2023 TRD Sport - 20” wheels to 18” wheels
Discussion in '3rd Gen Tundras (2022+)' started by Rocco2Gen, Jan 4, 2024.
  1. Jan 4, 2024 at 7:59 PM
    Rocco2Gen
    Rocco2Gen [OP] New Member
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    Many TRD Pro owners are immediately switching out wheels and tires and posting to sell. I love the BBS Forged wheel and the Falken Wild Peaks.
    Is there any issues I need to consider? Can I simply just swap 20’s for 18’s?
    Durtywrench likes this.
  2. Jan 4, 2024 at 9:10 PM
    Northern Toyota
    Northern Toyota New Member
    2023 Tundra TRD Off Road, 2022 Tacoma TRD off road premium
    Tires and bilstein
    Go for it. No issues
  3. Jan 4, 2024 at 10:07 PM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    Is it true that my truck with light up with warnings going to a different size wheel? Someone mentioned that you need to reset something called a speed sensor cali ratio?
  4. Jan 4, 2024 at 10:22 PM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    One more item.
    Any issue using the TPMSensors?
  5. Jan 4, 2024 at 10:27 PM
    NickBrewer
    NickBrewer New Member
    2023 Toyota Tundra 1794 Edition Magnetic Gray Metallic
    As long as the overall diameter of the wheel/tire combo is approximately the same, you should not have any issues...
  6. Jan 5, 2024 at 3:08 AM
    TundraRod5
    TundraRod5 New Member
    Rodney
    2023 Tundra TRD Sport Lunar Rock
    You will be all good. I took off and sold my 20inch Sport Wheels and replaced them with 18inch Fuels and 35s. When they did the lift at the dealer they reset my TPMS for me and the truck has been golden ever since!
  7. Jan 5, 2024 at 5:58 AM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    I really appreciate the feedback!
    Thank you!
    Mattedfred likes this.
  8. Feb 1, 2024 at 9:00 PM
    edielrvra
    edielrvra New Member
    dont forget those 35s on the 18"
  9. Feb 1, 2024 at 10:10 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    If I were you I’d pay real close attention to the weight of what you go with . I went to a metric 35” on 18s . I left the platinum 20” wheels. Wheel and tire combo was only up 7 pounds per corner . I didn’t lose much mpg though and still get 16 right now . When I was researching wheel and tire combos it was really easy to add 45 pounds to the weight that’s already there per corner .
  10. Feb 2, 2024 at 1:55 AM
    Yota802
    Yota802 New Member
    2023 Tundra Hybrid Limited CM WP
    Where would I find what stock weight was originally?
  11. Feb 2, 2024 at 8:05 AM
    Rocco2Gen
    Rocco
    202e Tundra TRD
    2023 TRD Sport
    Per my bathroom scale:
    TRD 20" Wheel with Bridgestone's = 78 lbs
    TRD Pro 18" Wheel with Falken Wild Peaks = 70 lbs
    Note: I went from one OEM Stock set up to another OEM stock set up.
    What I noticed right away was that the turning was greatly improved. I feel that the truck corners better. Other aspects feel very close to what it was prior.
    I am contemplating to purchase a "take off" TRD Pro shock set up ($2500 ish) which also means I need the Red CV axle (take offs $300).
    I am also contemplating (this is my preferred action) Eibach PRO-TRUCK-LIFT Stage 1 ($989) may or may not need the Red CV axle.
    I am in touch with Eibach as they intend to test this on the TRD Sport - but have not as of yet.
    I think it's a slam dunk if I purchase the Red CV axle as that would be the same as TRD Off Road.
    Before Pic
    After Pic
  12. Feb 2, 2024 at 9:55 AM
    Morning_Rock
    Morning_Rock New Member
    Those RC fender flares are perfect on the truck!
    Durtywrench[QUOTED] likes this.
  13. Feb 2, 2024 at 11:39 AM
    Durtywrench
    Lou
    23 Tundra platinum
    None
    Thank you ! The original ones were black so these matched perfectly .
