22 TRD Pro / Heritage Grille Camera Mount Bracket
Discussion in '3rd Gen Tundras (2022+)' started by Brums, Apr 30, 2022.
  1. Oct 5, 2022 at 8:30 AM
    #361
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    youd have to break/cut it off somehow
  2. Oct 5, 2022 at 12:38 PM
    #362
    ByeF150HelloTundra
    ByeF150HelloTundra New Member
    DFW
    2022 Tundra SR5
    yup, could prob just cut it off with a knife.
    paradizecityz[QUOTED] likes this.
  3. Oct 9, 2022 at 6:15 PM
    #363
    paradizecityz
    paradizecityz New Member
    Richmond, TX
    2022 Tundra TRD Off Road
    So I did it. Am I 100% happy with results? No but it was my fault.
    Used a bit of both hot glue gun and jb weld. Hot glue on top so it would stay and I jb weld the bottom and side as much as I can. Messy job and got some of the black on the front lights but can’t tell from a distance lol
    I didn’t use their harness, cut it up and just wired to my switch
    aeroo777 likes this.
  4. Oct 25, 2022 at 12:30 PM
    #364
    Prescott87
    Prescott87 New Member
    Jonah
    Brentwood, Ca
    2022 Supersonic Red Limited
    TRD Filters, De-Badged, TRD Pro Grille
    For those of you that got the light bar too from Alibaba, how do you like it? Any issues? I'm going back and forth between the OEM look and the Baja Designs option.
    Baja Designs and eddiefromcali like this.
  5. Oct 25, 2022 at 12:33 PM
    #365
    eddiefromcali
    Eddie
    100% Stock
    Light output is ok...nothing fancy. Mounting is a pain because nothing lines up. Looks completely stock and is light enough to not need any additional support like the Baja Designs lights
  6. Nov 4, 2022 at 10:33 AM
    #366
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    Got my grill from the local dealer, now looking for the lights, specifically the light bar. Baja design is out of stock. Any suggestions besides the cheap low output stuff?
    Yaboy likes this.
  7. Nov 4, 2022 at 10:35 AM
    #367
    whiskey_woo
    whiskey_woo New Member
    *laughs in cheap low output*
    9OH1 and ryanwgregg like this.
  8. Nov 4, 2022 at 10:35 AM
    #368
    whiskey_woo
    *cries
  9. Nov 4, 2022 at 7:19 PM
    #369
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    I thought some members were complaining about the low output from the oem/ebay light bars.
  10. Nov 5, 2022 at 7:59 PM
    #370
    Prohit
    Prohit New Member
    2024 Sequoia Platinum
    I thought the Baja had the bracket to hide the mounting screws?
  11. Nov 7, 2022 at 12:45 PM
    #371
    Prohit
    Prohit New Member
    did you not use the bracket?
  12. Nov 7, 2022 at 5:07 PM
    #372
    v-wiz
    v-wiz New Member
    Vic
    Lunar Rock Tundra
    Baja is back ordered for two months
  13. Nov 7, 2022 at 7:21 PM
    #373
    Prohit
    Prohit New Member
    You can clearly see the mounting screws.
    It looks great either way, just thought the bracket would hide it more.
    Baja Designs likes this.
  14. Nov 8, 2022 at 8:37 AM
    #374
    eddiefromcali
    Eddie
    100% Stock
    Did BD send you the support bracket?
  15. Nov 8, 2022 at 8:41 AM
    #375
    eddiefromcali
    Eddie
    100% Stock
    ryanwgregg likes this.
  16. Nov 8, 2022 at 8:48 AM
    #376
    eddiefromcali
    Eddie
    100% Stock
    I'd ask @Baja Designs if you need that bracket...sounds like it's free. Westcott warned me about this issue and I passed along the info to BD...maybe this was the result of that
  17. Nov 8, 2022 at 8:59 AM
    #377
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    The support bracket is in development and will be supplied to each customer who has already received this kit thus far included in the original cost. We created this support bracket in response to competitors' kits creating issues with the stock grills on this truck. For all new orders, this support bracket will be included.
    Best,
    Brandon
    eddiefromcali[QUOTED] likes this.
  18. Nov 8, 2022 at 9:16 AM
    eddiefromcali
    Eddie
    100% Stock
    just as an FYI. Westcott told me that during testing, the grille would crack at the mounting points from the weight/vibration of the light bar. Because of this, they have not released a kit until they addressed the issue. From what I've seen, theyre close to releasing it with the support bracket.
    This conversation with Jeff started when I posted how I mounted my knockoff light bar and he suggested the support bracket and mentioned their R&D. The chinese knockoff is super light, so I havent bothered with a support, but I did thank him for sharing his findings. I then passed along the info to BD. I wouldnt run the light bar without the support bracket...youre risking ruining the grille.
  19. Nov 8, 2022 at 11:20 AM
    #379
    Baja Designs
    Bill
    San Marcos, CA
    Hey @Yoda_Lance, from what I have been told the grills with the camera are stiffer than the grills without. This should limit any chances of issues but has not been proven yet. This being said did you purchase the light bar kit directly from us? If not please get in contact with me so the support bracket will be issued to you when it is released.
    Best,
    Brandon
  20. Nov 8, 2022 at 8:34 PM
    #380
    paradizecityz
    Richmond, TX
    I wonder how the new DD light bar will be then as I don't think that one has a support bracket...
  21. Nov 9, 2022 at 8:06 AM
    #381
    eddiefromcali
    Eddie
    100% Stock
    itll likely suffer from the same issues that westcott found IF the bar is heavy enough. Not sure how the DD compares to the BD, but it does look smaller and likely lighter. Jeff did mention that weight was a/the factor in the grilles cracking.
    I'll keep my chinesium bar for now until this all gets sorted out.
  22. Nov 10, 2022 at 7:40 AM
    #382
    paradizecityz
    Richmond, TX
    Just tagging @Diode Dynamics to see if they have a response. Thanks!
    SC4333 likes this.
  23. Nov 11, 2022 at 6:19 PM
    #383
    bongbong
    bongbong New Member
    2023 Tundra Limited
    Do you know the dimension of those lights?
  24. Nov 14, 2022 at 5:05 PM
    #384
    Prohit
    Prohit New Member
  25. Nov 14, 2022 at 5:31 PM
    #385
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    What is this dear item I lay my eyes on?
    Is it the oem lights and bracket?
  26. Nov 15, 2022 at 6:25 AM
    #386
    Prohit
    Prohit New Member
    oem lights but I had to 3D print the bracket.
    ryanwgregg and iiawah808[QUOTED] like this.
  27. Nov 15, 2022 at 7:07 AM
    #387
    iiawah808
    Oahu, HI
    Nice! Can’t wait to see the end result.
  28. Nov 15, 2022 at 11:28 AM
    #388
    Prohit
    Prohit New Member
    B31BF514-F2B0-444D-8D57-D85B2B9887BA.jpg 6566413C-A10B-4E9D-84EC-D7F1A5DC0EA5.jpg
  29. Nov 15, 2022 at 1:57 PM
    #389
    eddiefromcali
    Eddie
    100% Stock
    truck needs like 2" spacers now
  30. Nov 15, 2022 at 5:24 PM
    #390
    bongbong
    bongbong New Member
    2023 Tundra Limited
    Are you able to share the file so I could print this as well?
    SC4333 likes this.
