2105 Tundra TRD ECU Issues?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pckroid, May 12, 2019.
  1. May 12, 2019 at 4:15 PM
    Pckroid
    Pckroid [OP] New Member
    2015 Tundra TRD
    I have this 2015 Tundra and it sat for a month or so and wasn't run much over the winter here in PA. Once I started it, the check engine, traction control and 4L & 4H were flashing. It runs fine, except you cannot shift into 4 wheel. I reset the ECU, checked fuses and found nothing. Any ideas what my problem might be? Bought this as a second owner, never had any issues with it for well over a year and has only 42,000 miles on it.
  2. May 12, 2019 at 5:08 PM
    Blueknights75
    Ron
    Clayton, NC
    Welcome from NC!
  3. May 15, 2019 at 9:35 AM
    Pckroid
    2015 Tundra TRD
    Ii was out of town and finally got to take a good look at my Tundra. Yes, it does sit outside and I have had issues with critters before. Today I had it up on ramps and really looked. I did find a wire off at a plug that goes into the module near the gas tank. It was the red wire. I cannot determine if it was critters or not so I posted a picture. But the story is interesting. After repairing, the flashing 4L & 4H lights went off but I still had the check engine and traction control. I reset the ECU again, no help. I decided to drive it some and see if that makes any difference. Yes, the traction control went off and now I only have the check engine light. Everything is working as it should. I am in the process of doing a battery disconnect reset right now and see if that makes a difference. I'll be away for a few days but will report back on my findings and the inevitable solution. Thanks to all.
    Black Wolf and NewImprovedRon like this.
  4. May 16, 2019 at 11:31 AM
    Pckroid
    2015 Tundra TRD
    I went to Autozone and had the codes read. P0453 evporative emission system pressure sensor/switch high input. I am researching this today.
    Black Wolf likes this.
  5. May 16, 2019 at 11:40 AM
    Do you always top of your tank when filling up? If so....you shouldn't. Can cause evap system issues.
    NewImprovedRon likes this.
