2024 Oil
Discussion in '3rd Gen Tundras (2022+)' started by ridre52, May 16, 2024.
  1. May 17, 2024 at 8:41 AM
    DRP
    DRP Old Member
    Dave
    I've been getting my oil out of a big vat behind McDonald's. Been working fine so far. And my exhaust smells like fries. Win win in my book.
    SpilledTheSalt likes this.
  2. May 17, 2024 at 8:53 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I'm not gonna use that new fancy rock oil. Sperm whale's oil is way to go.
  3. May 17, 2024 at 9:19 AM
    Retired...finally
    My Fiat recommended 5w40 but I know better. It's Italian so EVOO is what it gets.o_O
    LightTheBeam likes this.
  4. May 17, 2024 at 1:39 PM
    pwpblue
    pwpblue My ignor list just keeps growing!
    Greensburg,PA
    2023 Toyota Tundra Platinum ADV
    I hope not in plastic bottles...........extra v oil has to be in special dark glass bottles............lol
    Retired...finally likes this.
  5. May 17, 2024 at 3:31 PM
    mass-hole
    mass-hole New Member
    Because the manufacturer is choosing the specs based on a multitude of variables. The most beneficial option for the manufacturer is not necessarily the most beneficial option for the owner, especially a long term owner.
    Those two things are not neccesarily causing issues in other engines at 20k miles though.
    In fact, start/stop actually lowers fuel dilution. Sitting, idling at a light, is exactly the kind of activity that allows fuel to build up in the oil.
    Black widow TRD likes this.
  6. May 17, 2024 at 3:35 PM
    lapoolboy
    lapoolboy New Member
    Wrong.
  7. May 17, 2024 at 3:36 PM
    mass-hole
    Its really is false though. Oils a liquid and the oil pump is positive displacement. Whether its 0W-20 or 5W-40, the pump will move the same volume of oil through the motor.
    Its not like 5W-40 oil molecules are thicker and wont fit in between the bearing surfaces.
    vtl likes this.
  8. May 17, 2024 at 3:38 PM
    Retired...finally
    consider the pressure relief valve.
    sudobash and Ausfahrt like this.
  9. May 17, 2024 at 3:39 PM
    mass-hole
    Ok, even so, it wont "Starve" the bearings of oil. The pressure will be the same in the bearing and flow will be high.
    Engines are not that finicky about oil viscosity and you will see engines even of the same build but in different applications are ok to use differnt weight oils. Take GM's 6.2L. 0W-20 in many applications. A Camaro with the track pack uses something like 0W-40.
    Fords Coyote. 5W-20 in some applications but comes with factory 10W-50 in others.
    This is all about appeasing the EPA. I would never run 0W-20 in a motor like this. I don't even run 0W-20 in my 5.7L or the 4.6L I had before that. I was running 0W-40 Euro oil in my Ecoboost.
  10. May 17, 2024 at 3:41 PM
    lapoolboy
    Sorry, but the viscosity of a fluid being pumped absolutely affects the flow characteristics within the system. Set up a closed-loop system and run tests...you'll see pressure and flow changes are related to the viscosity. Try pumping water vs. honey and see what happens.
  11. May 17, 2024 at 3:44 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    30 years ago my dad thought i was an animal for using 5w-30 and not 20w-50
  12. May 17, 2024 at 3:45 PM
    mass-hole
    Sure if its not a positive displacement pump. If anything the heavier weight oil will increase pressure at low RPM where these engines make their peak torque and help keep the bearing clearances. Flow volume will remain the same.
    Also, cold starting a 0W-20 is still WAY thicker than 30 or 40 weight at operating temperatures and the engines handle it just fine. If we're starving bearings then its happening with 0W-20 too.
  13. May 17, 2024 at 3:49 PM
    mass-hole
    Thats because those oils probably didnt have good antiwear properties and were depending on viscosity to keep metal parts separated.
    But just because new oils have better properties doesn't mean the viscosity thing doesn't still hold true.
  14. May 17, 2024 at 3:54 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    I think tolerances are part of the equation here. For example, if you want to bbq that wagyu steak with propane (and propane accessories), ideally it would be at least one inch thick. However, if your bbq is powered by natural gas, you’re gonna need a 7/8” thick slab of that same beef.
    mayan likes this.
  15. May 17, 2024 at 4:12 PM
    j-utah
    j-utah lost member
    Utah
    Fortress of Solitude, CO
    2024 Tundra SR5
    Dice valve stem caps (black)
    @vtl gave me the best advice. Another big brother for me on this forum. :hattip:
    vtl[QUOTED] likes this.
  16. May 17, 2024 at 4:28 PM
    j-utah
    j-utah lost member
    Utah
    2024 Tundra SR5
    I should point out that all of the 5.7 guys have good advice. A lot of displacement comes with a lot of advice. Take it. VTL just gets the award for being good and concise.
    vtl and Retired...finally like this.
  17. May 17, 2024 at 5:53 PM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    When triggered it will leave the designed line pressure, despite of oil viscosity. Propagation delay from the pressure source to sink will be higher with higher viscosity oil, but that's the counter job for a thicker oil film.
    5w30 is not radically thicker than 0w20. You only start to feel something when fill, say, 10w40 instead of 0w30. Like the engine is a bit more sluggish.
  18. May 17, 2024 at 6:28 PM
    pwpblue
    Greensburg,PA
    https://m.youtube.com/watch?v=V5a4kP-5Jiw
    Pretty obvious
    I work on material handling equipment-oil weight does make a difference. Cold storage unit/full time or part time in freezer two different oil requirements.
    This threads going to go on for infinity.
    lapoolboy likes this.
  19. May 19, 2024 at 6:16 AM
    #49
    captainnemojr
    captainnemojr New Member
    2024 Tundra Platinum HV 4x4 TRD OR
    I was wondering if someone was going to mention 0w-30. It falls right in line with the overseas specs, but isn't listed. I would think this would be the optimal one to pick if one was going to deviate from US specs.
  20. May 19, 2024 at 7:02 AM
    #50
    pwpblue
    Greensburg,PA
  21. Dec 23, 2024 at 4:59 PM
    #51
    bailey bulldog
    bailey bulldog New Member
    How's the 0w-30 doing? Been reading too much about oil lately. LOL
  22. Dec 23, 2024 at 5:27 PM
    #52
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    Use French fry oil. Exhaust smells better
    WILLINH likes this.
  23. Dec 23, 2024 at 9:57 PM
    #53
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    All I know is my truck and my son's truck have been quieter and smoother with 5w-30 in them. I figure if Ford is using 5w-30 in their Ecoboost and not having bearing failures, there may be something to that. Plus, the Ecoboosts get better mileage than the Tundra does. Go figure.
    WILLINH and Hbjeff like this.
  24. Dec 24, 2024 at 10:39 AM
    #54
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    For stress free driving, consider trading truck in before drivetrain warranty expires.
    You’ll get a decent trade in price with lesser miles on the truck.
    Plus, you’ll have the enjoyment of driving a vehicle without the stress of the repair cost of a major engine or transmission repair.
    I do absolute minimum maintenance and trade it in.
    No worries of what type of oil to use or doing early oil changes or using high octane gas.
  25. Dec 24, 2024 at 6:38 PM
    #55
    Raven67
    Raven67 It wasn't me.
    Kentucky
    24 Limited, 21 Redeye
    I just stick with the recommended oil as per manual, which is 0W-20. Many engineers & hours of testing & building went into this engine or any engine for that matter. The owners manual states that if any other is used, to switch back as soon as possible. Don't you think that if thicker oil was the cure all, then Toyota would recommend that instead of voluntarily replacing 100,000 engines?? I'll stick with what recommended & not worry about it.
    Although, my truck will get 5000 mile oil changes.
  26. Dec 24, 2024 at 7:35 PM
    #56
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I manufacture my own engine oil and have submitted it for testing.
    It exceeds all chemical and wear benchmarks.
  27. Dec 24, 2024 at 8:22 PM
    #57
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    The thinner oil will get to the crucial parts of the engine quicker than the heavier grade motor oil. Most manufacturers do recommend the use of the specific grade in their engines since they do build them and do a lot of research to know what is best for your vehicle. The biggest factor in engine reliability and longevity is doing the oil changes at regular intervals and keeping up with preventative maintenance. You can always upgrade to synthetic oil which does have better life expectancy than conventional oils. Can help the engine run cleaner longer. I have had multiple vehicles with over 250,000 miles while using synthetic without any engine issues. I do use the recommended weight oil with the synthetic.
    Raven67 likes this.
  28. Dec 25, 2024 at 7:06 AM
    #58
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Cold start benefits thicker oil as it provides better protection without oil pressure reaching the bearings yet. Open just any engine text book. Thin oil is for reducing pump loss in exchange of greater wear.
    When engineers were the ones who dictated what oil grade had to be used in engine, it was the SAE60 engine oil times.
  29. Dec 25, 2024 at 7:07 AM
    #59
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Now the question: does your engine oil gland produce enough of oil for 5k miles oil change intervals?
  30. Dec 25, 2024 at 9:38 AM
    #60
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Change intervals?
    Ain't no change.
    sudobash likes this.
