275/70/18 on a 18x9 wheel OK?
Discussion in 'Wheels & Tires' started by BlueBottle, Oct 2, 2016.
  1. Oct 2, 2016 at 5:36 PM
    BlueBottle
    BlueBottle [OP] not a PRO
    '16 Platinum 4x4
    See fine print
    I know that 275/70/18 fits good on 8" wheels but Im thinking of putting it on a 18x9 wheel.
    The tire I am planning on using is Wildpeak A/T3W tire.
    Manufacture specs say it can go up to a 8.5" wheel. So I am wondering how it would fit on a 9" wheel. Anyone have any experience mounting these tires on a 9" wheel?
    My second tire choice is 305/65/18 but I don't want to due to possibly having to trim to fit them. I will be on a 3/1 lift. I also do not want to lose too much mpg or power.
  2. Oct 2, 2016 at 5:52 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    2020 Tundra TRD Sport - 2017 4runner SR5p Trailpig
    I would say do not put the 275s on a 9" rim. You definitely want your tires to be a fair amount wider than your wheels to avoid curb rash on the wheels.
    Technically it will fit but it will look bad and a pothole or hitting a curb will chew up your wheels.
  3. Oct 2, 2016 at 6:46 PM
    ToyotaTundraMike
    2015 Tundra
    Look through the wheel and tire setup thread. There are a few guys running that size tire on 18x9's. I would send a few messages and see how their experience has been. I was gonna do the same and had the same question as you and was told it would be okay, but some tire shops may not do the install.
    BlueBottle [OP] likes this.
  4. Oct 2, 2016 at 6:52 PM
    bigoltater
    bigoltater New Member
    KC
    2005 Tundra DblCab4x4
    Leveling Kit,33'BFG
    18x9 on 275 70 is fine
  5. Oct 2, 2016 at 6:54 PM
    Backslider
    Tooele, UT
    As I said, it will fit but there is a good reason NOT to do it.
    That tire is so close to the wheel's width that it offers little to no protection to the wheel. You could mount a 255 on a 9" wide wheel, doesn't make it a good idea. I have also been told it's possible to lose the bead during normal, every day driving when you go with such a narrow tire.
  6. Oct 2, 2016 at 7:07 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    My wife has rubbed into a few curbs and never touched the wheel, and I have to admit I have too the first few days I had them put on, but the tire does petrude enough to protect the rim. I don't care for the fat tire look so that is why I went with the 275's. I don't see a reason not to unless your bad driver and have a tendency to hit curbs.
    As for the bead thing, I've never heard of that.
    zcarpenter92 likes this.
  7. Oct 2, 2016 at 7:14 PM
    Backslider
    Tooele, UT
    More potholes than curbs. I can pull this truck into the tiniest of spaces, but a bad pothole will marr the surface of your rims. It will eventually happen.
  8. Oct 2, 2016 at 7:57 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    If it wasn't worried about curb rash, will I be ok running it though? The truck stays on pavement also.
    Thanks for those pics! that tire doesn't look bad on that wheel. Is that a 3" lift?
  9. Oct 2, 2016 at 7:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    wow.. losing a bead during normal driving? that would be bad...
  10. Oct 2, 2016 at 7:59 PM
    Backslider
    Tooele, UT
    Not in the case you mention but in extreme tire/wheel mismatches. I should have been more clear, sorry.
  11. Oct 2, 2016 at 8:01 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Im still confused on what to order haha.. i need to make a decision in about a week.
    I may try to get my tire shop to order me both sizes if they let me and test fit them before making a decision.
  12. Oct 2, 2016 at 8:01 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    It's a 2 inch level, stock on the rear.
  13. Oct 2, 2016 at 8:23 PM
    Backslider
    Tooele, UT
    I really like your wheels. What are they?
  14. Oct 2, 2016 at 8:43 PM
    bigoltater
    KC
    Leveling Kit,33'BFG
    Fuel anza
  15. Oct 3, 2016 at 8:29 AM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    2020 Limited DoubleCab
    So you're buying new tires and you have a choice? I would agree with @Backslider, don't go against manufacturers max width. Look for a 285 or 295. I'd be more worried about losing the bead. You know how your underwear starts stretching out after awhile and starts getting a little loose? Well one time I tried buying one size smaller. Can I put it on and wear it? Yes. Is it too tight and uncomfortable and my balls are at risk? A little bit. Do I recommend? Hell no.
  16. Oct 3, 2016 at 9:34 AM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    Shit. I just ordered 18x9's last night and my tires are brand new 275/70's. Im glad I saw this thread - I'm hoping they'll cancel the order for me.
  17. Oct 3, 2016 at 9:38 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    lol I like your analogy. But what if I like p use smaller underwear lol. Jk.
    joonbug likes this.
  18. Oct 3, 2016 at 9:38 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    What tires did you order? Don't forget each tire is a different size. So make sure to check the factory specifications.
  19. Oct 3, 2016 at 9:39 AM
    joem1cha3l
    Albany, NY
    I have Cooper Discover STT Pro's
    T-Rex266 likes this.
  20. Oct 3, 2016 at 9:42 AM
    joem1cha3l
    Albany, NY
    Just looked on their site and it says "approved rim width 7" - 8.5" '
    SHIT.
  21. Oct 3, 2016 at 1:33 PM
    joem1cha3l
    Albany, NY
    Well, my 9" wheels will be here on Friday and I'm going to give it a shot. I'll post back here with my thoughts after they're on. I only put about 6k a year on my truck though so it'll be a small sample size of driving compared to most.
  22. Oct 3, 2016 at 1:43 PM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    I think you'll be ok. Seems fine on Bigoltater's. My point to OP was if he was buying new tires anyways, might as well buy the correct size. I think .5" will be fine.
    joem1cha3l likes this.
  23. Oct 3, 2016 at 1:54 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Take some pics of how much the tires stretch on the wheels. I think you will be fine too though. Being optimistic here!
    I'm scared to run bigger size and rub a dub dub. I really don't want to do any trimming if I can help it. I don't mind removing mud flaps though.
  24. Oct 3, 2016 at 2:03 PM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    So are you buying new wheels? Whats the offset?
  25. Oct 3, 2016 at 2:53 PM
    joem1cha3l
    Albany, NY
    You guys think I'll have problems with those 9" wheels now with rubbing?
    Runnings 275/70/18's on a 2.5" Level currently with stock wheels and 1.25" spidertrax. Was rubbing at full lock on the stock wheels so I removed the mud flaps and that seemed to fix it. Not sure whats going to happen now *sigh*
  26. Oct 3, 2016 at 3:22 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    18x9+12
  27. Oct 3, 2016 at 3:30 PM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    Ask @Law323
  28. Oct 3, 2016 at 3:39 PM
    joem1cha3l
    Albany, NY
    This is the EXACT wheel I have coming. Went with +12 to get me close to flush with my flares. If you can wait a few days I can give you an exact honest opinion but with my tires.
  29. Oct 3, 2016 at 3:44 PM
    joem1cha3l
    Albany, NY
    Kind of curious, what wheel did you go with? Couldn't find a ton of options
  30. Oct 3, 2016 at 3:45 PM
    joonbug
    joonbug bacon
    Joon
    NorCal - Dublin
    bet you two have the same wheel. lol
