21 TRD PRO, suspension upgrade
Discussion in 'Suspension' started by muskylounge, Aug 16, 2023.
  1. Aug 16, 2023 at 6:38 PM
    muskylounge
    muskylounge [OP] New Member
    Jeff
    2021 Tundra TRD PRO
    Hello everyone. I am newer Tundra owner. So far I love it. I bought it mainly to be able to pull a 5,000 lbs boat when needed. It does amazing job and has plenty of power.
    I am planning for two upgrades. First one is pretty straight forward as I want a big brake kit. I feel without a boat it probably needs a little better stopping power. The trailer has surge brakes and I cant really tell much of a difference between towing or not when it comes to stopping power. I am looking at this upgrade although it seems rather pricey.
    https://sdhqoffroad.com/collections...rbrake-stage-2-big-brake-kit-red-16-21-tundra
    Second upgrade I am not really sure where to begin. I am hoping someone here has done something similar. When trailering the rear end does squat a little. Depending on any additional payload. Example:New Rig.jpg a long fishing trip to North woods. Has anyone had success with something like coil over shocks? Is there any other possibilities?
    I will include one pict of boat hooked up, keep in mind this pict is without all the extra payload I bring with me on longer trips. I trailer-ed it 10 hours north to Minnesota full load and had no issues. Just seeing if I can eliminate some of the squatting.
    Thanks in advance
  2. Aug 16, 2023 at 7:02 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Take a look at this...
    https://activesuspension.com/products/toyota-tundra-1999-2020-hd
    Quite a few members have installed and really like the set up. If you go to the search bar and type in 'roadmaster' you should be able to find several builds/reviews with it...
    here's one on 21 Pro...
    Roadmaster Active Suspension
    Good luck in finding what works for you and welcome to the forum!!!
  3. Aug 17, 2023 at 3:35 AM
    Eaganite
    Eaganite New Member
    Gary
    Eagan, Minnesota
    2020 Limited TRD
    I added black SumoSprings to my truck, simple, inexpensive, and efective. I'm happy with them, and would buy again.
  4. Aug 17, 2023 at 8:48 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    I run the active suspension, excellent product that delivers. I have the HD version, set it with a quarter which is in between the white and black setting disks. Gave an inch of lift in the rear. Compliment the ProTruck suspension setup I have, which lifted the front 2 inches. So basically I am sitting like a TRD Pro, but instead of level I have about an inch of rake.
    I tow quite a bit and the setup I have is excellent, especially for the $. Definite upgrade over stock.
  5. Aug 17, 2023 at 9:04 AM
    frichco228
    Also, you can gain a lot by using cryo rotors and good pads. No real need for the big brake kit.
