2022 wiper blade replacement.
Discussion in '3rd Gen Tundras (2022+)' started by Weimer369, Jan 13, 2023.
  1. Dec 10, 2024 at 2:28 PM
    GREENPUS
    GREENPUS New Member
    Scott
    2024 Black Tundra Limited TRD Off-Road
    I had a 2018 RAV4. The original wipers from factory were perfect for 3years. I thought the same and paid Toyota to put Toyota OEM wiper blades on. Not the same. I got 6 months out of the wipers before streaking. Keep the original as long as possible lol
    TundraDan723 and DRP[QUOTED] like this.
  2. Dec 10, 2024 at 2:33 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Im gonna get some replacements, test drive a 25 and swap em :)
  3. Dec 11, 2024 at 9:28 AM
    PNW Tundra Mike
    Southern Cal
    MX4 Tonneau, Talon's Trans/Cat Shield
    I’ve found the Toyota OEM replacements to last longer than either the Michellins or Bosch blades from Costco
  4. Dec 11, 2024 at 10:10 AM
    JDAZ
    JDAZ New Member
    NJ
    2022 Lunar Rock TRD Limited
    Chrome Delete, TRD Pro Grill with BD light bar & OEM switch Beatsonic Amp Undercover armor flex cover
    I've been using the OEM inserts for 10 years. The Tundra's are super easy to replace unlike my Tacoma's that had metal inserts. I've tried the Bosch and RainX. (too expensive) The Tricos wouldn't make it through a winter. Anco's were junk. Silicone would be great but even more expensive. Plus some have open frames that allow stuff to get hung up in them. The OEMs, IMHO, are the way to go.
    https://partsouq.com/en/catalog/gen...=$&vid=0&cid=4&uid=432875&q=5TFJA5DB1NX008441
  5. Dec 11, 2024 at 10:44 AM
    eddiefromcali
    Eddie
    100% Stock
    looks like its the same pn for left and right...cheap too! Thanks!
  6. Dec 14, 2024 at 6:09 PM
    Gonefishingdave
    Gonefishingdave New Member
    Dave
    Central New York
    2024 MGM Tundra TRD OR Limited
    Bakflip cover, AVS vent visors
    I can tell you to avoid this wiper insert from Amazon:
    https://www.amazon.com/dp/B0BP6WGNLX?ref=ppx_yo2ov_dt_b_fed_asin_title
    Easy to install but left a 2-3 inch streak of water across the whole travel of the blade positioned at the center of the blade.
    I had to reinstall the old inserts.
    Amazon garage tagged this as a fit for a 2024 Tundra which is weird as they are a universal part.
    The cross-section on these inserts were not like the OEM ones.
    The OEM inserts only had one channel on each side on the cross-section but the Amazon ones had two.
    I will get genuine Toyota based on part number given in other posts on this thread.
  7. Dec 14, 2024 at 8:55 PM
    Spartanfam
    Spartanfam New Member
    West Michigan
    2024 Tundra Limited TRD Off-Road
  8. Dec 15, 2024 at 4:24 AM
    raylo
    raylo not so new member
    Frederick, MD
    I just got a set of the OEM inserts to replace the originals in my 2023. Easy peasy. No matter what you use the new attachment clip for the blades to the arms is the best and simplest ever. Genius.
    Gonefishingdave likes this.
  9. Dec 15, 2024 at 2:32 PM
    osu1978
    osu1978 New Member
    I plan on swapping rubbers myself. Do this on my Hondas too. No point in buying the whole contraption unless it’s damaged.
  10. Dec 16, 2024 at 7:37 AM
    a71rambler
    a71rambler New Member
    Kitsap County, WA
    '25 Lunar Rock Limited w/TRD OR and Performance Package
    A bunch...
    Living in the PNW we get alot of wet days... good wipers are a must, especially for someone who drives in the dark and is awaiting cataract surgery.
    I have used PIAA Silicone wipers on all my trucks and love them. But now with a '25 Tundra, I am having trouble finding fitment information.
    Hoping someone has tried the PIAA Si-Tech on the 3rd Gen Tundra and can report back on fitment.
  11. Dec 20, 2024 at 9:34 AM
    eddiefromcali
    Eddie
    100% Stock
    swapped inserts last night...so easy
  12. Dec 21, 2024 at 11:51 AM
    Aku77
    Aku77 New Member
    Washington State
    2023 Gray Tundra Limited
    Another vote for the Toyota OEM inserts. I find them to last almost 2 years for me here in Washington State. I typically just replace them around 1 1/2 years because they're not very expensive.
    A month ago, I went in to the dealership parts dept to buy some. I asked for wiper blades and they pointed at a rack of Sightline blades at $22 each. I asked if they still sell the OEM inserts. The two parts guys looked at each other, smiled, and then one said, "Oh, you want the good stuff." They double checked the size and then went in to the back.
    I also like the Bosch blades but the last time I bought them, they were around $29 each and they only last about 1 year for me.
    MAC25Tundra likes this.
  13. Dec 22, 2024 at 3:33 PM
    a71rambler
    Kitsap County, WA
    A bunch...
    Which dealership in WA?
  14. Dec 23, 2024 at 1:06 PM
    Aku77
    Aku77 New Member
    Washington State
    Titus-Will Tacoma. It's near the Tacoma Costco.
  15. Dec 24, 2024 at 7:21 AM
    a71rambler
    Kitsap County, WA
    A bunch...
    Thank you! I know it well... I am up in Kitsap.
  16. Dec 24, 2024 at 8:01 AM
    Hella Krusty
    Hella Krusty New Member
    Go with OEM refills (replace the rubber only ). 70% cheaper and last twice as long
    astrength22 likes this.
  17. Dec 26, 2024 at 9:56 AM
    Toyota_Ed
    Toyota_Ed New Member
    Ed
    Hades - Panhandle of Texas
    1967 Stout - 2024 Tunra
    Be CAREFUL on 'replacements' from Toyota, as they try to install their 'economy replacement' aka 'sightline blades', they are the $19.99 blade, NO refills available for the sightline style... the OE blade lists at $29.99 per blade, the INSERT for the OE blade is $12.18 per insert (X2)
    Tundrastruck91 likes this.
  18. Feb 17, 2025 at 7:18 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Can anyone point me to an online source for the replacement wiper inserts # 85213-0C010 who will ship?
    My closest dealer is over an hour away, and won't ship to my address. And I don't see the inserts on Amazon.
    Thanks for your help.
  19. Feb 17, 2025 at 11:42 AM
    #49
    MikeVpdx503
    MikeVpdx503 New Member
  20. Feb 17, 2025 at 12:41 PM
    #50
    Matt2015Tundra
    2023 1794 CrewMax
  21. Feb 17, 2025 at 1:48 PM
    #51
    MikeVpdx503
    et
    Not yet, I just ordered 4 wiper inserts since shipping quoted was >$6. We will see
  22. Feb 17, 2025 at 2:35 PM
    #52
    Matt2015Tundra
    2023 1794 CrewMax
    I just ordered 2.
    Shipping date was a ways out, but it was certainly cheap enough. The inserts price was also cheaper than my local dealers.
  23. Feb 17, 2025 at 4:18 PM
    #53
    brhodea
    brhodea New Member
    Michigan
    '24 CM Limited
  24. Feb 19, 2025 at 3:18 PM
    #54
    Toyota1234
    Toyota1234 New Member
    Jack
    2022, army green limited, off road, DC
    I’m still rocking my originals that are now 3 years old. They are still working 100% like new. Really incredible. There was a promotion a year or so ago to get a free set of wiper blades with an oil change so I have a new set sitting in a box.
    TundraDan723 and 22whatwedo like this.
  25. Feb 28, 2025 at 7:57 AM
    #55
    Matt2015Tundra
    2023 1794 CrewMax
  26. Feb 28, 2025 at 8:04 AM
    #56
    DRP
    DRP Old Member
    Dave
    What was their price? If I remember correctly, my dealer was $15 for a pair but haven't needed to buy any yet.
  27. Feb 28, 2025 at 8:16 AM
    #57
    Matt2015Tundra
    2023 1794 CrewMax
    They were $8.71 per insert, which is half the price my local dealership charges.
    Plus I didn't have to take the 2 hour round trip to my dealership to pick them up.
    Edit: I was mistaken. My local dealer quoted me a price for the entire wiper blade replacement, not just the insert. They charge around $10 per insert. But, with the time and fuel savings, it was still a lot cheaper to order from the linked vender and have them delivered.
  28. Feb 28, 2025 at 8:54 AM
    #58
    DRP
    DRP Old Member
    Dave
    Got it. Thanks. I have a dealership within 5 minutes so will just stop by there when needed.
  29. Feb 28, 2025 at 9:00 AM
    #59
    raylo
    Frederick, MD
    Just be careful... my normal dealer doesn't stock the refills, only the whole blades. Same for another dealer I tried whilst visiting family elsewhere. So, call ahead to see what your dealer carries. I had to order them via the Toyota parts website and select my dealer for pickup.
  30. Feb 28, 2025 at 9:40 AM
    #60
    MikeVpdx503
    Same here, my dealer only carries the Site Line replacements which are not the same quality as the OEM originals.
    Inserts are the way to go. I bought 4 of them (2 sets) so I should be good for approx 5 years of PNW rain
