275/70R18 - BFGoodrich All-Terrain T/A KO2 for 2nd gen
Discussion in 'Wheels & Tires' started by epicurese, Jul 22, 2023.
  1. Jul 22, 2023 at 10:54 AM
    epicurese
    epicurese [OP] New Member
    I've got a 2008 tundra with no lift. It's the SR5 if that matters. It's time to get new tires. Does anyone know if BFGoodrich All-Terrain T/A KO2 (275/70R18) will cause rubbing? Thanks!
    Update: the wheels are the Toyota 18 inch alloy wheels.
  2. Jul 22, 2023 at 10:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Depends on wheel offset
  3. Jul 22, 2023 at 11:10 AM
    epicurese
  4. Jul 26, 2023 at 4:26 PM
  5. Jul 26, 2023 at 4:34 PM
    jdg1982
    jdg1982 New Member
    Florence, Colorado (From Louisiana)
    2017 Magnetic Gray Tundra SR5 4x4
    I have 275/70R18 KO2s on stock suspension. I have SCS Ray10s. The only rubbing I have if I'm full turned in reverse. I did remove that little mudflap that's on the front of the tire.
    The Dude and Mahilts09 like this.
  6. Jul 26, 2023 at 4:53 PM
    Black Beauty 5.7
    Black Beauty 5.7 New Member
    Cannon
    2007 Black 5.7L Tundra SR5
    250,000 miles and always adding more :)
    You should be fine I'm on a horrendous monroe suspension with 275/65/r18s which is even lower than stock in the front and I don't rub at all with the factory mud flaps. I do have a -9 offset I believe on my maverick ultras but I'm also like 3/4" shorter in the front.
  7. Jul 26, 2023 at 6:14 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    I have 295/70/18 on stock wheels. No lift currently.
    You'll be just fine.
