22 tundra trd MAJOR GAP headlight and fender
Discussion in '3rd Gen Tundras (2022+)' started by Carguy912, Sep 18, 2022.
  1. Sep 18, 2022 at 5:26 PM
    Carguy912
    Carguy912 [OP] New Member
    2022 Tundra trd offroad
    Wheels, tires, grill, lift, ceramic tint, heretic fog lamps and debadged.
    So, I've had my new trd off road a week. Had already ordered trd pro gill, heretic amber fogs and decals, wheels tires and lift. AND, new headlights (upgraded LED'S found on upper trims and not an SR5 like mine) but when I was about to take off the other headlight I noticed this huge gapbetween the headlamp and fender. The same on the other side. Does anyone have this with their 22 tundra?? Seriously on a Toyota? Honestly all the gaps are overly larger than what you would expect on a 60k truck. Any thoughts?
  2. Sep 18, 2022 at 5:32 PM
    Taco-Spike
    Two Trucks
    That’s a big gap
    Mind the gap
  3. Sep 18, 2022 at 5:32 PM
    Carguy912
    Here is a pic of mic'd gap width.
  4. Sep 18, 2022 at 6:30 PM
    RookieEP
    RookieEP New Member
    2020 Tundra Limited TRD Magnetic Gray
    None
    Take truck to the dealer, that’s ridiculous.
  5. Sep 18, 2022 at 6:45 PM
    breynolds
    breynolds New Member
    Future Tundra owner
    Certainly something is stopping it from closing all the way?? Or the rubber stopper is turned up too high. Shocked it left the factory like that.
  6. Sep 18, 2022 at 9:44 PM
    1*MEDIC
    1*MEDIC New Member
    Mine has the same gap.
    mrfreeman likes this.
  7. Sep 18, 2022 at 10:01 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    toyota is moving forward, soon it's gonna be same as tesla...lol
    RookieEP likes this.
  8. Sep 18, 2022 at 10:57 PM
    RLHULK
    Rich
    2022 Silverado LT.
    Still rolling stock baby....
    Question on the headlights, I was under the impression the wiring harness is different for the SR5 and higher trims? Or are they simple plug and play?
    aeroo777 likes this.
  9. Sep 19, 2022 at 12:17 AM
    Booney
    Booney New Member
    Northern Colorado Mountains
    Smoked Mesquite 2021 1794 Off Road TRD
    Yeah... I would definitely take that to the dealership and let them fix it.
  10. Sep 19, 2022 at 2:00 AM
    Retired...finally
    A wee bit more than 1/8" between the headlights and the fenders? Must be me but that seems acceptable. It's a truck that must be designed for some light work and off roading. Stuff gives.
    BaldMenace likes this.
  11. Sep 19, 2022 at 5:00 AM
    nodak67
    nodak67 New Member
    JR
    from what i remember another forum member had the same issue. it was a mis aligned hood stop on one side or something to that effect.
    Carguy912[OP] likes this.
  12. Sep 22, 2022 at 9:47 AM
    Carguy912
    I drove down to my local toyota dealer and they had two new Tundras. Both has the gap one better than mine one worse. I have been in the automotive retail business for 31 years in hilton head sc and I can tell you it is absolutely not acceptable. It is as poor as Teslas fit and finish which is the worst. Also, as most of you are aware the head light upgrade dose.t work. Canbus lines and new wiring harness. I thought I did my due diligence and the dealer told me they were compatible. 100% they are not.
    Kap1 likes this.
  13. Sep 22, 2022 at 10:00 AM
    BadTrainDriver
    BadTrainDriver New Member
    2022 Tundra Capstone
    Times have changed...
  14. Sep 22, 2022 at 10:00 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    That straight up look like a cheap aftermarket headlight that don’t fit right…there should be no gap at all…gaps is for moving parts, doors, hood and tailgate.
    RookieEP and Carguy912[OP] like this.
  15. Oct 3, 2022 at 12:38 PM
    TSS Army Green
    TSS Army Green New Member
    @Carguy912 So did the upgraded LED headlight end up working for your SR5 truck?
  16. Oct 4, 2022 at 6:18 AM
    nodak67
    nodak67 New Member
    JR
    or for items that flex. not all items that dont move cant flex.
  17. Oct 4, 2022 at 6:22 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
  18. Oct 4, 2022 at 6:22 AM
    Boats N TRDs
    Boats N TRDs New Member
    Travis
    2022 Tundra Limited HV TRD OR
    Chrome delete
    Looks to me like the gap is fine, but the seal on the headlight isn't sitting properly and is folded back under the light housing.
  19. Oct 4, 2022 at 6:44 AM
    Carguy912
    The toyota store was wrong. They absolutely won't fit. Canbus lines are required for headlights for self leveling.
    Buellride likes this.
  20. Oct 4, 2022 at 6:46 AM
    Carguy912
    In regards to the headlight gap...there is no seal. No gasket or rubber. I've removed both. There should be but. That I'm assuming will be the fix or an insert to cover the hole. Virtually like I stated earlier all that I've seen have same issue.
  21. Nov 5, 2022 at 12:00 PM
    KrisGut
    KrisGut New Member
    hi so i just realized gap between hood and headlight on my 2022 toyota tundra platinum its different left side around 1/4 inch right side 1/2 inch
  22. Nov 6, 2022 at 8:43 AM
    Floridaman850
    Floridaman850 New Member
    Travis
    Panhandle
    '18 Cavalry Blue TRD Pro Tacoma
    Mobtown bolt-on sliders for tight parking spots
    There should be rubber stoppers on each side that are adjustable. Have them on my Tacoma. You can just hand screw to the height needed to adjust hood lay. I imagine Tundras have something similar.
    =JSG= likes this.
  23. Nov 6, 2022 at 10:08 AM
    Carguy912
    I put pictures in the thread. Its not the hood gaps it's on the fender where there is a visible hole on the side of the light. Should have a rubber molding.
  24. Apr 6, 2023 at 6:49 PM
    nodak67
    nodak67 New Member
    JR
    hate to un zombie an old thread, but was looking at the front end and notice that the alignment on the hood to front rubber seal is off from passenger side to driver side along with the headlight gap.
    driver vs pass hood gap and then driver vs pass headlight gap
