2024 Tundra and the recall?
Discussion in '3rd Gen Tundras (2022+)' started by 1794 LE number 716, Aug 6, 2024.
  1. Aug 28, 2024 at 10:21 AM
    dJunior
    dJunior New Member
    CT
    You might want a filter "socket" for it- kind of a pain to use an oldschool filter wrench on it- not much clearance or need long arms to swing it to loosen it.
    Also have a bit of hose to drain out the lil dribble cup- fair ammount of oil runs out of it.
    MaineTundy[QUOTED] likes this.
  2. Aug 28, 2024 at 10:23 AM
    dJunior
    dJunior New Member
    CT
    The sheet shows only 3 24 failures so far (1 hybrid). still low in milage and not hitting that average just yet but the 24s that do let go went very very early.
    MaineTundy likes this.
  3. Aug 28, 2024 at 10:29 AM
    Fatone
    Fatone New Member
    2022 Tundra TRD Sport Premium
    I saw an article on the GM 5.3 engine contamination replacement recall. It cited 20 hours of shop labor to do the full replacement. Sure that is a book estimate but fractional of the hours it takes for build a bear engine from a short block approach
  4. Aug 28, 2024 at 11:04 AM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Get a Fumoto valve for oil changes. So easy and no mess. Plus, easier to collect for oil samples with one.
    Okimar and MaineTundy like this.
  5. Aug 28, 2024 at 11:31 AM
    kirkb
    kirkb Lurking Member
    DFW
    2024 Tundra Limited 4x4 WCP Nightshade
  6. Aug 28, 2024 at 11:46 AM
    jctmundra
    jctmundra New Member
    Northern VT
    '23 1794 Hybrid Stunning Mesquite/Cream
    The recall is an engine recall, not generic vehicle. Toyota has identified a subset of engines they project to have RUD, not all engines are in this subset therefore your VIN is not listed.
  7. Aug 29, 2024 at 4:39 AM
    ansel123
    ansel123 New Member
    Sr5 2024
    Several
    I do 7500. Funny how when companies started doing free maintenance the oil changes miraculously were ok to go to 10k all of a sudden
  8. Aug 29, 2024 at 6:16 AM
    thomez
    thomez New Member
    NE Ohio
    Silver ‘24 Tundra Platinum
    The only reason they do this is to beg and plead the folks with leased vehicles to change their oil … they will even make it free a couple times.
    Imagine how many lease returns Toyota would get back that had 0 or 1 oil change in 3/36. Who wants to CPO and warranty that?!
  9. Aug 29, 2024 at 10:07 AM
    Bigbadpoppa
    Bigbadpoppa New Member
    got a 2024, going to change my oil at 1000km, then again at 5000km, then every other 5000km after. I've always been religious with oil changes, very small price to pay to have clean oil in an expensive rig. Might seem overkill, but oil gets dirty nonetheless even if the viscosity is still ok.
    SDT-Online likes this.
  10. Sep 4, 2024 at 5:06 AM
    MaineTundy
    MaineTundy 285/65/20 KO2- 34.6”. 35’s fit stock!
    2012 Rock Warrior / 2024 Limited CM 6.5, TRDOR
    Tow Hooks! 285/65/20 KO2 Yakima Rack Carlinkit Carista tweaks
    Can someone verify the metal TRD OR skid plate won’t interfere with the fumoto? It looks like it’s hangs lower than a plug.
  11. Sep 4, 2024 at 5:18 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    No clearance issues at all. Yes, it hangs lower than the OEM drain plug, but there's plenty of room before hitting anything, including the TRD skid plate.
    I have the extended length one with the longer nipple. Still plenty of room.
  12. Sep 4, 2024 at 5:26 AM
    MaineTundy
    Thank you.
  13. Sep 4, 2024 at 7:18 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    Has Toyota announced if they will give a long warranty on the replacement motors or just stick with the standard one?
  14. Sep 4, 2024 at 11:26 PM
    dagooaz
    dagooaz New Member
    Dave
    I haven't heard anything about an extended warranty. That being said, I'm in a 2024 hybrid, which hybrids weren't included in the recall for some unknown stupid reason, nor 2024s before the part number change, so it makes me nervous that I could have a crap engine. I'll just drive it and enjoy it and buy a nice, fat extended warranty before my factory warranty is up. At least I'll get something out of it should the engine crap out.
  15. Sep 21, 2024 at 7:46 PM
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I bought a new 24 a week ago. I planned first oil change at 1000-1500 miles, then 5k, then 10k. I'll do.it myself until the 10k free service.
    Tundrastruck91 likes this.
  16. Sep 21, 2024 at 7:59 PM
    Hella Krusty
    Hella Krusty New Member
    You should be able to have the truck do that automatically. Every time I start my truck the MPG in the cluster starts calculating from zero. The MPG in the JBL does a running average tank to tank to tank unless you manually reset it.
  17. Sep 22, 2024 at 8:59 AM
    GoHuskers
    GoHuskers New Member
    Nebraska
    '24 iForceMax, '17 RX350, '15 GX460
    I did mine at 2000 miles, REALLY easy. No mess no fuss. Bought 10 OEM filters from a dealer in South Carolina for 55$ delivered and I'm good for awhile.
