can shed on the topic.
    Blind
  2. Apr 20, 2018 at 5:01 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    A lot of it will be personal preference. Do you like more tire or more wheel? Tire profiles (from the rim to the outer part of the tire) are going to be more with 18's than they will with 20's. 20" wheels typically cost more than 18's, as do the tires. If you plan on offroading the truck a lot, people tend to go with 18's or so because you have more tire to protect your wheels.
  3. Apr 20, 2018 at 5:11 AM
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    @parker44 - well said. In my experience after switching from stock Platinum 20's to 18's and 285/65R18 KO2s, my truck rides smoother on road. I prefer the looks of 18's and the additional protection they give you vs 20's.
  4. Apr 20, 2018 at 5:19 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Larger heavier wheels and tires are not as easy to slow down as 18", the ride and turn in (handling) are not as good with larger than 18" on these trucks.
  5. Apr 20, 2018 at 10:43 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I have always preferred tire over rim for both off roading and on the road. Unfortunately when I bought my truck the only way to get the tires I needed (notice I said needed) was to buy the TSS OR with BFGs on 20s. I would have much preferred the same tire on 18s. In fact when I was looking to buy a TRD OR I told all of the sales people I was dealing with that the max size I feel should be on a 4x4 is an 18. I had a dealer trade working on a TRD OR when I saw the BFGs on the TSS. I decided to go ahead and try the 20s. I run some pretty rocky terrain and so far no nicks in the rims. When I replace the tires I will increase the sidewall profile. Speaking of replacing I was looking at the General X3s but pretty much scratched them off my list after seeing the weights. Those suckers are heavy but I guess most MTs are.
