275/80R/18’s on today....which wheel spacers should I get?
Discussion in 'Wheels & Tires' started by Nativeimages, Apr 17, 2021.
  1. Apr 17, 2021 at 4:38 PM
    Nativeimages
    Nativeimages [OP] New Member
    Willard
    2018 Tundra 1794 Edition
    2.75 inch front lift and 3 inch lift in rear....rubbing on skid plate....fixed by bending...considering cutting....removed front splash guard....at full turn tire rubs on sway bar.... I think I need wheel spacers....the question is what size....I’ve never had wheel spacers before....so am asking the more experienced members for advice....thank you
  2. Apr 17, 2021 at 4:39 PM
    Nativeimages
    Willard
    Darn iPhone key pad is so tiny....just saw the title in the thread...sorry....ha.....lol
  3. Apr 17, 2021 at 4:40 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    The two most used and proven options are http://www.spidertrax.com/2007-Up-Toyota-Tundra-Wheel-Spacers and https://rogue-offroad.com/BORA-Wheel-Spacer--Tundra--125_p_9869.html The bora ones come in different sizes and the spidertrax is one size. I am currently running the spidertrax and am happy with them.
  4. Apr 17, 2021 at 4:41 PM
    Nativeimages
    Willard
    Is Amazon ok to buy from?
    BravoDeltaRomeo likes this.
  5. Apr 17, 2021 at 4:45 PM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    As far as I know it is. Here is a pic for ya
  6. Apr 17, 2021 at 4:51 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    If it's fulfilled or shipped & sold by Amazon, go for it. Just be careful it's not from a new seller and the price seems too good to be true. That is usually a red flag for fraudulent sellers.
    The free shipping and return policy make it hard to not buy from Amazon.
  7. Apr 24, 2021 at 7:49 AM
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    I had 2” Bora bought them on ebay. You can also install a turn limiter.
    Nativeimages[OP] and Ted4311 like this.
  8. Apr 24, 2021 at 7:53 AM
    Ted4311
    Ted4311 Don't Sweat The Small Stuff
    SOMD
    14 Tundra MGM TRD-OFFROAD 4X4
    A LOT... NEVER ENDS
    20210416_195230.jpg I have 2 inch. No regrets.
  9. Apr 24, 2021 at 8:15 AM
    RoniusMaximus
    RoniusMaximus The One and Only
    J
    Tri-Cities, Washington
    2020 MGM Toyota Tundra TRD PRO
    Synthetic Blinker Fluid
    275-70-18 KO2s with spidertrax
  10. Apr 24, 2021 at 8:32 AM
    Nativeimages
    Willard
    I bought and installed the 1.25 inch spider trax...installed on 2018 tundra....with a larger and heavier tires....from a stock 70 lb tire /rim combo...275/65r/18.... to a stock rim and a kenda klever AT 275/80r/18 tire setup.....the stock combo setup weighs 70 lbs each stock tire/wheel combo.....the new kenda klever setup with stock rims comes in at 100lbs each....that’s about a 30 lb increase in weight for each...I did the 50 mile check inspection per install instructions....I got a front end alignment after I installed the spider trax.....my question......is my kenda klever wheel/tire combo setup to heavy....that’s quite a weight increase over stock....any thoughts?
  11. May 2, 2021 at 10:25 PM
    Big J
    Big J New Member
    2020 4x4 crewmax
    What is this set up? What lift and tires size? Any issues with 2" wheel spacers?
    CoachJ likes this.
