2024 Tundra purchase
Discussion in '3rd Gen Tundras (2022+)' started by puddin, Aug 25, 2023.
  1. Aug 26, 2023 at 2:42 PM
    Sixty9Four20
    Sixty9Four20 TRD is not a trim
    2023 TuRD Pro
    I didn’t spend the money to just swap out stuff.
    It is definitely marketed towards torque for towing....but a side effect is that the MPG WILL in some way improve. Stop and go is a huge fuel efficiency killer. Guess what the motor will do normally when you're stopped? Shuts off. Guess what happens when you lightly push the throttle...you enter prius mode until you push hard. You can remain slowly cruising up to speed in prius mode and I fucking love it. Obviously you can't do that if you're in los angeles or you'll be in a gunfight. Also when you're maintaining a speed without an incline or hard load, motor will shut off and any light throttle will be using battery. That's awesome.
    In whack ass washington state, for some reason vehicles above 6000LB don't have to pay RTA tax (busy I5 corridor tax). Guess what it says on the registration of my Turd Pro? 6010LB.
    This was a major suspicion for me when reading threads of people rolling into traffic about to get t-boned. It may seem that the tundra naturally expects some battery power to assist. I'm not an engineer though.
    TundraRyan, Kung and Kap1[QUOTED] like this.
  2. Aug 26, 2023 at 4:44 PM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    I just made a 40 mile trip to Bass pro and back. Trip average was 23.8 both ways.
    NutsVolts likes this.
  3. Aug 26, 2023 at 8:02 PM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    There is minor as in hardly noticeable, turbo boost lag then there is the random dead gas pedal issue. They are two different things. The dead pedal issue is random and only happened to a few members. It only happen to me once. It isn’t a hybrid vs non hybrid issue.
  4. Aug 26, 2023 at 10:19 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    Trust me, I've been at a dealer for various complaints about 6 times in the past year.
    They finally fixed the whistling noise from the driver window seal...
    Truck is normal.. It's just a 2022
  5. Aug 28, 2023 at 7:10 AM
    Tundraaa3
    Tundraaa3 New Member
    My SR5 has a 32 gallon tank.
  6. Aug 28, 2023 at 8:55 AM
    wmflyfisher
    wmflyfisher New Member
    Thank you sir. Can you see that by looking on the window sticker do you know?
  7. Aug 28, 2023 at 9:45 AM
    Breathing Borla
    Northern Illinois
    All platinums have 32 standard
  8. Aug 28, 2023 at 10:00 AM
    PERRY1060
    Perry
    Indiana
    I forgot that some SR5s have the 32 gallon tank. Maybe it is part of the convenience package option.
    Tundraaa3[QUOTED] likes this.
  9. Aug 28, 2023 at 10:07 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Any non-hybrid over 6k lb would be exempt as well. Crewmax with sunroof, LT tires, and a skid plate would do it.
  10. Aug 29, 2023 at 2:17 PM
    borla123
    borla123 The Pits
    Ontario
    18 Tundra TRD OR - '17 4Runner Torsen Full Time 4wd
    Driver Grip Handle Borla Dual, Line X, ESP Underseat
    My opinion.
    When the Hybrid came out I thought WTH there is no "Better Mileage" so whats the point. I have since come around and for the following reason. Engine Longevity. There is the most wear on take off. If I was looking to get a new Tundra and planned on keeping it long term past warranty. Hybrid. The battery components have long warranties and are I assume interchangeable for new ones ......unless battery tech changes so much (and it will) that the current config becomes obsolete. Will Toyota still make these parts if that happens ?
    and if it is a warranty buy, 3 year type of thing ownership then flip it - just get the one you prefer. It won't be for saving money on gas as others have said. When I test drove two non Hybrids - I found it to be a really heavy vehicle much heavier than the I.e. F150 truck, for the 3.4 liter without the turbos engaged.
    WesternDawg likes this.
  11. Sep 8, 2023 at 8:12 AM
    TundraRyan
    TundraRyan New Member
    2014 Crew Cab TSS
    Stock
    I'm in this same position. Looking at which 2024 or 2023 to get. You can still get great deals on 2023 models. Like there is a platinum 4x4 with long bed without hybrid they are selling for $63k. and they have a hybrid 4x4 they are selling for $67k. When you start looking at Limiteds to build out they are going to be that price or more. If I do a limited I would do a 2024 TRD not a 2023 because of all the paint matched body trim pieces. it just looks so much better. If you want 4x4 but don't need the niche features of the locking rear diff then I would say try to find you a 2023 platinum or SR5 loaded up. Dealers are making great deals right now on them.
    Are you going to lift the truck and what kind, if you want to do like a 3" the TRD package has the better front axles that you don't need to replace. If you want a small lift and a level, just get any truck. I mean I have a 2018 with a LSD and have been able to get out of everything, snow, mud. etc.
    Are you going to tow? this is I think really the only reason to get a hybrid. Like others have said the truck gets about the same gas mileage. however the additional power when towing is nice and it's less strain on the drivetrain itself, so you will have better gas mileage when towing. Also putting around town you might get a little better gas mileage. but it would be negligible. on the hwy from what I've read and I have friends with both trucks it's about the same. There companies out there with just some tunes being able to get a lot more Hp out of the standard non hybrids. And turbo lag is for people that have no clue to drive their trucks. lol. Sorry I've had a supra with 900 hp and turbo lag is just a state of mind when you're used to driving a V8.
    But the limited with the heated and ventilated seats are nice for sure! I live in TX and the ventilated seats would be welcomed! plus I do lots of sports and long drives so the heated seats are a nice touch too.
    Like everyone else said, go drive them and see the difference! you can feel it. and if that is what makes you happy, then go for that! It's about a $3k difference when you look at the trucks. if you tow I think it would be worth it, if you drive around town in lots of stop and go, it may help a tiny bit.
  12. Oct 27, 2023 at 12:35 PM
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    I did this yesterday. Both were nice, but the hybrid adds that low end torque which I need for towing my boat. I put a deposit down on a blueprint crewcab w/ 6.5' bed due for delivery in 41 days.
    Joro43, MrKABC[QUOTED] and OLV1071571 like this.
  13. Oct 28, 2023 at 6:25 AM
    Tundra_Jim
    Tundra_Jim New Member
    The Max gives you less payload capacity with the additional weight of batteries, electric motor and components. So if you want or need higher payloads look into that. There’s a video on YouTube where they compare max vs regular iForce and they are basically the same on 0-60 times and in certain results the normal iforce was quicker likely due to weight savings. The Max will benefit under heavier towing load to get to speed a little easier with the extra torque from the electric motor below the truck.
    forzamrit likes this.
