2024 TRD Pro with Tow Mirrors Grade Package
Discussion in '3rd Gen Tundras (2022+)' started by stout, Sep 6, 2023.
  1. Sep 6, 2023 at 6:24 PM
    stout
    stout [OP] New Member
    Can anyone confirm that these are powered both for extension and folding? It’s on a truck that was just allocated and I have the option to put a deposit down on. The price has me concerned that they are not powered. I had to fold my ‘11s mirrors manually to get in my garage and would rather not have to do that with a new truck.
  2. Sep 6, 2023 at 7:09 PM
    stout
    Much appreciated! Not sure why the Vspec couldn’t say that.
  3. Nov 20, 2023 at 7:23 AM
    24NiteShade
    24NiteShade New Member
    Does anyone know the OEM part numbers for these mirrors and the two cube switches to extend and light the tow mirrors?
  4. Nov 20, 2023 at 8:16 AM
    Henry2019
    Henry2019 N/A
    Houston, Texas
    2019 SR5 CM CEMENT GREY
    3/1 Lift Kit 20X9 Fuel Assaults +1 295/60R20 Falken Wildpeak A/T3W
    sounds like a whole nightmare lmao
  5. Nov 22, 2023 at 8:02 AM
    iparks81
    iparks81 New Member
    Ian
    3rd Gen 1794
    bone stock
    I'm looking for a set of OEM Tow Mirrors as well.
    They are Crazy $$, but I need them, and I am not going to put on lame strap-on's
    Boost Auto says "coming soon" with a nice set of mirrors, but I need them sooner than "coming soon"
    I have a 1794 with AVS, when I pull the switch panel back it looks like it is pre-wired for the push buttons for "extend" and "light" for the mirrors. Do you think that new harnesses will still be necessary at that trim level?
    I would love to find the part numbers for the mirrors and switches, I can only find the P/N's for the standard mirrors.
    On a side note...the dealership nearest me has 50+ Tundras coming in, and only 3 are coming with tow mirrors...2 Platinums and 1 Limited.
    ryanwgregg likes this.
  6. Apr 30, 2024 at 11:23 AM
    sbrews
    sbrews New Member
    2024 Tundra
    None... yet.
    Its been a bit since the last response... I got a 2024 Tundra SR5 Crewmax 4x4 back in February... and find I now want/need tow mirrors and would like to go OEM if at all possible. I did pop off the blank button panels on the dash - wiring for the light and extend are indeed there. So like the above, I am interested to know if a new harness is actually necessary or would I be good to go with just getting the tow mirrors/buttons and swapping them out.
    Editing to add/ask:
    If OEM is not an option for reasons, are there any 3rd party mirrors that you would suggest/recommend that have OEM like functionality (BSM (blind spot monitor), power folding, extending, etc)? While I would like OEM, I am open to 3rd party.
  7. Nov 22, 2024 at 6:26 PM
    Just_Tito
    Just_Tito New Member
    23 Tundra
    I don’t think anyone has successfully swapped oem tow mirrors for oem mirrors and have everything functioning properly. I would trade right away if this was easy. I hate these big ass mirrors.
  8. Nov 24, 2024 at 2:20 PM
    Coachcleats90
    Coachcleats90 Solar Octane
    Brad
    Bend, Or
    23 Pro Solar Octane
    OEM Console safe Bed Tie downs Tactillian flag & Bear flag AJT key fob CBI covert bumper More to come
    I did. Guy sent me switches too. Although he broke em at remove time in half, so they wouldn’t work. Will need to buy new switches I guess.
    Took a different harness too.
  9. Nov 24, 2024 at 6:15 PM
    catch22
    catch22 New Member
    2024 Blueprint Platinum CrewMax 6.5 bed 4x4
  10. Nov 25, 2024 at 9:16 AM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    How bad was it tearing apart the entire dash then to put the new wire harness in the truck? and how much did you spend on the harness? part number for the harness you used?
    You may have bolted a set on, but it doesn't sound like you have a set of fully functioning folding OEM tow mirrors yet.
  11. Nov 25, 2024 at 8:34 PM
    Just_Tito
    23 Tundra
    it sounds like you are at maybe 80%?
  12. Nov 25, 2024 at 10:10 PM
    Coachcleats90
    Brad
    Bend, Or
    23 Pro Solar Octane
    Had dealership do it. Of course they charged arm / leg for the job. Panel of door is super easy 3, screws. Side of dash is easy, just clips. Know this now after switching panels to red.
    Seller provided the OEM harnesses. So I lack part #.
    80% semantics I guess. If switches had been taken apart wholly. Extend and lights would work…
    Just_Tito likes this.
  13. Nov 26, 2024 at 5:15 AM
    teab
    Ty
    Denver
    What do you consider an arm and leg for being charged? I mean people are trying to figure out if they want to do this and you're all "I don't kiss and tell"...share some specifics dude like what your invoice said for hours, what the invoice said they did, maybe some pictures of your "harness"...you know helpful stuff.
    I don't think its just your switches that don't work. I have a feeling you'll be disappointed when your switches show up and they still don't work. I don't think you understand the extent of the harness that is needed to get them fully functional.
    Report back when you have them fully working or share some info that is helpful. Many have tried to make this work and if you stumbled on a way to do it then enlighten the audience other than I have done it but they don't work though.
  14. Nov 26, 2024 at 5:20 AM
    tom_w2287
    tom_w2287 New Member
    Tom
    2024 Tundra SR5
    Weatherguard toolbox, Ranchhand grille guard
    The yota garage has a tow mirror option that’s plug and play, the only downside is it’s manual extend and you lose the mirror camera. They are like $800
  15. Nov 26, 2024 at 9:37 AM
    Coachcleats90
    Brad
    Bend, Or
    23 Pro Solar Octane
    @teab
    Swapped harness is installed. Arm n leg attached for what was done. Started out way lower then when I showed up to retrieve truck, it was oh we had two guys working on it… this n that here is your new bill. Local dealership isn’t super customer centric. Over 900 bones for work…
    knowing now how to remove door panel, I may have been able to run new harness thru door grommet myself. Just wanted (dealership) to do so it would be warranty. Believe I’m in error with that thought process too since I provided the OEM pieces…
    sticky note is the part #’s for switches.
    1200 for mirrors, plus switches, plus 900+-. It’s steep for the cut over doing at dealership. Think I got a decent price on mirrors too. They could be more costly to purchase.
    Hopefully more ‘helpful’
    B
  16. Nov 26, 2024 at 9:42 AM
    teab
    Ty
    Denver
    Super helpful. Hope the switches get em working.
  17. Nov 27, 2024 at 8:11 PM
    silverrules
    silverrules New Member
    I was able to add this option to my 2025 TRD pro and cost was $290
  18. Nov 29, 2024 at 1:48 PM
    teab
    Ty
    Denver
  19. Nov 29, 2024 at 6:58 PM
    silverrules
    Just picked up my truck today and can confirm its powered for both, extension and folding.
    DimaA likes this.
