22’ TRD PRO mods? Let’s see
Discussion in '3rd Gen Tundras (2022+)' started by TobyKai, Jul 30, 2022.
  1. Nov 9, 2022 at 11:36 AM
    #271
    claytron8000
    claytron8000 New Member
    Clay
    2022 White Tundra Limited TRD Hybrid (hopefully)
    My TRD Pro mod would be finding out when it will actually arrive.
    TRDx2 and ryanwgregg like this.
  2. Nov 10, 2022 at 4:11 PM
    #272
    M11s n B&T’s
    M11s n B&T’s New Member
    2022 Tundra TRD Pro
    They could be like aircraft, usable fuel vs actual fuel capacity.
  3. Nov 12, 2022 at 11:29 AM
    #273
    nobaddays
    nobaddays New Member
    Tyler
    2023 Black Tundra TRD Pro
    Full front PPF, Tint, Go Rhino boards, Retrax, 35's, Rekgen Flaps
    Painted the grey trd hood emblems to match. Turned out decent. Might do the same on the grille one of these days. Also added my retrax one xr cover and used the Carista to turn the exhaust sound and seat belt alarm off.
    =JSG=, iiawah808 and 509Yota like this.
  4. Nov 13, 2022 at 4:17 PM
    #274
    509Yota
    509Yota New Member
    23 TRD Pro MGM
    Where did you get a Carista for the 3rd gen or did you use the 2nd Gen version?
  5. Nov 13, 2022 at 7:09 PM
    #275
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    2nd gen works fine for 3rd
    nobaddays and 509Yota[QUOTED] like this.
  6. Nov 14, 2022 at 12:43 PM
    #276
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Put on the AFE Tow Hooks. Think the colour match of the tow hooks and sway bars looks good and they look low enough to be useful some of the time. I know they're not as good as full on bumper tow hook but I didn't feel comfortable cutting up my bumper for one of the CBI Covert bumper just yet. I've also got tint, PPF, ceramic coat, Retrax XR cover, Bed Step put on. I've got a screen protector sitting in the house as well as Yakima bars for the tonneau cover so I can mount my ski box over the bed.
    PXL_20221031_024413309.jpg PXL_20221111_231318940.jpg PXL_20221111_231259130.jpg
    RatPanda, Leif84, osu1978 and 6 others like this.
  7. Nov 19, 2022 at 1:05 PM
    #277
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    Can someone with a Westcott lifted Pro take front and rear measurements for me? Center of wheel to bottom of fender flare? My front end is higher than the rear on my truck after the install. Trying to figure out why.
  8. Nov 20, 2022 at 7:36 AM
    #278
    osu1978
    osu1978 New Member
    Not sure if this applies to the tundra bushing (pretty sure it would) but on my other car if you fully tighten the control arms while the wheels are off the ground it affects height and can lead to premature bushing wear due to the bushing twisting/binding once at ride height.
    Edit: Here I found a video for you: https://www.youtube.com/watch?v=-QczV_6v42A
    Tundrastruck91 likes this.
  9. Nov 20, 2022 at 3:58 PM
    #279
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    I definitely tightened up in the air. I just loosened up the LCA’s while it was on the ground and I didn’t see any movement in the bushings. Still the same ride height. I’m 7/8” higher in the front for some reason. I’m getting an alignment tomorrow but I don’t think that’ll change it that much.
  10. Nov 21, 2022 at 4:45 PM
    #280
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    So my Westcott lift is installed. I’m 7/8” higher in the front. Maybe it’ll settle in. Apparently that’s within spec for the lift after speaking with tech support. Not sure what everyone is seeing.
    I also installed 295/70-18 Nitto Recons. They really look great with the lift.
    Truck definitely drives different now. A lot more wind noise on the highway and I can feel the heavier tires when driving and going slow. The battery alone doesn’t move the truck as easily anymore. I also feel a light vibration from the rear when going 20-30mph. Not sure if a rear tire might be out of balance or if it’s the more aggressive tread.
    Overall the truck looks a lot much better, but at a slight cost.
    RickyBobbysTundra and ryanwgregg like this.
  11. Nov 23, 2022 at 2:01 PM
    #281
    sirlinus
    sirlinus New Member
    Just installed 35x12.5 KO2s. No lift and almost no rubbing ... maybe just a slight touch to a front mudflap at full lock although I'm not sure. Might try and pin back the front mudflaps a little if I can figure out a way to do it. Looks so much better but manners aren't quite as smooth as with the extra-soft OEM Wildpeaks. Going to run it this way for a while before deciding whether to install a Westscott. Have a Carista on order to decide if I want to cut the the engine sound and turn off the frantic seat belt warning
    osu1978, Descend, =JSG= and 5 others like this.
  12. Nov 23, 2022 at 2:13 PM
    #282
    Supertech1
    Supertech1 New Member
    Nice truck. I’ve got a Carista, and no truck. Waiting on MGM Pro. First thing I’ll do is turn off the engine noise, then the annoying seatbelt chime.
    sirlinus likes this.
  13. Nov 24, 2022 at 11:58 AM
    #283
    TK421
    TK421 New Member
    Ethan
    2022 Tundra TRD Pro
    Go Rhino RB20s
    Can someone with a Pro with 35"s and Westcott lift measure the height of the bottom of their receiver hitch? I am planning to switch to 35"s + lift when the factory rubber wears out but I am going to order a weighsafe hitch before then. I don't want to order a drop that will be to short for my boat trailer based on my measurements now. Thanks in advance.
    Ethan
  14. Nov 24, 2022 at 1:44 PM
    #284
    DesmoDoe
    DesmoDoe New Member
    Canada
    22 SO TRD Pro
    Yakima rack and ski box put on over the weekend, here she is as clean as she'll get in the winter. I was back and forth on the height of bars but I'm pretty happy with where it all ended up. The box hangs over the back about 6 or so inches (which I expected) and helps me accommodate my longest skis without having to go diagonal in the bed.
    excelw, ytank1, Tibetan Nomad and 2 others like this.
  15. Nov 25, 2022 at 8:54 AM
    #285
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    Finally took a few pictures…
    A94B1118-F1E4-4D78-87F2-78A111A2D1EE.jpg AAFD1DEC-7896-4346-B3C2-A3726AA4C19C.jpg
    ytank1, YF19EX, osu1978 and 3 others like this.
  16. Nov 25, 2022 at 9:03 AM
    #286
    iiawah808
    iiawah808 New Member
    Oahu, HI
    2022 iForce Tundra Limited TRD Offroad
    Currently Searching....
    White is gorgeous.
  17. Dec 2, 2022 at 8:32 AM
    #287
    kilocharlie106
    kilocharlie106 mmmm Bourbon
    TRD Pro in LR
    How are you liking the Westcott lift and bigger tires?
    Has anyone else had issues with tire wear on outer edge due to the camber inward of the front tires? Toyota spec'd alignment
    ryanwgregg likes this.
  18. Dec 3, 2022 at 9:15 AM
    #288
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    The look with the bigger tires and lift is so much better. You can definitely feel the heavier tires when driving and I got S rated Nitto Recon’s which are only 52lbs too. I’m not happy with the Westcott lift since I’m sitting high in the front. When I called to ask about it they said it was normal. Not sure I would have purchased it if I knew this was a possibility in advance. My tires now look like they’re sitting more flat than than the stock tires did. You can fix that when you get an alignment.
    RickyBobbysTundra likes this.
  19. Dec 3, 2022 at 10:23 AM
    #289
    Navy Jumper
    Navy Jumper Airborne Paratrooper
    2023 TRD PRO
    Is that the Front ONLY lift kit?
  20. Dec 3, 2022 at 2:36 PM
    #290
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    Full kit. Front and rear
  21. Dec 3, 2022 at 3:19 PM
    #291
    Navy Jumper
    2023 TRD PRO
    Interesting. Maybe the suspension will settle after a week or two.
  22. Dec 7, 2022 at 10:24 AM
    #292
    Budge
    Budge New Member
    2021 MGM Tundra TRD Sport
    Your truck looks sweet. Can you post a couple of more exterior pictures? I am trying to decided if I will trade my 2021 TRD Sport (MGM) for a 2023 Pro in MGM to be delivered in the spring?
    Thanks
  23. Dec 7, 2022 at 10:30 AM
    #293
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Has anyone had experience removing the tailgate TRD Pro decal? Is it as difficult as the other badges/decals? I have a Solar Octane Pro coming in January and it has the silver/red decal. Not digging the option, I would rather have black. Thanks.
  24. Dec 7, 2022 at 12:26 PM
    #294
    MDesi
    MDesi New Member
    Matthew
    22 TRD Pro
    It’s a sticker… use a heat gun and plastic razor blade. It won’t be hard to get off
  25. Dec 7, 2022 at 1:08 PM
    #295
    TWade
    TWade New Member
    Tanner
    Ya, I read that about the other decals, I just wasn't sure since it's recessed how hard that would be. Thanks for the reply. I'll just have to wait and see.
  26. Dec 7, 2022 at 2:23 PM
    #296
    Lunagas11
    Lunagas11 New Member
    TX
    22 LunarRock TRD PRO
    TRD running boards TRD tonneau cover 35" BFG AT K/O2
    Mine had the red and grey TRD decals too and I didn’t care for them either. So I just asked the dealership to take them off before I took delivery.
  27. Dec 7, 2022 at 2:32 PM
    #297
    TWade
    TWade New Member
    Tanner
    That is awesome information. Thanks. I will try that before I do it myself.
  28. Dec 11, 2022 at 8:01 PM
    #298
    2020Platinum
    2020Platinum www.youtube.com/NitroZ18Fishing
    Patrick
    Northeast PA
    2022 TRD Pro (Lunar Rock)
    A lot. See my channel for all installs/mods!
    CBI Covert bumper paired with Gear America Uber shackles, freakin love it!...I'll be running the Warn VR Evo 12-S as well, looks killer on the Pro!
    RatPanda, ytank1, DarthTRDPro and 8 others like this.
  29. Jan 7, 2023 at 4:37 PM
    #299
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    How's cover been holding up? Curious if I should snag one
  30. Jan 8, 2023 at 2:04 AM
    #300
    RickyBobbysTundra
    Phoenix
    Notice a big mpg change with the tires?
