2025 Tundra Engine is down!
Discussion in '3rd Gen Tundras (2022+)' started by Tarikah, Jun 26, 2025.
  1. Jul 14, 2025 at 5:06 PM
    #691
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    Or, the stacked tolerance evaluation did not cover the manufacturing flow extremes.
    PermaFrostTRD[QUOTED] likes this.
  2. Jul 14, 2025 at 5:51 PM
    #692
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    No, We know motors are being replaced because of a bearing failure. The symptom is a knocking motor lol
  3. Jul 14, 2025 at 5:58 PM
    #693
    PermaFrostTRD
    Northern NY
    Wrong again. Plenty of failures that happened without “knocking”.
  4. Jul 14, 2025 at 6:09 PM
    #694
    Breathing Borla
    Northern Illinois
    Good lord boys, do we even know what we are arguing about ? Lol
    chrisgibbs707 likes this.
  5. Jul 14, 2025 at 6:15 PM
    #695
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
  6. Jul 14, 2025 at 6:34 PM
    #696
    LionsFan20
    Josh
    24 Tundra
    Well the sky isn’t technically blue either….the motors knock, or seize from a bearing failure. The symptom is the knocking or locked up….is that better.
    sudobash likes this.
  7. Jul 14, 2025 at 6:37 PM
    #697
    sudobash
    sudobash New Member
    Are they the Teenage Mutant Teenage kind?
    GODZILLA and AZBoatHauler like this.
  8. Jul 14, 2025 at 6:49 PM
    #698
    AZBoatHauler
    So.Arizona
  9. Jul 14, 2025 at 6:52 PM
    #699
    PermaFrostTRD
    Northern NY
    Toyota’s ambiguity continues to be justified
  10. Jul 14, 2025 at 6:57 PM
    #700
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    That's the only kind
    GODZILLA likes this.
  11. Jul 14, 2025 at 7:47 PM
    #701
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    Stacked tolerances is something I’ve been dealing with consistently as an engineer as we push the envelope for efficiency. I don’t think this is something that is well taught in engineering anymore, if it at all. I wouldn’t be surprised if that is it.
  12. Jul 14, 2025 at 9:21 PM
    #702
    chrisgibbs707
    chrisgibbs707 New Member
    Socal
    2022 Tundra SR5 4x4
    Relatively recent mechanical engineering grad here. University of Colorado didn’t really touch on tolerance stackups. Only a tiny bit in my senior design class. It’s much more complex than it seems when you have so many components working together. I remember thinking “oh well you just min max the tolerances” but I didn’t consider pin/hole clearances until I had to do a stack up at work. Now, add in rotating assemblies with harmonic frequencies / non-straightness across bearings… that’s when it probably becomes FEA time using different high/low tolerances… but if you make one wrong assumption, you could be missing something huge. Add in time constraints, lack of resources during covid, confidence/reliability calculations, and of course money. There could’ve been an assumption/calculation made long ago that hasn’t been questioned yet.
  13. Jul 15, 2025 at 12:07 AM
    #703
    C150 driver
    C150 driver New Member
    2024 Tundra TRD OR
    Lol, what are you talking about? That wouldn’t solve a main bearing failure due to contamination. You would see an upper rod bearing failure and piston/cylinder damage if the actual tune was the problem, multiple people have posted pics of their spark plugs at the 40k interval change and they look perfect. You’d see damaged spark plugs if the tune was an issue. Stop peddling nonsense. Also multiple videos showing the engine swap being done on YouTube, you wouldn’t need to swap the ecu, just upload new software. Modern engines have knock sensors, the ecu would pull timing on its own if it sensed any pinging or misfire. Modern engines will literally go into a limp mode annd self limit if any misfire is detected for a certain period. This was demonstrated when people installed the TRD intakes without the performance tune. The truck went into limp mode and wouldn’t make power, every word of what you posted is just flat wrong.
