285?? / 1st gen
Discussion in 'Wheels & Tires' started by Tay2610, Nov 9, 2018.
  1. Nov 9, 2018 at 4:28 PM
    Tay2610
    Tay2610 [OP] New Member
    I have a 1” lift in the front and currently running 265/75 16. I’m wondering if running a spacer would cause any fitment issues. I’m also wondering if I can run 285’s with the spacer and not get rubbing? If anyone has any spacer pictures on 265’s or 285’s posting would be appreciated. Thank you.
  2. Nov 9, 2018 at 4:40 PM
    Casper421
    Casper421 Adventure in a 1st gen
    N. Cal
    06 DC
    What 1” lift do you have already installed? Are you talking about wheel spacers or a lift spacer?
    @Professional Hand Model is running 285’s with minimal lift from 5100’s.
    Tay2610 [OP] likes this.
  3. Nov 9, 2018 at 4:48 PM
    Darkness
    Darkness New Member
    Luis
    All over SoCal
    The darkest
    It's really dark
    Stock wheels? That matters.
    285/75 16 inch rims with 4" backspace (maybe)
    3.5" lift up front +/- (lowering it this month)
    2" lift in rear
  4. Nov 9, 2018 at 4:50 PM
    Professional Hand Model Fred Brookes
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    I have been on 285/75/r16 for about 12 years. No lift (until the recent Billy 5100 at one notch up from bottom). They have always had slight rub on inside frame at full turn.
    Since the front end rebuild with new shocks, lower control arms (OEM), and new cam bolts things are a little different. The front tires are more vertical now due to the newer better alignment and the rub seems to be a slight one on the upper control arm at a hard turn like cutting into a parking spot.
    I just make sure to not turn hard. In your case, you have a spacer lift. Might be different.
    Tay2610 [OP] and Casper421 like this.
  5. Nov 9, 2018 at 4:55 PM
    2002 Tundra SR5 4WD
    Aluminum sideboxes
    On stock wheels rims. You like my new radar ball on the cap?
    BestGen, Darkness and Tay2610 [OP] like this.
  6. Nov 9, 2018 at 7:04 PM
    Tay2610
    Sorry I need to clarify. I’m asking about wheel spacers. I have 5100’s on notch #3 (1.1”?). I would like to be more flush with the flares. Do wheel spacers create fitment issues? (Interference with the flare?) Would aftermarket UCA’s allow for 285’s w/no rub? 2006 AC stock wheels.
  7. Nov 9, 2018 at 7:06 PM
    Tay2610
    Can I even fit 285 on a 17x7?
  8. Nov 14, 2018 at 4:13 PM
    seth419
    seth419 New Member
    Santa Barbara, CA
    2005 Tundra DC 4x4
    I think 1.25" is about the smallest spacer that will work, get spidertrax. Not sure about rubbing but pushing the wheels out will cause them to be closer to front and back of wheel wells when turning. Lots of guys run 285's on the stock wheels.
  9. Dec 3, 2018 at 10:32 AM
    WaTrout88
    WaTrout88 New Member
    Benjamin
    2002 White Tundra TRD
    Rear leaf ICON progressive aal, Billy's 5100 4 corners
    I have a 2002 Tundra TRD AC. I have Billy's on all four, with AAL in the rear. I just had some 285/75/16 BFG KO2s installed on stock 5 spoke wheels at 4wheelparts. They had to use G2 1.25" spacers to keep the tires from hitting the upper control arms. It was cheaper than getting new wheels but it cost me $200 bones for the spacers. I had some rubbing on the front fender plastic so I removed the fenders this weekend and no longer have the issue but I have yet to stuff the wheels and see if they hit anywhere else. Here are some picture.
    After: 285/75/16
    UsKvZAZEcurClvy4KJzYc5IoxIfam86bie08JZve_d3d3d2b9963f97846911101a4a0bfb5ffbfedf14.jpg
    Before: 265/75/16
    I4o4JwRfTt992-cKalfaL5J9yrUyWmmjVOm6iNJj_65201dde37cc4cd3638b276be35c8231578de621.jpg
    P70-et5QUMgnou6RoNjFPv7dZh6GKXgqKAbkGfaX_5e2e8544ec86aad1b169b0dc52716558f043f846.jpg
    This is where it was hitting.
    gJ7iNO4nY5oP7eBcqvRNfXoZ33B0vmmC8WQ9Bzr__87746cf6ef57fb67c883deadcf1547e503a05350.jpg
    Tay2610 [OP] and BestGen like this.
  10. Dec 5, 2018 at 10:21 AM
    WaTrout88
    Benjamin
    I adjusted the depth of my spacer. I just checked the invoice and it was a G/2 93-83-125T which is a 1.25" wheel spacers not the 1.5" that I had originally said.
  11. Dec 25, 2018 at 3:43 PM
    JustGotDuals
    JustGotDuals New Member
    @WaTrout88 what level are your billies set at? How is the ride quality with them on that set? Thanks
  12. Dec 27, 2018 at 9:14 AM
    WaTrout88
    Benjamin
    I believe I currently have them at the 2nd to last notch. Ride quality is fine, the new BFGs add some stiffness at first but I don't notice after driving it the last couple of weeks. I did notice this weekend when I came into a steep sidewalk apron a little hot, I had some rubbing so I will need to look into my pinch welds soon and get out the surgery tools.
