2025 Tundra Engine is down!
Discussion in '3rd Gen Tundras (2022+)' started by Tarikah, Jun 26, 2025.
Thread Status:
Not open for further replies.
  1. Jul 8, 2025 at 2:55 PM
    #331
    Bulldog6
    Bulldog6 New Member
    ‘25 Lunar Limited
    A short block is the block, crankshaft, pistons, rods, assembled. That is what is delivered.
    It must be obvious at lease a short block is needed. You don’t have to do a complete tear down to come to that conclusion.
  2. Jul 8, 2025 at 4:03 PM
    #332
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    I’m assuming this is their plan… Although no one can answer my question about if it was shavings in the oil, are they proactively replacing the turbos/oil lines/etc or do we just wait until those fail… Apparently that answer may come from the other rep
  3. Jul 8, 2025 at 4:04 PM
    #333
    Redoak
    Redoak New Member
    Dave
    2006 Toyota Tundra DC, Limited 4x4, with LSD
    none
    A short block is a block assembled with crank, bearings, pistons etc in it; to which they will put on his old heads, (now a long block) intake, oil pan, etc.
  4. Jul 8, 2025 at 4:28 PM
    #334
    sudobash
    sudobash New Member
    Previous, similar repairs allow for parts to be ordered based on the symptom and interfacing with TAS, FTS, etc.
    Bulldog6 likes this.
  5. Jul 8, 2025 at 9:06 PM
    #335
    MAC25Tundra
    MAC25Tundra New Member
    2025 Limited Crew Max 4x4
    Appreciate your continued updates. Hoping the best for you.
    Doofus, Mallcrl[QUOTED] and BlackNBlu like this.
  6. Jul 8, 2025 at 9:09 PM
    #336
    Breathing Borla
    AZ
    Hey Toyota
    Get your fuckin shit together guys, enough of this bs. It’s been years , figure this shit out
    ngoshawk, walleyes, kirkb and 10 others like this.
  7. Jul 8, 2025 at 9:31 PM
    #337
    Reciprocal
    Reciprocal New Member
    2025 Tundra 4x4 Limited Crew Cab 5.5
    "certain machining debris may not have been cleared from the engine when it was produced." Doesn't say "in the oil," could be machining debris pinched between crankshaft bearing and cradle. Could be something else. I wouldn't assume anything. Toyota put out the bulletin and is paying for the fix, new engine.
    RCMN-24V381-0422.pdf
  8. Jul 9, 2025 at 4:00 AM
    #338
    sudobash
    sudobash New Member
    And yet, said debris is in the oil because said debris was discovered in the oiling passages of a brand new short block.
    WNY PAT and Mallcrl like this.
  9. Jul 9, 2025 at 5:38 AM
    #339
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Thanks for the continued updates.
    At what date is your lemon law applicable for this truck?
  10. Jul 9, 2025 at 5:47 AM
    #340
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    30 days in the shop, so 7/24
  11. Jul 9, 2025 at 5:53 AM
    #341
    OLV1071571
    OLV1071571 New Member
    2024 Silver Limited CrewMax 5.5ft
    Perhaps I missed it but do you have the extended warranty as well? I only ask out of curiosity if having an extended warranty (even if it died within the standard warranty) rates you to have a long block. I think the answer is no but perhaps someone can confirm.
  12. Jul 9, 2025 at 6:05 AM
    #342
    Matt2015Tundra
    2023 1794 CrewMax
    I don't think the extended warranty makes any difference on the scope of repairs.
    Toyotas standard response for engine failures that fall outside of the recall has been only short block replacements. Which I personally think is borderline criminal. How can their warrantied repairs differ from the recall repairs for the exact same failure?
  13. Jul 9, 2025 at 6:09 AM
    #343
    Toyota does not have long blocks to repair non-recall vehicles as I understand it. Every long block they produce is for the recall. If you are not in the recall, you do not get one of the long blocks being produced for the recall vehicles. Typically Toyota does not produce long blocks for repairs for any of their models, they produce short blocks, and the additional repair parts to be used as needed. As best I understand it.
    woods, 75tranzam and Tundrastruck91 like this.
  14. Jul 9, 2025 at 6:09 AM
    #344
    Matt2015Tundra
    2023 1794 CrewMax
    Thanks. At this point I think I would be hoping for a lemon law case. Or, for Toyota to buy back your truck and get you into another one.
    I would not be comfortable with a short block repair.
  15. Jul 9, 2025 at 6:17 AM
    #345
    sudobash
    sudobash New Member
    Yes they do.
    It's called a "Partial Engine Assembly" and it has been used in multiple local repairs. It does not include all the things that the Recall Engine Assembly does. Think of it as a block and heads and everything needs to join those things together. Electronics not included.
    19000-F4030 - Partial Engine Assembly (Non-Hybrid)
    - Original was 19000-F4020 and was superseded in January 2024)
    19000-F4040 - Partial Engine Assembly (Hybrid, including Sequoia)
    - Original was 19000-F4010 and was superseded in January 2024)
    kirkb, Mallcrl, woods and 2 others like this.
  16. Jul 9, 2025 at 6:22 AM
    #346
    Then I stand corrected. When do they use the long block vs the short block that literally everyone on here gets outside of the recall?
    woods likes this.
  17. Jul 9, 2025 at 6:28 AM
    #347
    sudobash
    sudobash New Member
    That is completely up to Toyota Corporate, but they have been used.
    They have for sure been used for the failures that have happened in Toyota's own Corporate Fleet. All repairs done at Toyota of Plano.
    Mallcrl and Tundrastruck91 like this.
  18. Jul 9, 2025 at 6:38 AM
    #348
    lapoolboy
    lapoolboy New Member
    "Speak softly and carry a big stick" a very wise man once said. It's all about what someone is willing to accept. Some folks will just let Toyota/dealer/etc. do whatever they want and as long as the vehicle runs and operates, they don't care what was done to it. Hell, some of these people don't ever even raise the hood on their own vehicle.
    woods and sudobash like this.
  19. Jul 9, 2025 at 7:17 AM
    #349
    LionsFan20
    LionsFan20 New Member
    Josh
    24 Tundra
    They also have some extras for those engines damage during shipping. Now some of those engines are lightly damage as maybe as simple as a new intake tube needed or maybe a bent oil cooler, but there are reports of damage engines bad enough for Toyota to send out another motor....
    kirkb and sudobash[QUOTED] like this.
  20. Jul 9, 2025 at 9:13 AM
    #350
    WNY PAT
    WNY PAT New Member
    Agree!
  21. Jul 9, 2025 at 9:14 AM
    #351
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    Definitely doesn’t alter the repair; extended warranty only comes into play after the initial is over.
    To answer your question, I don’t have the extended warranty, I figured I would consider it as I approach 36k miles (which will probably be the 24 month mark) on whether I’m keeping it or not. I had my last Tundra for ~16 months (almost 50k miles though)
    sudobash and OLV1071571[QUOTED] like this.
  22. Jul 9, 2025 at 9:23 AM
    #352
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    They very likely know the cause. And they have analyzed every solution option weighing cost vs reputation impact vs speed of making it a memory.
    It's always a speed, cost, quality triangle for any business decision. Toyo is no different.
    WNY PAT[QUOTED] likes this.
  23. Jul 9, 2025 at 9:52 AM
    #353
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    And they STILL won't tell you whether your engine spun a bearing or it was something else? That info should be easily accessible on a service write-up. I'd go straight to the service desk and ask for any write-ups attached to your VIN. Never heard of a dealer intentionally hiding this info from customers about their own vehicles.
  24. Jul 9, 2025 at 9:53 AM
    #354
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    My dealer called me and told me it was the bearing lol.
    Terndrerrr[QUOTED] likes this.
  25. Jul 9, 2025 at 10:25 AM
    #355
    Breathing Borla
    AZ
    we are past all that, just fix the fuckin problem Toyota.
    excelw, walleyes, hagrid and 4 others like this.
  26. Jul 9, 2025 at 11:41 AM
    #356
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    it usually takes over a day and a half dozen calls just to get them to answer the phone. Getting actual answers about anything from them is basically impossible.
    sudobash likes this.
  27. Jul 9, 2025 at 2:07 PM
    #357
    That was rather amazing. They just gave 'ol Dodge the big FU.
  28. Jul 9, 2025 at 2:22 PM
    #358
    JJcksn12
    JJcksn12 New Member
    Jay
    2025 MBM Limited TRD OR
    3” TRD Suspension Lift
    7300 on mile build date of 10/2024 and running like a champ.
    break in oil change at 1000
    and every 2500 since
    at 10000 I’m going to up to 5000 intervals.
  29. Jul 9, 2025 at 2:24 PM
    #359
    Brian422
    Brian422 New Member
    Birmingham, AL
    23 Limited 4x4
    I changed my oil every 4k ran flawlessly until one day out of no where. There are no signs when it fails more times than not from what ive seen. My truck has 18k on it.
    sudobash and JJcksn12[QUOTED] like this.
  30. Jul 9, 2025 at 2:52 PM
    #360
    JJcksn12
    JJcksn12 New Member
    Jay
    Ain’t that a SOB
    Tundrastruck91 and sudobash like this.
Thread Status:
