285/55/20 on stock suspension?
Discussion in 'Wheels & Tires' started by matambo, Oct 4, 2017.
  1. Oct 4, 2017 at 9:25 AM
    matambo
    matambo [OP] New Member
    2017 Tundra 4x4
    I'm new to the truck world and just got my self a 17 tundra crewmax TRD 4x4. it came with the 18" 275/65/18 tires. i wanted to go 20" with a 285/55/20 wheel. tried calling discount tire and tire rack and they are having different opinions. so all ya tundra experts. would a 20 x 9 wheel equipped with a 285/55/20 have issues on a stock suspension and height? (my tundra not lifted)
    Toyota10s likes this.
  2. Oct 4, 2017 at 9:55 AM
    gm125800
    gm125800 New Member
    2018 GMC Sierra Denali
    I would like to find out as well. I'm not too convinced about the Dunlops which it came with. I was looking to go with that size on the originals or 275/60/R20 all terrain tires.
    matambo[OP] likes this.
  3. Oct 4, 2017 at 10:32 AM
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I believe my buddy's 2015 XSP-X package came with 285/55/20...wheels should be 20x9 +50 or +60 offset.
  4. Oct 4, 2017 at 11:27 AM
    matambo
    2017 Tundra 4x4
    be great if you can get the specs. i have an SR5 TRD package with 18" 275/65/18 michelins
    4x4_Angel likes this.
  5. Oct 4, 2017 at 11:40 AM
    gan
    gan New Member
    Rgv Texas
    2021 Black Tundra Pro
    that is the size that the TSS package comes with 285/55/20 BFG Ko2 it fits fine on a stock suspension.
  6. Oct 4, 2017 at 11:50 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    2017 SR5 2wd stock suspension. 285/55r20 BFG ko2's. +50 offset.
    Joncan808, matambo[OP] and srad750c like this.
  7. Oct 4, 2017 at 11:53 AM
    BRTundra
    BRTundra New Member
    Tony
    Baton Rouge, LA.
    2017 Tundra Platinum 5.7L CM
    I'm running 285/55/20 BFG KO2 on stock platinum rimswith no fitment issues.
  8. Oct 5, 2017 at 11:34 AM
    matambo
    2017 Tundra 4x4
    great looking truck. what brand wheel is that? offset is +50?
  9. Oct 5, 2017 at 11:48 AM
    easleycrawler
    Travis
    Thanks. They are BBS and I do believe they are +50. They are even with the outside of the fender and a +60 puts them inside the fender.
    matambo[QUOTED][OP] likes this.
  10. Oct 5, 2017 at 12:06 PM
    BayRunner
    It seems the consensus is that a 285/55/20 tire will fit on stock wheels (ET: +50, +60), but will it fit with aftermarket wheels such as +25?
  11. Oct 5, 2017 at 12:32 PM
    easleycrawler
    Travis
    That's iffy. Mine are really close to the front mudflap, but doesn't rub anywhere anytime.
  12. Oct 5, 2017 at 12:49 PM
    chphilo
    chphilo Tundra addict
    Western PA
    285/55/20 is slightly smaller than 285/65/18, which is not that much larger than stock tires (less than 1/2 inch taller, I think). You should not have difficulty fitting that to stock Tundras. Even with 25 mm offset wheels, it shouldn't be an issue.
    I ran 275/65/18 (stock tires) on 18x9, 18 mm offset wheels and tires didn't even come close to rubbing. That was on stock suspension. Now I have 295/70/18 on 3.5 inch OME lift.
    srad750c and matambo[OP] like this.
  13. Oct 6, 2017 at 7:05 PM
    matambo
    2017 Tundra 4x4
    thanks for all the input. just got back from the local tire discount and got myself a 20 x 9 +25 offset on Nitto TERRA GRAPPLER G2 285/55/20. wheel and tire will come tues and hope to post a photo as soon as i have it installed. thank you very much
    easleycrawler likes this.
  14. Oct 6, 2017 at 10:02 PM
    onetohunt
    onetohunt New Member
    Marvin
    2016 Magnetic Gray Tundra TSS
    Same here.
  15. Oct 24, 2017 at 6:35 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, that is what I have. I had a TRD ready go but switched gears when I saw that TSS OR had KO2s from factory. Really did not want 20s but had to compromise to get tires I needed. I run some pretty rough stuff on hunting ranch. Now will see how 20s do in the rocks.
    4x4_Angel and matambo[OP] like this.
  16. Nov 11, 2017 at 6:13 PM
    srad750c
    srad750c just passing through
    NC
    2015 Limited DC 4x4
    TRD Pro exhaust, TRD Pro suspension, G-Tek Fab door sill protectors, Stealth running boards, 20" Gunner wheels, BFG K02
    is your truck leveled?
  17. Nov 11, 2017 at 6:27 PM
    easleycrawler
    Travis
    No sir. Bone stock.
    matambo[OP] and Sunnier like this.
  18. Nov 12, 2017 at 12:13 AM
    srad750c
    NC
    2015 Limited DC 4x4
    Thanks for the info.
  19. Nov 12, 2017 at 8:31 AM
    matambo
    2017 Tundra 4x4
    thank you all for the input. just had discount tire install the new shoes. 285/55/20 Nitto tires with 20 x 9 wheels. I'm lovin it, no rubbing no issues. here is a photo of my baby.IMG_4478-3.jpg
    Miami1794, equin, onetohunt and 11 others like this.
  20. Nov 12, 2017 at 10:06 AM
    srad750c
    NC
    2015 Limited DC 4x4
    What is offset and back space? I want to up grade my feet next year.
  21. Nov 12, 2017 at 1:11 PM
    matambo
    2017 Tundra 4x4
    -18 MB wheels
  22. Nov 12, 2017 at 11:27 PM
    srad750c
    NC
    2015 Limited DC 4x4
    thanks
  23. Nov 17, 2017 at 9:18 PM
    Toyota10s
    Toyota10s New Member
    Chace
    West Coast
    2017 Toyota Crewmax limited Tundra
    Bone stock.
    Your truck looks awesome!! I'm in the same boat. I want 20s that are quiet and do the job in handling as well. I'm too old to have mudders going 24/7 on me :) The supercharger will be loud enough.
    As much as I love lifted Tundras they don't look good if the truck isn't lifted with big off-road tires. But i was afraid of what it would look like with bigger tires and no lift.
    I always compare what o want to the 2015-17 Tundra Pro. The 18" wheels/tires look tiny on that beast so I figured 20" should work and look great on the new Tundras.
    matambo[QUOTED][OP] and srad750c like this.
  24. Nov 17, 2017 at 11:10 PM
    srad750c
    NC
    2015 Limited DC 4x4
    I’m with you, I put TRD Pro shock set on my Limited DC. I hope to use with the stock 20x9 +50 offset Gunner wheels. If anybody out there knows if this will work please let me know.
    Toyota10s[QUOTED] likes this.
  25. Nov 17, 2017 at 11:38 PM
    Tomcat
    Tomcat Ever see a motorcycle outside a shrinks office?
    2010 SR5 4X4 5.7 20" wheels Metallic Gray
    Bakflip
    Nice time for some fender flares now
  26. Nov 27, 2017 at 5:57 AM
    myk1013
    myk1013 New Member
    Myk
    2017 CM * MGM * TRD
    do you happen to have pictures of your truck with this wheel and tire set up before the lift??
  27. Nov 27, 2017 at 6:57 AM
    matambo
    2017 Tundra 4x4
    still debating about the flares hahaha nut thank you
  28. Nov 27, 2017 at 7:12 PM
    chphilo
    Western PA
    Ha, I had to look through old pictures. Here's one before fender flares, without lift, stock tires on 18x9, 18 mm wheels (should tell you how much tires stick out).
    Stock tires/after market wheels (18x9, 18mm offset), fender flares.
    srad750c and Toyota10s like this.
  29. Aug 7, 2018 at 2:33 PM
    Joncan808
    Joncan808 New Member
    Jon
    None
    nice look do you have a lift or leveling kit on this? looks great what the offset of the wheel thanks
  30. Aug 7, 2018 at 5:32 PM
    matambo
    2017 Tundra 4x4
    Stock TRD suspension
