2025 Owners: any major/minor Tundra's issues so far?
Discussion in '3rd Gen Tundras (2022+)' started by Alphagreen, Jan 7, 2025.
  1. Apr 27, 2025 at 4:50 AM
    #91
    Tjbouwhu
    Tjbouwhu New Member
    I guess I am not sure, there is a ride select knob…normal, comfort, sport, sport+, “custom”. Nothing changed with any selection.
  2. Apr 27, 2025 at 5:09 AM
    #92
    Tjbouwhu
    Tjbouwhu New Member
    After the latest trip to another dealership, the service manager there said yeah the 2025 Tundras that come in with Bridgestone Duelers jerk all over the road on these groved highways. He actually said it was scary…
    So back to the Toyota Case Rep, terrible follow up and response BTW, starts reading me the vehicle warranty verbatim over the phone…where he was going with this is that I need to take this up with Bridgestone under the tire warranty. So if these vehicles with Bridgestone tires have this characteristic, what sense would it make for me to put another set of Bridgestone tires on it???
    I call BS, Toyota engineered and manufactured this truck, the vehicle in total (frame design, suspension design, suspension components, tires, etc.) are all part of the total ride package they supplied. Bridgestone Dueler tires are running on many different trucks on the road and I can’t imagine they are all twitching like this thing does on groved highways.
    ccalv likes this.
  3. Apr 28, 2025 at 12:34 PM
    #93
    23 Platinum
    23 Platinum 25 Platinum Off-road
    California
    25 Tundra Silver Platinum off-road
    I presume because of the massaging seat mechanism on my 25 platinum, it is hard and somewhat uncomfortable. My 23 Platinum's seat was cushy, soft and extremely comfortable. Bummer
  4. Apr 28, 2025 at 7:28 PM
    #94
    rp2000r
    rp2000r New Member
    Rented a 25 Hybrid limited and loved the truck. Only issue I noticed was the drivers seat back popped when moving around. Drove the truck 700 miles over a few days.
  5. Apr 29, 2025 at 7:13 AM
    #95
    Jeff25tundra
    Jeff25tundra New Member
    Jeff
    2025 Tundra SR5 blackout package
    2025 SR5 4x4 Purchased Feb 3, 2025. 10,940 miles as of this morning and the only issue I have had is rock pecks in the windshield. That is a driving on I 20 problem not Toyota.
  6. Jun 14, 2025 at 3:54 PM
    #96
    glpatton
    glpatton New Member
    Follow up on my bowed bed posted earlier. Received word they will be replacing the box. Awaiting final instructions from Toyota.
  7. Jun 15, 2025 at 6:26 AM
    #97
    Reubenski
    Reubenski New Member
    2025 Limited CM, TRD Off-road package, 3" lift
    Auto tailgate deteriorated to the point I have to manually help it open by pushing on it. It's basically broken.
  8. Jun 16, 2025 at 5:51 AM
    #98
    mysticbus
    mysticbus New Member
    2025 Tundra SR5 4x4
    I've had my 2025 SR5 4x4 for a couple month and about 2500 miles. I did an oil change with 5w-20 at 1000 miles, and thus far the truck has been perfect.
  9. Jun 18, 2025 at 7:16 AM
    #99
    Trdmikey8
    Trdmikey8 New Member
    I have my 25 tundra SR5 4x4 with 1000 miles about a month already. Did a initial oil change and the mechanic found some coolant leaks. I didn't notice any leaks on the driveway and the truck drove fine. Normal operating temperature. I took it to the dealer and the service said it was the timing cover gasket issue that wasn't seated properly. They will replace under warranty next week.
  10. Jun 30, 2025 at 9:46 AM
    #100
    JZ'06'25
    JZ'06'25 New Member
    2025 Limited with TRD package purchased in November 2024. Changed oil at 750 miles. Sent an oil sample to Blackstone labs. Test results were exactly what you would expect to see. Super clean oil, no contamination of metal debris. Now in June 2025 I have 4,000 miles - mostly freeway - and get 18mpg, and there are no issues.
  11. Jun 30, 2025 at 6:21 PM
    #101
    Mallcrl
    Mallcrl New Member
    Anand
    Maryland
    '25 Limited TRD-OR
    It's been posted in several other threads, but for posterity....
    2025 limited non hybrid, engine failure at 1270 miles/10 days, tomorrow evening will mark a week since it arrived at the dealer via tow truck with no timeline for repair at this point. Friday I was told they ordered a short block and was advised to call back on Monday to get an ETA on the parts, I called back today and was told to call back Wednesday or Thursday for an ETA as "it's too soon to know when the parts will arrive".
    I also started a case with Toyota's brand engagement center to fight for a long block instead of a short block given the horrific sounds it was making, should have an update on that in the next day or two. That was specifically prompted by a friend-of-a-friend who got Toyota to swap his Sequoia TRD Pro for a new one due to the time it spent in the shop awaiting parts (last year). I don't want a new truck, but I do want an entire new motor like the recall guys are getting
    Edit: Oh, and the pano roof cover rattles above the driver's head, but not enough that I'm going to ask an underpaid dealer tech to drop the headliner and figure out why
    kirkb likes this.
  12. Jul 31, 2025 at 3:53 PM
    #102
    ccalv
    ccalv New Member
    2025 Tundra Limited 4x4
    1.75” RC front level 1.25” RC rear spacer 285/65r20 Nitto Recon Grapplers
    Going through this now. After having many F150s and tired of rear end/transmission issues I’m pretty dissatisfied with this trucks suspension set up. Was also told it may be the “cheap” stock tires, but I planned on changing them anyway and leveling the truck and nothing changed. Tried different tire pressures and everything. Still feel every crease/dimple in the road. I’m looking into suspension now, may be starting with the rear and see where we end up.
  13. Jul 31, 2025 at 4:00 PM
    #103
    Breathing Borla
    AZ
    all that level kit crap does is make it worse, do you have load e?
  14. Jul 31, 2025 at 4:06 PM
    #104
    ccalv
    ccalv New Member
    Normally, I would agree on the level. But the truck rode 100% the same when it was stock. Yes load e, Nitto Recon Grapplers. I’ve read they’re a 10 ply with 12 ply sidewalls, so they’re expected to be rougher, but this isn’t right.
  15. Jul 31, 2025 at 4:12 PM
    #105
    Breathing Borla
    AZ
    I dont know man, spacer lift with load E, thats pretty much to two worst things you can do for ride quality.
    what it is, axle hop?
    try getting a few sandbags for the bed and see if that calms it down a bit for an experiment.
    I had to ride with sandbags in my 16 platinum since the roads were such shit in IL it would rattle my damn teeth loose.
    My 23 platinum is the best riding tundra I have ever had by far.
    Tundrastruck91 and ccalv[QUOTED] like this.
  16. Jul 31, 2025 at 4:18 PM
    #106
    ccalv
    ccalv New Member
    I’ve got about 200+/- pounds in the bed including the bed cover. I’m wondering if installing 1.25” on the rear has the rear shocks stretched maybe? Grasping at straws before I spend some money on suspension. Taking it back one more time to get them to roadforce balance the tires and maybe get an opinion after they ride in it.
  17. Jul 31, 2025 at 4:25 PM
    #107
    1862ltz
    1862ltz New Member
    Best riding TRUCK I've ever had!
  18. Jul 31, 2025 at 4:26 PM
    #108
    Breathing Borla
    AZ
    My ram was damn good too
  19. Jul 31, 2025 at 4:27 PM
    #109
    Breathing Borla
    AZ
    i hate to say this but I think you’ll neeed to go back to stock or go up significantly to a real suspension
    sticking a spacer in and then throwing load e tires on is a recipe for disaster imo
    ccalv[QUOTED] likes this.
  20. Jul 31, 2025 at 4:33 PM
    #110
    ccalv
    ccalv New Member
    Thanks for the talk! I guess I’ll be looking into some suspension upgrades. Any recommendations for a close to stock ride but keep the same 1.75” in the front and 1.25” in the rear? Doesn’t have to be exact.
  21. Jul 31, 2025 at 4:55 PM
    #111
    1862ltz
    1862ltz New Member
    I was between a ram and the tundra. We also had a GX460 and now GX550. They ride better, so maybe the tundra is the best riding pickup I've ever owned. But most trucks I would say I feel every bump in the road. It's how they make every bump feel that makes the difference.
  22. Jul 31, 2025 at 5:10 PM
    #112
    Breathing Borla
    AZ
    my tundra with AVS rides simply awesome, love it
  23. Jul 31, 2025 at 5:14 PM
    #113
    Breathing Borla
    AZ
    there are tons and tons of stuff on this site , but I would go with the 3” oem trd lift if it were me
  24. Jul 31, 2025 at 5:23 PM
    #114
    WindChillYeti75
    WindChillYeti75 New Member
    2025 WCP Limited TRD Off Road iForce Max
    High pitch wind noise from driver’s side mirror (which there’s currently a TSB for) and I had a slight rattle in my headliner when going over bumps. Dealer replicated both and replaced both! Now it’s super quiet! No complaints!
  25. Jul 31, 2025 at 6:20 PM
    #115
    jtweezy
    jtweezy New Member
    Jeffrey
    I have the factory 3" TRD lift and I love the way it rides. Would highly recommend unless you have a specific use case for your truck that requires a highly specialized suspension.
  26. Jul 31, 2025 at 6:25 PM
    #116
    Breathing Borla
    AZ
    @ccalv
    ccalv likes this.
  27. Jul 31, 2025 at 6:41 PM
    #117
    jtweezy
    jtweezy New Member
    Jeffrey
    My 2025 Limited TRD Off Road had to have the rear 3rd member assembly replaced. Got some flickering warning lights on the dash related to VSC and Traction Control. Dealership diagnosed it, ordered parts and replaced it. Took about a week to get the parts and a day to do the work, but the truck was drivable the whole time.
