2024 Tundra SR5 4x4 (35k Miles) Fluid Questions
Discussion in '3rd Gen Tundras (2022+)' started by okk3n, Sep 16, 2024.
  1. Sep 16, 2024 at 12:58 PM
    okk3n
    okk3n [OP] New Member
    Just purchased a 24 SR5 4x4 and I have put 1k miles on the truck (now at 35,080).
    I am wanting to change the transfer case, front/rear diff fluids and grease the driveshaft joints.
    I found the fluid amounts/types, but I was wondering what brands I should use besides obviously Toyota. Also, does anyone know the washer sizes and the pounds of torque to use for the bolts?
    Transfer: 2.17 qt. (ATF WS)
    Front Diff: 1.49qt (75w-85-GL-5)
    Rear Diff: 5.7qt (75w-85-GL-5)
    for the transfer case fluid should I use Valvoline Maxx Life Full Synthetic ATF and for the diffs should I use Red Line Synthetic Gear Oil GL-5 75W-85?
  2. Sep 16, 2024 at 1:59 PM
    okk3n
    Would Red Line Transmission Fluid D6 be good for the transfer case and Red Line Synthetic Gear Oil GL-5 75W-85 for the diffs?
  3. Sep 16, 2024 at 2:05 PM
    lapoolboy
    lapoolboy New Member
    If not OEM Toyota, I like Amsoil stuff.
  4. Sep 16, 2024 at 2:59 PM
    okk3n
    Thanks!
    I am correct right, that the 3rd gen’s use 75w85 for the diffs and ATF WS for transfer case? That’s what I understand from online. But on older tundras people say NO to ATF WS for transfer case https://www.tundras.com/threads/transfer-case-oil-atf-ws.82338/
  5. Sep 28, 2024 at 12:46 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
  6. Sep 28, 2024 at 4:47 PM
    22whatwedo
    The Open Road
    303Gen3 likes this.
