2025 Tundra Engine is down!
Discussion in '3rd Gen Tundras (2022+)' started by Tarikah, Jun 26, 2025.
Thread Status:
Not open for further replies.
  1. Jul 16, 2025 at 7:22 AM
    #781
    Laluu
    Laluu New Member
    I think in that K you’re getting involved with the dealer a lot and dealers are not the brand so they probably will not be willing to lose anything just my two cents I guess
  2. Jul 16, 2025 at 7:22 AM
    #782
    sudobash
    sudobash New Member
    COVID. It will forever be their COVID vehicle. Every manufacturer has one by now.
  3. Jul 16, 2025 at 7:32 AM
    #783
    Laluu
    Laluu New Member
    But why do you think that they haven’t fixed it yet? It’s been. going on five years, you don’t think they would’ve updated the engine by now Or at least made a good fix for it you know
  4. Jul 16, 2025 at 7:33 AM
    #784
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Huh, maybe this IS an airport
  5. Jul 16, 2025 at 7:34 AM
    #785
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    Does anyone know what Toyota considers an acceptable failure rate on an engine? Are they good with a 1% failure rate...2% does anyone know?
  6. Jul 16, 2025 at 7:35 AM
    #786
    sudobash
    sudobash New Member
    Not this.
    NMTundra likes this.
  7. Jul 16, 2025 at 7:36 AM
    #787
    LionsFan20
    Josh
    24 Tundra
    Is that not a good question to ask lol??? Sorry
    sudobash and kirkb like this.
  8. Jul 16, 2025 at 7:59 AM
    #788
    sudobash
    sudobash New Member
    It's a great question. Even with the smallish percentage that we know about, this is more than Toyota ever wanted. Think about the T24A and it failing in the Land Cruiser & Tacoma.
    WNY PAT likes this.
  9. Jul 16, 2025 at 8:05 AM
    #789
    LionsFan20
    Josh
    24 Tundra
    Ideally they want to keep warranty cost down...
    sudobash likes this.
  10. Jul 16, 2025 at 8:58 AM
    #790
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I saw an article probably a year ago giving engine failure stats for most makers. Toyota was in the top tier with an average of 200-300 failures in 100k engines. That was across all engines produced. The worst makers were about 2x.
    Premature engine failures are actually pretty rare regardless of maker these days. Not the old GM aluminum engine days in the 70s when it was 90%>.
    So 1% failure would be below average for any maker and substantially worse for Toyota.
    I think the recent VC engines recall for Nissan and 2.7 L for Ford are similiar with 1% failures to date. But they recalled all engines in a run.
    But if a company recalls that many vehicles their analysis yields they found a real problem they can't solve easier. it's not just being nice
    WNY PAT, woods, 75tranzam and 2 others like this.
  11. Jul 16, 2025 at 9:41 AM
    #791
    nkyrental
    nkyrental New Member
    Kevin
    2022 Chevrolet Silverado 3.0 Duramax
    Toyota has agreed to replace 100,000 engines. I wonder how many have fully failed prior to getting the replacement, what the percentage of field failures is for this incident?
  12. Jul 16, 2025 at 9:56 AM
    #792
    LionsFan20
    Josh
    24 Tundra
    I can only speak for what I have seen and of the recall motors we have done, only 3 or 4 were vehicle off road(dead truck) the other 70 were fine
    Tundrastruck91 and BoulderGT3 like this.
  13. Jul 16, 2025 at 10:18 AM
    #793
    badass03taco
    badass03taco New Member
    2005 Limited Double Cab 4wd
    The new new trucks with the fancy bearings are the same as the crate engines. And yea they have been failing.
    WNY PAT likes this.
  14. Jul 16, 2025 at 10:31 AM
    #794
    badass03taco
    I fully suspect the owners are the beta testers and Toyota is constantly changing things and watching the outcomes along the way to decide what’s the best strategy to keep moving forward
    I truly suspect some of these are also getting ecu reflash updates and Toyota is likely testing different values trims and what not. I still don’t think the engine is the issue, if I’m smart enough to figure it out the folks at Toyota certainly are. I think they’ve created an ecu tune that is so lean at part throttle and even in boost to meet the emissions standards which generates immense cylinder temps and pressure which cause an ever increasing Likelihood of LSPI (low speed pre ignition) and / or detonation. The reason they can’t come out and say that is because they can’t openly say
    “Our tune is too lean”
    The first thing that will happen is a Volkswagen fiasco all over again. EPA starts jumping down their throat and forced Toyota to park a million trucks in the Mojave desert like Volkswagen. Toyota is replacing engines that fail from what appears to be poor tuning and knock which takes the rod and crank bearings out. My thoughts are they are keeping silent about any tuning issues due to the amount of money it costs for a buy back of a half million trucks rather than just 100,000 engines. The weight of the EPA on their back about not being able to meet emissions would be monumental. So replacing engines that fail may be the cheaper way out.
    cue the guy who said about GM earlier in thread
    “If the lawsuits cost $1,000,000 million but the fix costs $1,000,001 then GM will see you in court.
    if these engine replacements cost $1.4b but trying to change the tuning to “fix” the real issue (detonation) gets them in hot water with the EPA and clean air act and emissions czars, they may be swallowing the engine replacements cause it’s cheaper.
    Laluu[QUOTED] and kirkb like this.
  15. Jul 16, 2025 at 10:59 AM
    #795
    Reciprocal
    Reciprocal New Member
    2025 Tundra 4x4 Limited Crew Cab 5.5
    I agree with the second part.
    kirkb likes this.
Thread Status:
