2024 Tundra Light Bar Wiring
Discussion in '3rd Gen Tundras (2022+)' started by asuragod, Nov 20, 2024.
  1. Nov 20, 2024 at 9:53 PM
    asuragod
    asuragod [OP] New Member
    2024 Tundra Platinum TRD OR
    ROXX Tundra front bumper Rough Country Low Profile Hard Tri-Fold Chinese Heritage Grill + Light Bar
    Recently wired up a lightbar for my Tundra but into a small problem. I got the lights to work but they are always on when the truck is on. I installed an OEM style switch from R4T with the intention of being able to turn it on and off but it doesn't seem to work. Attached is how I ran the wires for the light bar and switch. Any idea as to why the button won't work?
  2. Nov 27, 2024 at 2:35 PM
    elysian1
    elysian1 New Member
    2024 Grey Tundra Limited TRD
    you could start by checking to see if the switch itself is faulty. remove the power wires from the switch and manually complete the circuit and see if the lights power on and off. if they do, then you have a bad switch. if theyre staying on no matter what, then youve wired the switch in the wrong place and the circuit is always receiving power
  3. Nov 28, 2024 at 7:46 AM
    Samuryan
    Samuryan Nayrumas
    Reno
    22 sr5 trd OR
    Pretty sure red is your "switched power" and should connect to 86. Green is your "supply and indicator" tap into blue or straight from fuse. Yellow is "nighttime ambient" should tap into brown wire on any existing switch. Always takes my a few tries to map it in my head.... Including nowScreenshot_20241128_073333_Chrome.jpg
    Raven67 likes this.
  4. Nov 29, 2024 at 2:47 PM
    asuragod
    First just wanted to say thanks for the help. As for an update this is what I've tried so far. I've unplugged the wiring harness from the switch itself and the light bar remains on regardless, not sure if that's of any significance. I've also tried switching the red and green wires but no success. I have noticed that regardless as to which wire gets connected to the fuse box, the relay instantly will turn on. I also want to note that the backlight for the switch is not on, but the indicator light is.
  5. Nov 29, 2024 at 5:49 PM
    Hella Krusty
    Hella Krusty New Member
    Battery to 30
    Powered switch to 86
    Ground to 85
    Both 87 to devices IE if you have 2 fog lights, 2 back up lights. If its 1 light bar then connect it to a single 87
    Note: When I ever I hook a relay to a light source I tap the high beam wire and connect to 86. So when I turn on my high beams , the light bar fires on
  6. Nov 29, 2024 at 7:39 PM
    asuragod
    Alright so I finally got it figured out. Thank you all for your input. Problem was when I initially did the wiring I heat shrink-ed both the red and green wires with one big sleeve when I made the connection with the other wire not thinking it would cause any issues(I've never wired anything before in my life so this was a first time experience). I have now separated them and just wrapped them separately with electrical tape.
    Samuryan likes this.
