275/70/18 Pressure?
Discussion in 'Wheels & Tires' started by ProtoJ, Mar 30, 2019.
  1. Mar 30, 2019 at 3:05 PM
    ProtoJ
    ProtoJ [OP] New Member
    2018 Crewmax TRD Off-Road
    I have 275/70/18 KO2s on my 18 CM. My door jamb says 30F/33R. The inter webs have from 30-45psi. Anyone know what the actual recommended pressure for these tires are? They feeling amazing at 30....but thinking 35 is probably more appropriate.
  2. Mar 30, 2019 at 3:09 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    38 on mine
  3. Mar 30, 2019 at 3:11 PM
    ProtoJ
    I have the E rated KO2s and a Topper on the back. What is the chalk test?
  4. Mar 30, 2019 at 3:32 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    I run 275/65 ko2. Same width on 18x9 wheels i run 50psi front 40 back with no load
  5. Mar 30, 2019 at 3:47 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Toyo open country AT’s on mine
    35-40 all around 45 on rear when towing/hauling.
    Rica25 likes this.
  6. Aug 11, 2019 at 1:14 PM
    NJ Cement TRD Pro
    NJ Cement TRD Pro My Tundra has a Raptor bodykit.
    Ben
    Bergen County, NJ
    2019 Ford Raptor
    I have the same tires on my 17 TRD Pro. 41.5 is too firm. Shakes the entire frame and chassis.
    34 feels better, front and rear.
    Your results may vary.
    Rica25 likes this.
  7. Aug 11, 2019 at 1:33 PM
    pro2amendment
    pro2amendment Member
    Indiana
    2018 Tundra: 5.7L Flex, MGM Gray DC, Offroad pkg
    Bullet liner
    To see the tread pattern imprint. At ideal inflation it will be across the entire width. Too high and more the center shows but not edges and too low it might cup in the middle.
    I've also seen where people calculate based on max load of the tire. Whatever the ratio of your truck weight/max load, multiply that by the max load pressure to figure out a good tire pressure for your set up. I found that was too run high in another vehicle but I put 10 ply on a tiny xterra.
    Rica25 likes this.
  8. Aug 15, 2019 at 8:42 AM
    SLC Tundra
    SLC Tundra New Member
    JkT
    '19 Tundra SR5 CavalryBlue 4x4
    2" lift, TRD 18" wheels, Nitto TerraGrappler G2's, Bilsteins, black powder coated logos and bumpers
    I run Nitto Terra Grappler g2's 275/70-18 E rated and found 44 to 45 psi front and back for day to day works well. When towing, I air up the rears to 50 to 55.
  9. Aug 15, 2019 at 8:46 AM
    I ran 44 in mine as well when I had them. As a matter of fact, I am running 44 in my 285/70/18 Ridge Grapplers.
  10. Aug 15, 2019 at 8:47 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    I got over 60K miles on my 275/70R/18 KO2's and I ran 40 lbs of pressure. I also religiously rotated them every 5K miles.
    I didn't do any towing and I use my truck primarily as a daily driver.
  11. Sep 6, 2019 at 2:44 PM
    Tundramoney
    Tundramoney Old school
    Earth
  12. Sep 22, 2019 at 5:04 PM
    SLC Tundra
    JkT
    Update. I'm finding that I prefer my Nitto Terra Grappler g2's ride a little better at 42 psi cold. On the freeway they warm & increase to 44-45 which is perfect.
  13. Nov 24, 2020 at 9:27 PM
    Zizyang
    Zizyang New Member
    2020 tundra pro army green
    275/70/18 falken wildpeak at3w im running 35 all around is that to low? 2020 tundra pro
  14. Nov 25, 2020 at 4:17 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    As you can see, pressures folks run range from mid 30s to upper 40 psi, and it really depends on how their truck is set up, add-ons, loaded, etc. Here is info on the chalk test mentioned before- https://www.youtube.com/watch?v=FabWgDAulGg
    Zizyang likes this.
  15. Nov 25, 2020 at 4:19 AM
    frichco228
  16. Nov 25, 2020 at 5:00 AM
    glowblue
    glowblue From time to time
    VA
    2021 Tundra SR5 —> 2021 F-250 XLT
    I have the exact same tire and The tire shop set them to 38 psi when I installed them. Recently I raised them to 42 psi and think they ran a little smoother.
    Zizyang[QUOTED] likes this.
  17. Nov 25, 2020 at 7:33 AM
    Zizyang
    Zizyang New Member
    Did you run at 42 all around?
  18. Nov 25, 2020 at 7:50 AM
    Kanobi13
    Kanobi13 New Member
  19. Nov 25, 2020 at 7:52 AM
    Lake.Life24
    Lake.Life24 New Member
    Shawn
    Upstate, NY
    2021 GMC Sierra 3500HD Gasser
    General Grabber ATXs 275/70/18 I run 40 up front and 44 in the rear to support the additional weight of the cap, crates and tools
    Zizyang likes this.
  20. Nov 25, 2020 at 8:04 AM
    PhysicZ
    PhysicZ 1g3
    Robert
    2013 MGM Tundra crewmax
    I run toyo at3s in socal, customer service from toyo told me 36 front, 38 rear in my conditions
  21. Nov 25, 2020 at 8:19 AM
    Zizyang
    Zizyang New Member
    Well i cant do the chalk test right now its raining where i live in going to try 36 in the front and 38 in the back.
  22. Nov 25, 2020 at 10:57 AM
    glowblue
    VA
    Yes. If I’m hauling heavy stuff I might air up the rears but generally run same pressures in all tires.
