22 Tundra TRD Suspension Lift Kit
Discussion in 'Suspension' started by gr8fasushi, Sep 11, 2022.
  1. Jan 16, 2024 at 2:35 PM
    #991
    dadtrucklife
    dadtrucklife New Member
    2021 SR5 TRDOR 4x4 (Army Green)
    Prospective buyer here. Correct me if I’m wrong, 33s are the largest standard load tires available on the market. I don’t want to sacrifice weight and mpgs and go any bigger. Do 33s look bad on the factory lift, should I not order the factory lift and stick with the standard TRD off-road suspension? Stock seems low and lift seems more than I need. Anyone else wish they offered an in between height?
    Slimdusty likes this.
  2. Jan 16, 2024 at 7:57 PM
    #992
    Slimdusty
    Slimdusty New Member
    Slim
    2023 Black 1794 OR
    I had a bit of this dilemma also, but went with it and love the way it looks. I found the 275/65/20 recon grappler (34”) in standard load only 48 pounds and that’s what I did and love it!
    one option for you might be to just do a “lift level” one of the products that just lifts the front end level with the back. They are much cheaper and are an “in between” perfect for a 33”. Some guys say the ride is rough though. Look up cornfedsuspension.com
    jachal and dadtrucklife[QUOTED] like this.
  3. Jan 17, 2024 at 4:03 AM
    #993
    EveryDayEnthusiast
    EveryDayEnthusiast New Member
    Get the kit from westcott design with them for 1k rides great
  4. Jan 17, 2024 at 6:55 AM
    #994
    2021 work truck
    2021 work truck New Member
    22 Tundra Crewmax 6.5
    33" Tires, Black Toyota Rims, TRD shocks
    I ordered the shocks separately for under $600. I want to keep the stock UCA and axles. I'm thinking by keeping the front under 2" lift I will be ok. Leveling with 5100 shocks is pretty standard for most IFS Toyota trucks. The fact that these shocks are tuned for the Tundra lift kit that allows for a 33" tire is why I went with them. I'm just hoping they do not droop too much since they do extend an extra 2" vs original shocks. Anybody with more knowledge or insight would be great. I haven't found anybody else who has gone this route. I might have to be the guinea pig!
  5. Jan 17, 2024 at 12:03 PM
    #995
    dadtrucklife
    I should rephrase my question. What is the tallest standard load tires in 18” wheels? My research shows 33s, is there a 34? Seems like most run 34+ with the lift. Anyone run 33s?
  6. Jan 20, 2024 at 7:43 PM
    #996
    Capecodpat
    Capecodpat New Member
    patrick
    2024 platinum tundra
    Question. Are you able to fit 35’s without any other modifications with the trd lift kit?
  7. Jan 21, 2024 at 5:46 AM
    #997
    jhtram
    jhtram If I'm curt with you it's because time is a factor
    Jay
    Raleigh, NC
    2023 Lunar Rock Tundra Limited TRD
    OEM TRD Lift Maxxis RAZR AT LT285/65R20 tyres Spidertrax 1" Spacers Retrax Pro XR Tonneau Bumpershellz 'stache overlay TRD Pro Fender Flares Yakima Overhaul HD Bed Rack OEM Blackout Overlays aFe Front Tow Hooks Talon's Cat Shield Undercover SwingCase Toolboxes TufSkinz Console Cover (Matte black) ScreenProtech LCD and instrument cluster protectors Tailgate & bumper vinyl inserts (texas decal king)
    My personal experience is you'll need spacers if using OEM wheels. Also will require pinning back the fender well carpet and front mud flap removal or trimming
  8. Jan 21, 2024 at 7:33 AM
    #998
    Capecodpat
    patrick
    What offset are your 17’s. Just got zero offset RRW’s and looking for 35’s without rubbing hopefully
  9. Jan 21, 2024 at 8:42 AM
    #999
    jachal
    jachal jachallen
    andy
    FLX, NY
    2023 Black Platinum Hybrid
    dealer installed trd lift w
    2” rear coil springs
    35x12.5r18 firestone destination xt’s
    on kmc impact +18
    Newm, dutch2112, Minarets and 2 others like this.
  10. Jan 22, 2024 at 6:44 PM
    #1000
    boomtime
    boomtime New Member
    I swapped out the sway bar drop brackets with the Icon drop kit (PN 55151)
    I was having issues with rubbing the sway bar with 285/75 R18 with the TRD Pro BBS wheels (+47.5mm offset)
    With the Icon sway bar drop kit I can now turn the wheel to full lock. I can also install my fabric skid plate over the sway bar. I'm going to attempt to re-install the air dam as well at some point since I still have the motor on there. I hope that the dealer who installed the kit gave me all the hardware back in the box they left me with.
    Hoody likes this.
  11. Jan 22, 2024 at 6:54 PM
    #1001
    boomtime
    boomtime New Member
    The Icon spacers are 4 pieces. They're pretty symettrical. One long piece and one short piece for each side. There weren't any instructions but it was pretty straightforward.
    It comes with 4 bolts and washers. The OEM stuff is 17mm. The kit comes with 19mm. They're shorter than the bolts that are in the TRD Lift brackets but longer than the bolts that are on a stock Tundra.
    Removed the TRD Sway bar drop bracket...
    Doing this myself I re-installed one bolt part way while I placed the spacers in on the drivers side.
    I placed the Icon spacers in on the drivers side and then did the same on the passenger side. The longer spacer doesnt really seem to have anything that indexes it in place so I just tried to make it aligned as best as i could.
    Final torque to 59 ft-lb. I chose this value from the TRD Lift kit manual.
    Clearance with the Icon sway bar drop kit... I drove it around the block for a couple miles and I couldn't make it rub. It looks close but maybe it puts it in a different location such that the wheel travel doesn't allow it to hit the sway bar? I hope so...
  12. Jan 22, 2024 at 6:55 PM
    #1002
    boomtime
    boomtime New Member
    Badass... which rear spring?
    jachal[QUOTED] likes this.
  13. Jan 22, 2024 at 6:57 PM
    #1003
    jachal
    jachal jachallen
    andy
    FLX, NY
    thx bro — Toytec
  14. Jan 22, 2024 at 7:02 PM
    #1004
    Hoody
    Hoody Member
    Kommiefornia
    '23 Platinum 6.5 bed
    Nice, glad this helped with the rubbing. It's funny their recommended 285 tire size on oem wheels seems to rub everytime. Looks like it changed the drop from maybe 3" to 1" ish. Just enough room for your tires.
    I wonder why they dropped it so far with the kit. Do you need an alignment after moving the bar up? And was it super tight or feel like it was binding when you tightened the bolts back down?
    SWFL23TRDOR likes this.
  15. Jan 22, 2024 at 7:06 PM
    #1005
    boomtime
    boomtime New Member
    When the vehicle is on the ground the sway bar has a ton of free play. Very easy to move it into place. The only resistance i felt was from the bushings in the endlinks. yeah 285's rub every time. I can't imagine how the folks with 35x12.5" are doing with the stock rims.
    I just measurd the TRD drop bracket at 3 5/16", the icon spacer is 3/4".
    Regarding alignment... i dont think so. hopefully someone corrects me if i'm wrong. my probably wrong understanding of the sway bar is to have the left and right suspension work together but still have some flex/compliance for the suspension to also work independently to an extent. i know for sports cars people use different stiffness sway bars to tune for more oversteer/understeer.
  16. Jan 22, 2024 at 7:39 PM
    #1006
    jachal
    jachal jachallen
    andy
    FLX, NY
    more
    Cheeko and Yaboy like this.
  17. Jan 22, 2024 at 7:50 PM
    #1007
    Hoody
    Hoody Member
    Kommiefornia
    Yeah I wouldn't think you'd need an alignment but I've never really messed with sway bars before.
    I just put my front air spoiler back on today. The dealer trimmed it for me and said I could put it back on but it needed a little more trimming around the trd sway bar brackets. You might not need to trim anything with those higher brackets.
    You made me start thinking of switching to the icon drop brackets and just keep my 20" plat wheels since they match the MGM, but I do like having more rubber with 18's. Not sure my wheels would work still since they're +60 and yours looks like it's cutting close already.
  18. Jan 22, 2024 at 8:20 PM
    #1008
    boomtime
    boomtime New Member
    It might be worth a shot... they're about $80 with tax.
    Amazon.com: ICON Front Sway Bar Drop Kit, Compatible with 2022-2023 Toyota Tundra, 55154 : Automotive
    I also ordered spidertrax wheel spacers but I don't think i'll be putting those on if i don't have any issues with the icon spacer. i should have waited before ordering the spidertrax.
    Would you happen to have any pictures of how the air dam mounts? I haven't tried fitting it yet and i'm not sure how the brackets should install.
  19. Jan 22, 2024 at 8:57 PM
    #1009
    Hoody
    Hoody Member
    Kommiefornia
    No pics of the brackets but there's a hinge on each side with a welded nut and use one bolt each, the ones with the washer on them. Then the motor is right in the middle and has two holes, use the other two bolts and go up through the spoiler into the mount on the motor which has threads in it.
    You shouldn't need to deploy it down to mount it. At first I deployed it down and put the motor bolts through the motor into the spoiler before I realized it was backwards. Let me know if you still need pics, I can take some pics of how it mounts tomorrow if needed.
  20. Jan 26, 2024 at 5:18 AM
    #1010
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Ride quality with the factory TRD suspension is good? Significantly better than Westcott 3/1?
  21. Jan 26, 2024 at 5:24 AM
    #1011
    bfluitt
    bfluitt New Member
    2024 Limited TRD OR - TRD Lift
    No comparison, I actually sold a '23 because it had the westcott / air suspension. Like riding a pogo stick.
    Rolling on the factory trd 3" now, very nice.
    Minarets[QUOTED] likes this.
  22. Jan 26, 2024 at 5:27 AM
    #1012
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Thank you
  23. Jan 27, 2024 at 1:25 AM
    #1013
    royaldouchebag
    royaldouchebag New Member
    G
    2024 Limited Crewmax 6.5 TRD OR
    3” factory lift
    I apologize if you already mentioned this, but which solution did you go with on the front sway bar? I’m hoping to run that same size tire in a yoko geo at hd on stock TRD rims.
  24. Feb 6, 2024 at 12:37 PM
    #1014
    Marc4x4
    Marc4x4 New Member
    Has anyone got the TRD lift and stuck with the stock tires for awhile, does it look stupid. Picture would be nice. Thanks
  25. Feb 6, 2024 at 12:41 PM
    #1015
    Marc4x4
    Marc4x4 New Member
    Do you have any rubbing. Thanks
  26. Feb 6, 2024 at 1:19 PM
    #1016
    Hoody
    Hoody Member
    Kommiefornia
    I still have the stock ones, not by choice but until I can afford new wheels and tires. It's been almost 2 months and it'll be a while longer since I want wheels and tires due to the sway bar rubbing with oem wheels. It honestly doesn't look as bad as I thought it would but it definitely could use that wheel well filled in.
    My dealer just got another truck in like mine except with factory installed lift and they swapped out the tires for KO2's but I think only 1 size up 275/65/20, looks better with the BFG sidewall at least.
    jachal and Newm like this.
  27. Feb 6, 2024 at 1:29 PM
    #1017
    Marc4x4
    Marc4x4 New Member
    Interesting the OEM wheels rub, first time Ive read that.
  28. Feb 6, 2024 at 2:07 PM
    #1018
    Hoody
    Hoody Member
    Kommiefornia
    Well the tires seem to rub on the trd kit sway bar due to the oem wheel offset even with Toyota's recommended size of 285's. Unless you add wheel spacers. From what I've read dozens of times on here at least and lower wheel offset seems to be fine, like methods +18.
  29. Feb 6, 2024 at 3:06 PM
    #1019
    nrm91
    nrm91 New Member
    Boise, ID
    2022 Platinum CrewMax Magnetic Grey
    35/11.5/20 Toyo AT III's
    What did you pay for the lift and what did the dealer charge to install?
    PapaDave418 likes this.
  30. Feb 6, 2024 at 3:22 PM
    #1020
    DBTundra278
    DBTundra278 New Member
    Dustin
    2023 Tundra SR5 TRD Off Road
    How did you get the blackout Toyota logo and blue “mustache”?
