2023 sequoia SR5 TRD off-road Phoenix
Discussion in 'Sequoia Builds' started by Cdunner, May 2, 2023.
  1. May 2, 2023 at 4:45 PM
    Cdunner
    Cdunner [OP] New Member
    2023 White Sequoia SR5 TRD Off-road
    Hello all. My name is Chris and I’ve owned my 2023 sequoia for a month now. It’s a 2023 sr5 trd offroad 4x4 tow package with heated steering wheel. I’m out in Phoenix but purchased in Santa Barbra. I have installed trd pro wheels/tires, trd pro grille, rigid sae 20in light bar, westcott pro light bar bracket, and RC 1.75 front leveling kit. I have air lift rear bags on the way. Thanks for checking out.
  2. May 2, 2023 at 4:51 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Noice! :thumbsup:
  3. May 4, 2023 at 4:30 PM
    sd172
    sd172 New Member
    South Dakota
    2021 Sequoia Nightshade
    Looks good!
    Are you planning to trim/remove the lower air dam at some point?
    Cdunner[OP] likes this.
  4. May 4, 2023 at 5:12 PM
    Cdunner
    I’ve taken it off already it’s just held by 10 screws. I may just take it off when going off-roading. I’m sure taking it off will lower my mpgs as well.
    sd172[QUOTED] likes this.
  5. May 4, 2023 at 7:34 PM
    Cdunner
    Installed 2022+ Tundra ultimate rear air lift kit. A band saw came handy here. The mounting points are the same but the rear shock top mounting point is a few inches closer to the rear axle than tundra. I had to notch the bracket about 1/2”. I’m going to keep 5 psi in the bags and see how the ride is. 5 psi gives me 1/2 lift in the rear which is a good thing. The RC front spacer lift left my front 1/2” higher than the rear.
    sd172 and Metro14536 like this.
  6. May 4, 2023 at 7:42 PM
    Cdunner
    The pro doesn’t come in 8 seats so I had to make my own. I want to black out the window trim, and ideas? I’m not sure about plastidip
  7. May 5, 2023 at 2:56 AM
    EvoTundra
    EvoTundra New Member
    Sweet looking Sequoia!!
  8. May 5, 2023 at 9:04 PM
    rohit_trd
    rohit_trd New Member
    2023 Toyota Sequoia HV SR5 4WD with TRD Off-Road
    Hi - Are you also considering replacing the fender flares with the camo-pattern fenders of the '23 Sequoia TRD Pro (with the marker lights)?
    I've been trying to get the exact part numbers for the TRD Pro flares, but the Toyota Information System at the dealer keeps coming up with Tundra TRD Pro flare part numbers.
  9. May 5, 2023 at 10:21 PM
    Cdunner
    Hi yeah I’ve thought about this but the difference between the two are pretty minor from far away, would be cool though. True, dealers don’t have a ton of part numbers on sequoia yet. If you find out something let me know. I think my max price on this mod is $500. Oh sr5 with trd off road too sweet, there’s not a lot of us around.
    rohit_trd[QUOTED] likes this.
  10. May 20, 2023 at 7:39 AM
    Cdunner
    Added a cornfed 2022 tundra 1” rear spacer. So this is a RC 1.75 front and cornfed 1 rear. Looks and drives nice. .5” higher in the rear.
    doublethebass, S. Equoia and sd172 like this.
  11. May 20, 2023 at 8:37 AM
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    How much does the fan on the garage ceiling help with PHX summer?
    I have 5 or so small fans running 24/7 to lower temps a few degrees.
  12. May 20, 2023 at 9:09 AM
    sd172
    sd172 New Member
    South Dakota
    That is a nice set up with airbags. I like just a little tilt with the rear sitting higher.
  13. May 20, 2023 at 10:46 AM
    Cdunner
    Still hot as hell but it’s works well.
    e30cabrio[QUOTED] likes this.
  14. May 20, 2023 at 10:57 AM
    e30cabrio
    Do you have any info on it? brand etc?
    Thanks
    Cdunner[QUOTED][OP] likes this.
  15. May 20, 2023 at 11:43 AM
    Cdunner
    Tundrastruck91 likes this.
  16. May 21, 2023 at 7:35 PM
    GingerGremlin84
    GingerGremlin84 New Member
    2021 Black TRD PRO
    Looks great Chris.
    I just got a Limited in Lunar Rock with the TRD Off road package. Looking to do the TRD Pro grille swap first thing. Did you do yours yourself? Im wanting to get the marker lights and light bar to do it all at once.
    The limited has chrome door handles as well as the chrome window trim. I’ve seen a few recommendations to dechrome at a place that installs car wraps. It’s a route I might go with. I’m looking into whether the 23 Tundra door handles will work on the Sequoia for a color match swap.
  17. May 21, 2023 at 7:49 PM
    Cdunner
    Thanks! Welcome to the forum! Yes I did do the swap myself. It took about 3 hours and the entire from bumper needs to be removed so be prepared for that. Checkout YouTube for a good step by step guide, if you need help finding let me know. If you need any help at all let me know. I did install a relay off of the fog lights for the light bar. Also be prepared to run a power line from the trunk to the front. Yes I couldn’t stand all the chrome on the limited so that’s why I went sr5 but the limited comes with some good options that I missed out on.
  18. May 21, 2023 at 7:53 PM
    Cdunner
    FYI your significant other may have a heart attack lol. I would do it overnight.
    e30cabrio likes this.
  19. May 21, 2023 at 8:01 PM
    GingerGremlin84
    2021 Black TRD PRO
    Man, I might have a heart attack I watched a few YouTube videos on Tundra grille swaps, it’s definitely intimidating. I’m actually more concerned about wiring the switch for the lightbar.
  20. May 21, 2023 at 8:05 PM
    Cdunner
    What bar and switch are you installing?
  21. May 21, 2023 at 8:07 PM
    GingerGremlin84
    2021 Black TRD PRO
    Baja Designs or Rave Off Road, but I’d seen some reviews and comments saying Rave had moisture issues in previous light upgrade kits in the past.
  22. Jun 14, 2023 at 1:27 PM
    Bm3z43
    Bm3z43 New Member
    Ben
    2023 Army Green Sequoia Limited
    Yakima Roof Basket
    Nice! I think you did a couple of the same things I planned to do. With the Airlift…does the 5psi in the bags cause the ride to suffer? Also, did you get a MPG loss when you removed the front air dam? I have been contemplating both of those and even have the Airlift Ultimates coming (hate the squat when I put my boat on it), but I didn’t want to mess up the ride so I have been thinking about just using a weight distribution hitch. Also, I hate the low air dam and have been thinking about removing, but I haven’t yet done that either.
  23. Jun 14, 2023 at 2:49 PM
    Cdunner
    Airlift at 5psi made my ride about the same if not better. FYI with the ultimate you don’t need to leave any pressure but I do leave a little. I did not remove the air dam as I’m afraid the mpgs will drop off and I don’t really mind it. I don’t run a distribution hitch on either my 4K pound boat or 4K pound double axle enclosed trailer and everything is smooth and looks good. Did you buy the 2022 tundra airlift kit? It will need modification to fit the sequoia.
  24. Jun 14, 2023 at 4:13 PM
    Bm3z43
    Bm3z43 New Member
    Ben
    Yakima Roof Basket
    Yup…I picked up the Ailift Ultimate kit. When I asked Airlift, they said they couldn’t confirm fitment yet but we’re working on it. I also saw a video by Yota Garage and they told me it would without modification, so I got it. I appreciate your intel on it. A small notch isn’t a big deal. I was more concerned about the ride. Thanks for the Intel!
  25. Jun 14, 2023 at 4:35 PM
    Cdunner
    Yeah you’ll see when you get there. There’s some frame areas where the mounting spots are different between the two. The shock is also at a different location as well. You’ll see when you line it up. I used my bench band saw to cut. Give yourself a couple of extra hours on install.
  26. Jul 8, 2023 at 1:57 PM
    Cdunner
    Thanks yeah they get the looks and they are still super rare.
  27. Jul 10, 2023 at 8:05 AM
    War Machine
    War Machine SSEM # 5 3MW
    Our Platinum Sequoia has black window trim so you may be able to order it.
  28. Jul 10, 2023 at 8:20 AM
    e30cabrio
    That’s opposite of years gone by. Previously SR5/PRO was black & Limited/Platinum was silver.
    interesting!
  29. Jul 10, 2023 at 8:34 AM
    Cdunner
    Yeah I tried m, unfortunately you have to order the whole glass for the rear apparently. Was like 900$ a side.
  30. Jul 10, 2023 at 8:38 AM
    War Machine
    Yeah it was definitely an improvement in that area. No chrome at all on this one. Saved me a little work this time at least.
