22’ TRD PRO mods? Let’s see
Discussion in '3rd Gen Tundras (2022+)' started by TobyKai, Jul 30, 2022.
  1. Sep 21, 2022 at 6:35 PM
    #241
    Pilotjoe123
    Pilotjoe123 New Member
    Joe
    2019 Tundra Sport red
    don't sweat it man just use that battery lol
  2. Sep 22, 2022 at 7:19 AM
    #242
    naddysaad
    naddysaad New Member
    2022 Tundra TRD Pro
    any lift or level?
  3. Sep 22, 2022 at 7:32 AM
    #243
    hyperlight12
    hyperlight12 New Member
    Mark
    2017 TRD Pro
    None - just took off mud flaps all the way around
  4. Sep 22, 2022 at 7:53 AM
    #244
    kregstrong
    kregstrong New Member
    Anyone know how the hell to jump this thing off if ever needed, or to jump another vehicle with cables from mine? Is there some terminals under the hood somewhere. If so I never saw them. Haven't opened the back seat battery compartment yet, too many car seats lol.
  5. Sep 22, 2022 at 7:43 PM
    #245
    4wd TRD PRO
    4wd TRD PRO New Member
    Driver side in the cab under the back seat, remove the access panel and there is your battery.
    RickyBobbysTundra likes this.
  6. Sep 23, 2022 at 3:51 PM
    #246
    Siblue
    Siblue Old member
    Ryan
    25 Tundra TRD pro
    Question for the pro owners
    Are the door handles and tailgate handle gloss black or flat/matte black?
    Thanks.
  7. Sep 23, 2022 at 4:27 PM
    #247
    4wd TRD PRO
    Not gloss.
    zonehenge and Siblue[QUOTED] like this.
  8. Sep 24, 2022 at 3:56 PM
    #248
    zonehenge
    zonehenge New Member
    Pete
    Western Mass
    2022 Solar Octane TRD Pro
    285 75 18's Wild Peak, PPF for front, Go Rhino RB20 slims, Truxedo Sentry CT, TVD decals
    matte as is the top part of the sideview mirrors
    Siblue[QUOTED] likes this.
  9. Sep 24, 2022 at 10:50 PM
    #249
    M11s n B&T’s
    M11s n B&T’s New Member
    2022 Tundra TRD Pro
    Just got these ones from a vendor on eBay, they Fit well. Hard ABS material with black camo pattern.
  10. Sep 25, 2022 at 9:21 AM
    #250
    M11s n B&T’s
    2022 Tundra TRD Pro
    Outdoor lighting little better now to compare
    I donot benefit nor affiliated with this seller in any way. I had a PM asking where these were from so I’m sharing. Also i did ask the seller of these if he could cut other materials. He said he could, i was thinking about sending him some forged carbon fiber sheets https://www.rockwestcomposites.com/chip-board
    https://www.ebay.com/itm/3742152396...RPOpJtfS8u&var=&widget_ver=artemis&media=COPY
    Next mods going to see how i like the AFE intakes, burger jb4 (been sitting here since before the truck got here just have not put to much time into trying to find the rear harness as the hybrid stuff seems to really get in the way of what you need to do comparing to the non hybrid install video. Also got the burger valve noise maker things lol Not bothering with an exhaust if anything i will try bypassing the secondary cats then datalogging to make sure everything stays happy (check for boost creep etc)
    ReCKzX, ytank1, MateoAirborne and 2 others like this.
  11. Sep 28, 2022 at 6:09 PM
    #251
    M11s n B&T’s
    2022 Tundra TRD Pro
    Put these on this evening, drove it quick to see how it sounded. This box is so well sealed as a true cold air intake that there is hardly a difference in noise. Now I’d you want noise there are removable plates on it but if you want performance you’ll want to keep it sealed. It’s essentially a prettier version than stock with a filter with more surface area. Very well engineered though I am impressed I have to say. Uses factory mounts off air boxes fits just like stock. Took maybe 30 minutes to do it however I watched the directions several times before doing it so it would be easier to go about. Make sure you put maf’s in right direction (tubes) or you’ll have issues. Also I noticed left and right maf’s had a slightly different number on top so I made sure the left stayed on the left and right stayed on the right. Not sure if it would have made a difference but didn’t want to test it out. New mounts for maf use new screws Torx heads. You will also need flat head, Phillips, 10mm to remove stock straps and I think it was a 7mm to fasten new worm gear straps.
    =JSG= and Eurodriver like this.
  12. Sep 29, 2022 at 4:59 AM
    #252
    atrouth
    atrouth New Member
    Anthony
    2022 Tundra Platinum CrewMax
    Man, the toys in that garage.....
    How are you liking the new AFE intakes? I've been considering that as an upgrade on mine
    =JSG= likes this.
  13. Sep 29, 2022 at 8:41 AM
    #253
    M11s n B&T’s
    2022 Tundra TRD Pro
    they are very well built. i seen some people talking negatively on them, i figured id try them. But man they were well thought out.
    They use the factory bushings to mount, the line right up for the factory cold air ducting and seal up to it. They have removable covers if all you care about is the sound. The real gain over factory airbox is CFM from larger surface area filters. I got the dry filters as the other kit was a 6-12 week lead time. This truck's engine compartment i can tell from using high pressure washing is sealed up pretty good from elements like my nissan is therefore even with covers out you arent going to hear alot. My cayenne is decatted with intakes as well, it has louder intake sounds than both of the other FI vehicles but after a wash, much more water under the hood. I dont think the truck will benefit much if you leave the factory engine calibration in place, im sure the factory airboxes were engineered for what Toyota wanted out of this motor. So i think only worth it if you plan on getting either a VR tune or JB4 from Burger.
  14. Sep 29, 2022 at 11:37 AM
    #254
    letsgomoreplaces
    letsgomoreplaces New Member
    Carl
    2022 Tundra SR5 TRD OR crewmax
    Soon to install lift, 37s, Nitro Gears
    Just got my TRD pro. I'm replacing my SR5 off-road that I got in january. The last one I ran 37s on with this custom wrap and a bunch of other goodies. Doing the same on the TRD Pro. Timing worked out so the wraps already done
  15. Sep 29, 2022 at 3:04 PM
    #255
    SC.Pro92
    SC.Pro92 New Member
    Nick
    2022 Tundra TRD Pro? Lunar rock
    Took a trip to Asheville before the hurricane killed our Florida plans. Literally climbed this joker up the mountain and finally had a use for the fancy front facing cameras I said I would never use. Not any major off-roading but more than riding around corn fields I normally do. Haha
    ytank1, =JSG=, DFS and 4 others like this.
  16. Sep 30, 2022 at 10:25 AM
    #256
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    Looking good. How are you liking the Wescott lift now that youve had a little while?
  17. Sep 30, 2022 at 12:04 PM
    #257
    SC.Pro92
    SC.Pro92 New Member
    Nick
    I like it so far ride and comfort wise. Only thing I am hating about this thing is my gas mileage. I averaged 12.9 in the mountains and on the interstate with eco mode turned on. I knew the lift and tires would affect it but so far the best I could do is 15.6 mpgs stock. But then again it’s smiles per gallon that matter most I guess.
  18. Oct 4, 2022 at 6:15 AM
    #258
    M11s n B&T’s
    2022 Tundra TRD Pro
    Just did JB4 and his vent to atmosphere diverter valve adapters. Noticed driving a different vehicle and wife following me in truck the intake sound difference is much more noticeable by whoever is in front of you for sure.
  19. Oct 4, 2022 at 11:18 AM
    #259
    jeosbor1
    jeosbor1 New Member
    North Carolina
    2022 Lunar Rock Limited TRD OR
    Is the vent a BOV?
  20. Oct 13, 2022 at 11:08 PM
    #260
    M11s n B&T’s
    2022 Tundra TRD Pro
    yes but like Terry at Burger said start with 2 screws out. I tried all 4 and it affected drivability due to mass air flow measurements being too far out of spec. I went to 1 screw out truck runs perfect. Tune is great. I used a special tape we use that is like a stretchy rubber we use to secure fittings on cellular sector radios and wrapped the entire JB4 in that for weather protection. Reason being the one in my cayenne got water damaged some how. I suggest it not sure what Terry will say but for sure seal up your chips before the install. Today I got the tint evened out and step bars finally. Going in 2 weeks to get rid of secondary’s leaving factory TRD exhaust on and I think that will be a great balance of sound plus a little bit of top end gain removing those secondary’s. Did same with my Cayenne Turbo and it sounds perfect on stock muffler. The nismo on other hand tuned up, runs so rich on 93 it looks like an asshole with a Cummins when I hit it lol. Part of GTR’s and pump gas those cars love to run pig rich. Next mod id like is audio and one of those peddle input accelerator things to give faster response so downshifting occurs quicker. Wish they would of given us paddles I’m so used to driving with those in everything else. I prefer to be In control of trans over computer. With tires and all I’m getting 15mpg highway and about 13 around town.
    ytank1, =JSG= and iiawah808 like this.
  21. Oct 16, 2022 at 2:48 PM
    #261
    Front_Range_Pro
    Front_Range_Pro EEF Brand Ambassador
    Vail, Colorado
    2022 Lunar Rock TRD Pro
    Got some stuff finally:
    • prototype UpTop Overland Zulu roof rack
      • 40” BD S8 light bar
      • R4T rock lights
    • 17x8.5” Method 305s with custom center caps and 0 offset
      • BFG K02 315/70R17
    • Usual Toyota stuff
      • Black TRD Pro tailgate lettering (to go with the red from the silver/red)
      • Console safe
      • Tonneau
      • Bed mat
      • Predator tubes
    • Xpel Stealth wrap
    already have more stuff coming in:
    • UpTop AFS mid-height rack
    • Retrax cover
    • Decked cargo glide
    • CBI covert front bumper
    • Warn 10k winch
    • BD 20” S8 light bar
    • BD S2 fog light replacements
    • BD XL80 ditch lights
    • SwitchPro
    • More
    ytank1, DarthTRDPro, =JSG= and 6 others like this.
  22. Oct 17, 2022 at 2:25 PM
    #262
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Hey @Front_Range_Pro, The truck is coming out nice. Once you have everything for it on, you have to share some pictures.
    Best,
    Brandon
  23. Oct 17, 2022 at 4:29 PM
    #263
    Front_Range_Pro
    Vail, Colorado
    Most definitely! :cool:
    =JSG= and Baja Designs[QUOTED] like this.
  24. Oct 29, 2022 at 8:21 AM
    #264
    Lunagas11
    Lunagas11 New Member
    TX
    22 LunarRock TRD PRO
    TRD running boards TRD tonneau cover 35" BFG AT K/O2
    Little late to the party but anyways: TRD running boards, Toyota tonneau cover, spray in bed liner, bed extender, console safe, ceramic coating, ceramic tint, pedal commander, and 35" BFG AT K/O2
    cartage1, ytank1, Yaboy and 6 others like this.
  25. Nov 6, 2022 at 7:06 AM
    #265
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Keep ‘em coming
  26. Nov 6, 2022 at 9:45 AM
    #266
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    are the TRD Pros coming with the all weather floor mats now?
    I love my 2021 factory TRD floor mats. New some early adopters didn’t even get floor mats with their trucks? Which is insane?
    zonehenge likes this.
  27. Nov 7, 2022 at 3:20 PM
    #267
    nobaddays
    nobaddays New Member
    Tyler
    2023 Black Tundra TRD Pro
    Full front PPF, Tint, Go Rhino boards, Retrax, 35's, Rekgen Flaps
    Mine came with all weather mats. 3M used my truck to make the full hood template for their clear bra, so if yours doesnt come out right, dont blame me... Just got my tint and Tires & boards done. 20% tint up front and 285/75 Falken Wildpeaks to fill up the wheel wells a bit more and RB20 boards. Retrax pro should be here tomorrow, then I'll be done for a minute or two.
    cartage1, ytank1, JTE.VA and 4 others like this.
  28. Nov 7, 2022 at 4:38 PM
    #268
    zonehenge
    Pete
    Western Mass
    Mine came with the mats, and it wasn't an "option"
    Minarets[QUOTED] likes this.
  29. Nov 7, 2022 at 4:56 PM
    #269
    Minarets
    Minarets New Member
    Nashville
    2021 TRD PRO
    Thank you.
  30. Nov 9, 2022 at 9:19 AM
    #270
    SolarOctane22
    SolarOctane22 New Member
    Tony
    Boise
    2020 Tundra TRD Pro - AG
    Westcott Fox TRD pro lift, 1.5"/1" rear blocks, Icon Rebounds, Toyo 35", TRD Intake w/SABM
    I had a range of 6 miles showing and when I fueled up last week, I put 27 gallons into the tank. So I think a range of an additional 40 miles at a minimum, past 0 on the display.
