20x12 with 35x12.50 on 3" lift
Discussion in 'Wheels & Tires' started by Asutton, Oct 7, 2016.
  1. Oct 7, 2016 at 9:21 PM
    Asutton
    Asutton [OP] New Member
    Andrew
    2008 Tundra Limited
    3" level in the front
    Hey guys,
    I want to put 20x12 rims on my truck with 35x12.50" tires on a 3" leveling kit. Has anyone done this?
  2. Oct 7, 2016 at 9:40 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Depends on your offset.
  3. Oct 8, 2016 at 7:10 AM
    Asutton
    Andrew
    2008 Tundra Limited
    I don't know what offset I would want. I would want deep dish rims.
  4. Oct 8, 2016 at 8:30 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I don't know of many shops that would put 12.50 tires on a 12" rim. Not just that but most 12" rims only come with 0 or -44 offset. You'd need to do trimming either way.
  5. Oct 9, 2016 at 3:15 PM
    Asutton
    Andrew
    2008 Tundra Limited
    Thank you for your help man! I want to stick with 35s. I'm not sure if they fit being that wide.
  6. Oct 9, 2016 at 9:27 PM
    joeguam
    joeguam New Member
    JOE
    2015 Toyota Tundra SR5
    Pro Comp 6 Inch Stage II Lift Kit with Icon 2.5 coil overs and piggyback rear shocks, SPC Upper Control Arms, Atlas 6” Leaf Springs, Coach Builder Steering kit, Coach Builder +3 Shackles, BDS Recoil Traction Bars, Amp Research steps, Fuel Nutz two piece 20x12-44 offset wrapped with 38” Toyo MT tires, LineX Bed Liner, Viper 5706V Alarm and Remote Start, Pioneer 4200, JLAudio Amps, JL Audio Subs. Nitro Gear 5.29 and Auburn LSD
    Whats your BS? I have 20x12 -44 with a true 35" tire, same Stage II 6" Pro Comp lift. I rub the bumper liner extension cover at full lock reversing.
  7. Oct 9, 2016 at 10:23 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    BS = Back Spacing
  8. Oct 9, 2016 at 10:24 PM
    csuviper
    Broomfield, CO
    Think it was already stated at -44
  9. Oct 10, 2016 at 7:40 AM
    joeguam
    joeguam New Member
    JOE
    No point intended but thought I may learn a set up that I can do to elevate the rub without cutting anything. I might have thought that your backspace might the ticket. Backspace is different than offset from my understanding. Even when I added preload to the coilover collar and increase the lift by 1 1/2 I still rub. Even then the ride was really stiff so I choose the lesser of evil.
  10. Oct 10, 2016 at 3:23 PM
    joeguam
    joeguam New Member
    JOE
    LOL I saw the original post through email.
