275x70x18 with my 5100 setup?
Discussion in 'Wheels & Tires' started by k9shag, May 12, 2019.
  1. May 12, 2019 at 3:34 PM
    k9shag
    k9shag [OP] New Member
    Tony
    Midland, NC
    2017 Tundra DC SR5 MGM
    Ok trying to figure this out have been up and down the forum and have no real idea.
    Currently I have a stock 2017 SR5 with TRD wheels and 275x65x18 Coopers.
    Tuesday I am having 5100's put on all fours on the middle setting up front. I chose the middle setting because I am also going to order a topper and do not want the front higher than the rear. My plan was to upgrade the tires to Michelin Defender load range E 275x70x18. I do not want to trim anything other than removing the front mud flap if necessary.
    Will this work?
    Anyone running this setup?
    Thanks Tony
    Rica25 likes this.
  2. May 12, 2019 at 3:50 PM
    Cavscout
    Cavscout New Member
    Rick
    2015 DC SR5 TRD
    Stock (mostly)
    I have a 2015 TRD DC and my 5100s were just delivered. My Falken wildpeak 275/70/18 tires were delivered last week. Waiting for time to get both installed. Also going with the middle setting on the front. Everything that I have read says everything should work out fine.
    Gearbox80 likes this.
  3. May 12, 2019 at 4:00 PM
    rons23
    rons23 Get The Led Out!!!
    Ron
    Kill Devil Hills
    2008 Nautical Blue TRD
    @k9shag, no you won't have to do anything. Your only going up a little over 1" and keeping same width. :thumbsup:
  4. May 12, 2019 at 6:04 PM
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    I have that size tire on stock suspension, so I think you'll be fine. :thumbsup:
    15whtrd likes this.
  5. May 12, 2019 at 6:07 PM
    CrunchTimeHD
    CrunchTimeHD New Member
    Louis
    Easton Pa
    2011 tundra limited CrewMax
    You should be fine I'm running 275/70/18 with no lift and I didn't have to do any trimming.
  6. May 12, 2019 at 6:23 PM
    k9shag
    Tony
    Midland, NC
    Great to hear, thanks everyone.
    Squatting Pigeon likes this.
  7. May 12, 2019 at 8:51 PM
    CARLHEIZER
    CARLHEIZER New Member
    San Diego
    2019 TUNDRA 1794 EDITION
    LINE-X, BAK MX4 WITH BAK BOX, UPGRAGED SOUND SYSTEM BY OEM AUDIO + AND CERAMIC WINDOW TINT - ALL SIX WINDOWS.
    Pics please when done!
  8. May 12, 2019 at 9:32 PM
    Steve89gt
    Steve89gt New Member
    2018 Limited CM
    De-badged, De-chromed, TRD CAI, TRD Exhaust, Bilstein 5100s, Fuel 18 x 9 wheels, BFG KO2s 275/70/18, ESP Underseat Storage
    I have the same setup, you’ll be fine.
    Mikekoot and plumber802 like this.
  9. May 16, 2019 at 6:45 PM
    Gearbox80
    Gearbox80 New Member
    Brent
    Courtland, Ontario, Canada
    2018 Cement grey TRD
    TRD sticker removed 275/70/18 KO2’s More mods to come in future
    Any pics yet?
  10. May 18, 2019 at 12:27 AM
    Cavscout
    Cavscout New Member
    Rick
    2015 DC SR5 TRD
    Stock (mostly)
    No pics yet. The 5100s were installed today and the tires with alignment is tomorrow. Will post pics later.
  11. May 18, 2019 at 4:06 AM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    So just confirming... 5100 middle setting and no lift in rear? I'm looking at same so just keeping up.
    OP looking forward to see your pics
  12. May 18, 2019 at 4:16 AM
    k9shag
    Tony
    Midland, NC
    Here Is a pic after the 5100 install. Front on middle setting. The tires are Cooper 275/65/18. I will be going to Michelin Defender 275/70/18 I think. Although staying with the current size will keep my speedo correct and save a little fuel.
    I have to admit I just drove over 400 miles on a trip to DC and the difference in the ride was very noticeable. For the better.
    Here is a pic bone stock.
  13. May 18, 2019 at 5:38 AM
    Steve89gt
    2018 Limited CM
    Yes
  14. May 18, 2019 at 7:11 AM
    Rica25
    Ricardo
    Tulare
    I've gone with about 6 different sizes on my truck since new highest I went was 305 70 18 now after 10 yrs finally went back to the stock Michellin LTX At2 and the power is now back the comfort is also back ride is great and the best is my MPG is also back the look was great with my 295 70 18 Nitto Ridge Grapplers but were absolutely heavy and I did not want to re gear
  15. May 18, 2019 at 7:13 AM
    Mikekoot
    Mikekoot New Member
    Canadia
    2018 MGM tundra sr5 DC /2014 SSM Toyota Tacoma sr5 DCLB
    I got that size duratrac with no lift then threw in some 5100 in middle setting with no issue.
    Rica25 likes this.
  16. May 18, 2019 at 7:13 AM
    Mikekoot
    Mikekoot New Member
    Canadia
    I did this a while ago. I have a thread
    Rica25 likes this.
  17. May 18, 2019 at 9:04 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Nice truck. I run that size in Ridge Grapplers on stock TRD OR suspension, no issues at all.
    Rica25 likes this.
  18. May 18, 2019 at 10:09 AM
    k9shag
    Tony
    Midland, NC
    When you went to 275/70/18 how much was your speedo enter off.
  19. May 19, 2019 at 4:30 AM
    pro2amendment
    Indiana
    Bullet liner
    The difference in circumference is just over 3%.
    So if if speedo reads 70mph you may actually be going 72-73.
  20. May 19, 2019 at 4:45 AM
    pro2amendment
    Indiana
    Bullet liner
    Oh. I never scrolled down before. The site actually gives you the speedo info as well.
    Rica25 likes this.
  21. May 20, 2019 at 11:58 AM
    Cavscout
    Cavscout New Member
    Rick
    2015 DC SR5 TRD
    Stock (mostly)
    Here is the promised pic.
    My driveway is not level. The front measures 39 1/4” from the ground and the back is 40 1/4”. The ride may be a little stiffer than it was, but the old shocks had 73,000 miles on them. The tires are as quiet as advertised and if they last as advertised I will be very happy. I bought everything on Amazon. Tires $710, 5100s $352. Tires mount, balance, alignment, and strut install was about $500. So about $1550. I do notice that I need to stretch a little more to get in the drivers seat. May need to get the driver side grab handle in the future. There is no clearance issues. I am very happy the way everything turned out.
    nvrgvup444 and k9shag[OP] like this.
