275/70 R18 Tires and Thoughts on 10 ply?
Discussion in 'Wheels & Tires' started by scruff1221, May 6, 2025.
  1. May 6, 2025 at 9:20 AM
    scruff1221
    scruff1221 [OP] New Member
    Ryan
    2022 Tundra Trd Off-road
    Anyone Running 275/70 R18 Tires and Thoughts on 10 ply?
    Does it make it rougher riding?
    I'm looking at a tire however they only offer in LT and 275/70 18
    Any pictures of truck would be helpful
  2. May 6, 2025 at 9:55 AM
    msl0
    msl0 New Member
    24 SR5 TRD OR
    Tires, plates, canopy
    I'm running this size in 10ply on my '24 SR5 TRD OR and have found it depends on the tire model. Summer tire is a general grabber a/tx and in the winter I'm running studded nokians. I keep tires between 30-35psi as the temperatures vary, and find that the general's obviously have a bit more road noise, but they are a bit (but noticeable) smoother ride, both on and off road. I only ran the stock tires for <20km so I can't really compare to those
  3. May 6, 2025 at 10:04 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    I'll throw this out there. Take it for what it's worth.
    I'm only sorta close at 285/75/18 which is nearly 35". They are 10-ply / E-load.
    Your 275/70's are just over 33's, so quite a difference in sidewall height. Roughly an inch.
    Going from my stock 20's 265/60/20 (32.5" high) to these near 35's was a wash from a ride quality standpoint. Definitely not worse at all.
    33's aren't much additional sidewall than stock so...... YMMV
    raylo likes this.
  4. May 6, 2025 at 11:44 AM
    RabidAxolotl
    RabidAxolotl New Member
    25 Lunar Rock Limited
    Rougher compared to what?
    Only had 275/70r18 for a day and haven’t noticed any difference in the short drives I’ve had
  5. May 6, 2025 at 11:49 AM
    scruff1221
    Ryan
    Stiffer Ride with a harder compound rubber
  6. May 6, 2025 at 11:53 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    I know it's not quite apples to apples, but I ran both D and E rated tires on my Tacoma and I didn't think they rode bad at all. I actually was pleasantly surprised because of all the instances I heard of people putting on E's and then it rode like a dump truck. I'm sure a lot of that depends on suspension and even the brand as well but for a heavy truck like a tundra I wouldn't worry about it.
  7. May 6, 2025 at 11:54 AM
    BlackNBlu
    Rich
    MN
    Compared to a non-10 ply/E-load tire.
  8. May 6, 2025 at 1:22 PM
    Nbab23
    Nbab23 2020 SR5
    Nathan
    PA
    2020 SR5 crewmax
    Stillen CAI, DD 8” exhaust, Toytec Aluma coilovers, Icon leaf springs, SCS SR8 18x9 wheels, Cooper Rugged Trek 275/70/18 A/T Tires, Ecoological bumper shellz and grill surround, AJT interior black out kit, AJT shift knob. TRD pro style grill, VLED aqua blue footwell lights, MESO custom dome and map LED lights, swing case, Rough country bed mat, TRD pro headlights and fog lights, Morimoto XB tail lights and 3rd brake light.
    The larger size E tire will create a rougher ride for sure. Early on it may feel about the same but as the tire wears a bit there will be some noise and a rougher ride compared to stock tires. Tire quality and tread pattern can come into play as well. It just depends your driving preferences and if you want to sacrifice some ride quality for looks. I personally am okay with a little rougher ride if I am gaining a more aggressive look. It will also affect acceleration a bit with the heavier tire and gas mileage. Things to consider as well.
  9. May 6, 2025 at 4:32 PM
    SC SR5
    SC SR5 New Member
    2014 SR5 CM, 2025 Lifted Platinum
    RC coilovers/level shocks , 2014 Factory lift on the 2025 Platinum
    I like my 10 ply Es filled to 65 lbs all around, if I towed all the time I’d have the rears at 80, very rare if I get a nail or screw in my 10 ply’s, I’m on construction sites daily
  10. May 6, 2025 at 4:41 PM
    RabidAxolotl
    I got a nail/screw in a AT3W on my 4Runner. It would slowwwwwly leak air, only lose 5-7lbs and never anything more. Figured the tire had so much rubber that is was basically sealing it self off when the pressure got to a certain point or something.
    SC SR5[QUOTED] likes this.
