22 TRD Pro / Heritage Grille Camera Mount Bracket
Discussion in '3rd Gen Tundras (2022+)' started by Brums, Apr 30, 2022.
  1. Aug 11, 2022 at 7:49 AM
    #241
    whiskey_woo
    whiskey_woo New Member
    no you will have to run your own wiring or splice into something just like an aftermarket solution
  2. Aug 11, 2022 at 7:51 AM
    #242
    myerswoodshop
    myerswoodshop New Member
    2022 Toyota Tundra Platinum
    Gotcha. Wondering if $200 is worth it just for the 'looks' if I never wire it to anything...
  3. Aug 11, 2022 at 10:45 AM
    #243
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    A626174C-AE62-43EA-8446-D783C6763032.jpg 82451DBC-47A4-4C25-BD6F-04C46B8FE2B3.jpg
    My amber lights for the TRD Pro Grille came in today. The holes don’t actually line up with anything, so I’m going to save install for when I take my front end apart in about a week. Planning on just tapping into the wiper fuse on the driver side for power. I added the fuse connector on there
    ToyoTundra89 and eddiefromcali like this.
  4. Aug 11, 2022 at 10:49 AM
    #244
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    are they standard halogen or LED?
  5. Aug 11, 2022 at 10:56 AM
    #245
    ByeF150HelloTundra
    DFW
    2022 Tundra SR5
    LED, you can vaguely see them in the bottom picture
  6. Aug 12, 2022 at 3:45 AM
    #246
    Brums
    Brums [OP] New Member
    Bethel, OH
    22 Tundra DC TRD Sport
    Those lights look great, appears that your still going to have to come up with a custom mounting solution though, my guess is the Chinese grille has stand offs molded directly into the grille to mount these. Same thing for the light bar, it doesn't appear to have the mounting tabs in the same locations as oem light.
    One way I could think to mount it would be to get some 1/4 in or so, plastic rod and drill a hole in one end and then cut to length, and glue/ contact cement / jb weld / plumbers cement (if you get ABS rod) to the oem grille
    I might have to order some of these
  7. Aug 12, 2022 at 9:13 AM
    #247
    eddiefromcali
    Eddie
    100% Stock
    Can loan you my set once I get it. Saves you some cash if it doesn't work out
  8. Aug 12, 2022 at 5:33 PM
    #248
    Brums
    Bethel, OH
    once someone has them "set in place" would like to see a picture of how far back the mounting tabs of the lights go, if they aren't extremely long, could probably use the alum bar thing like i did as well
    could probably use an angled piece to mount them
  9. Aug 12, 2022 at 8:19 PM
    #249
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    2022 Tundra SR5 TRD OR CM 6.5
    Got mine today too. Definitely going to need a custom mounting solution than my electrical tape lol. As ByeF150HelloTundra said, the holes dont line up to anything. At least they fill out the voids nicely.
    I did order a set from Rave Offroad that came out today. So depending on when those arrive. I may just rig those up instead. Curious to see how those mount up as well.
    20220812_201026.jpg 20220812_201033.jpg 20220812_201049.jpg 20220812_201119.jpg 20220812_195811.jpg
    KClav and zstone93 like this.
  10. Aug 12, 2022 at 9:37 PM
    #250
    Jr3volution
    Jr3volution New Member
    Johnnie
    DFW TX
    Looks like you’ll be getting some amber light emitted behind the grille?
  11. Aug 13, 2022 at 9:23 AM
    #251
    jgoliath
    jgoliath Northeast Rust Fighter
    2022 Tundra, SR5 Offroad, Lunar Rock
    You have the coupon code for rave off-road? I saw he posted it but I’m not seeing his posts anymore.
  12. Aug 13, 2022 at 9:28 AM
    #252
    eddiefromcali
    Eddie
    100% Stock
    FUNDRAFORUM
  13. Aug 13, 2022 at 10:06 AM
    #253
    brucega7x
    brucega7x New Member
    2022 Tundra SR5 CrewMax 4X4
    I want to order but I was just wanting more info on how it’s wired in before I do.
  14. Aug 13, 2022 at 10:12 AM
    #254
    jgoliath
    Looks like a good ol’fuse tap. Pick your fuse or run a new fuse block with switches.
    eddiefromcali likes this.
  15. Aug 13, 2022 at 10:14 AM
    #255
    eddiefromcali
    Eddie
    100% Stock
    You could wire however you'd like :notsure:. Theyre only gonna draw like 1A, tops....any circuit could handle them
  16. Aug 13, 2022 at 11:28 AM
    #256
    Pg1329
    Pg1329 New Member
    2022 tundra limited
    did the grille fit perfectly? And did u need to recalibrate the tss
  17. Aug 13, 2022 at 11:26 PM
    #257
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    Are the screws that hold the camera a T6? I’m stumped. :bananadead:
  18. Aug 13, 2022 at 11:27 PM
    #258
    eddiefromcali
    Eddie
    100% Stock
    It is
    Yaboy[QUOTED] likes this.
  19. Aug 13, 2022 at 11:32 PM
    #259
    Yaboy
    Yaboy New Member
    Canada
    22 limited off-road
    The only one I don’t have…. :sick:
  20. Aug 14, 2022 at 4:51 AM
    #260
    Brums
    Bethel, OH
    my guess is the rave will attach with double sided tape on the "wing" part of it
    if you wind up going with the rave and don't want the chinese ones, let me know how much you want for them
  21. Aug 14, 2022 at 7:40 AM
    #261
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Gonna run the Chinese ones for now. Since they have the oem look. Going to attempt to install today. As long as I can figure out a easy mounting solution. Never ran a fuse tap before. So if anyone has any pointers on where specifically to tap into so that these run with the automatic daytime running lights that would be appreciated.
  22. Aug 14, 2022 at 7:47 AM
    #262
    whiskey_woo
    IGN so that it comes on when the truck is on and off when you turn it off. Please share your solution!
    ToyoTundra89[QUOTED] likes this.
  23. Aug 14, 2022 at 8:25 AM
    #263
    knewcomb
    knewcomb New Member
    What is the size of the screw that holds the camera to the original mount? Nevermind question answered a few posts above.
    Yaboy likes this.
  24. Aug 14, 2022 at 11:13 AM
    #264
    knewcomb
    knewcomb New Member
    Got everything assembled but the wiring for the front camera isnt long enough to make it to the plug. Am I missing something there?
  25. Aug 14, 2022 at 11:29 AM
    #265
    eddiefromcali
    Eddie
    100% Stock
    I just unclipped it from one or two clips nearest the camera and that gave me enough slack
  26. Aug 14, 2022 at 12:17 PM
    #266
    knewcomb
    knewcomb New Member
    That did it. Swapping this thing out was a little more annoying than I was anticipating.
  27. Aug 14, 2022 at 12:51 PM
    #267
    eddiefromcali
    Eddie
    100% Stock
    Yep...million screws and clips
  28. Aug 15, 2022 at 1:32 PM
    #268
    myerswoodshop
    ToyoTundra89 and Yaboy like this.
  29. Aug 15, 2022 at 5:57 PM
    #269
    Brums
    Bethel, OH
    just so you know, putting the fender liner on the outside is incorrect when reassembling, there is a gap between the bolt holes in the plastic fender flare that it is supposed to slide into
    from your video, just FYI
    Hugo Stiglitz, jgoliath and Yaboy like this.
  30. Aug 15, 2022 at 6:01 PM
    #270
    ToyoTundra89
    ToyoTundra89 Member
    Seattle, WA
    Mounted the markers, was ready to take apart my front bumper but after further reading i realized I would need some DIY spacers since I have the oe light bar. Will hold off until I pick up some additional hardware to allow for AGS to fit with the oe light bar.
    This isn't the best solution by any means, but it's easy and cheap. Maybe 10 bucks in materials. I tried both 3M and Velcro. Both worked, but I liked the velcro fitment better. Adhesive felt stronger, and it was easier to get them to line up straight. They're really solid and not going anywhere, and easily removable if needed. Edit: Run a small bead of super blue on the top of the plastic light housing where it meets the grill to eliminate any gap. Works great.
    Going to pick up the additional hardware later this week. Planning to wire up the markers by the fuse tap method. Light bar is just for show. Not messing with that wiring mess anytime soon.
    Materials:
    -9 inch simpson strong tie
    -10lb Velcro
    20220813_162048.jpg 20220814_100829.jpg 20220814_104749.jpg 20220814_101534.jpg 20220813_163407.jpg
    eddiefromcali, KClav, Yaboy and 2 others like this.
