2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Feb 20, 2021 at 3:30 PM
    #2851
    Bulldog9
    Bulldog9 "My other car is a Porsche"
    NOVA
    2017 TRD PRO in Cement
    see sig for mods.....
    The main problem with Turbo's in addition to wastegate actuation and system problems is the bearing. People who get on it before the oil is warm, or who ride it hard and then shut off can damage the turbo bearings, either scoring when the oil is cold, or coking when shut off too hot. Modern Turbos have water jackets to help with this, but good habit is to let the engine idle for a few minutes before shutting it off. I had an accusump system in my Saab 900 Turbo that would circulate oil through the turbo and engine for 2-3 minutes after shutting down if I wanted. Was also a pre-oiler as well. You just couldn't do both. If you used it to cycle oil on shut down, the pressure would drop and would be a normal cold start. Other than that, if the engine is built with a turbo in mind, there should be no difference.
    I put 500K miles on my 1982 Saab 900 Turbo APC..... Not my car, but this has been floating around Saab Net for years.;) Motor was reportedly on a dyno.
    Lovetrucks and vanapagan like this.
  2. Feb 20, 2021 at 4:38 PM
    #2852
    Squatting Pigeon
    Holden
    North Texas
    4Runner | GR Corolla
    https://pressroom.toyota.com/album/2014-2017-toyota-tundra-third-3rd-generation/
    TomC843 and Cpl_Punishment like this.
  3. Feb 20, 2021 at 4:57 PM
    #2853
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    I mean a tundra is even close to the weight of my gas f250 which is 6,700lbs for a 3/4 ton.
  4. Feb 20, 2021 at 5:07 PM
    #2854
    art64
    art64 New Member
    Now, I got excited what your tune can do to this little monster, if this is indeed the new Tundra's engine.
  5. Feb 20, 2021 at 5:08 PM
    #2855
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    A Tundra splits the F150 and F250 based on online specs. F150 - ~4600 lbs, Tundra - 5500 lbs, F250 gas - 6450 lbs, diesel - 7300 lbs. Don't know if I'd call that close, but the Tundra definitely needs to go on a diet
    Cpl_Punishment and vanapagan like this.
  6. Feb 20, 2021 at 5:17 PM
    #2856
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Automotive generations are defined by the engineers’ model codes, not by someone who writes for the online “press room” of a giant multinational corporation. The XK50 platform from 2007 is still currently in production. This means the Tundra is still in gen 2.
    Either the person who threw that page up made an error that never got fixed, or they think it’s better press for Toyota to call the facelift/refresh of a 14-year model run a new gen since so many others are referring to it that way anyway. It does not trump the model codes set by the design engineers.
    Also...
  7. Feb 20, 2021 at 5:18 PM
    #2857
    Njmike13
    Njmike13 New Member
    Hunterdon county, NJ
    2021 PRO Lunar Rock
    Had nothing to Add. Just wanted to be post #2666:bananadead:
    vanapagan and Oey12 like this.
  8. Feb 20, 2021 at 5:20 PM
    #2858
    Squatting Pigeon
    Holden
    North Texas
    I don't trust car bloggers as far as I can throw them either.
    We'll see what Toyota says when the truck is actually released. As of now, the "4th gen" section is just a place to wrangle all the 2022 threads. The amount of them that get created in a week instead of adding to the dozens that already exist is just mind boggling.
  9. Feb 20, 2021 at 5:27 PM
    #2859
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    The F150 weights the same amount as a 5th gen 4Runner? I would think the F150 would weight more...no?
  10. Feb 20, 2021 at 5:28 PM
    #2860
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    My tundra was over 6000 when it was on the scale. I dont remember the exact number but I think it was close to 6400 lbs if not more.
  11. Feb 20, 2021 at 5:40 PM
    #2861
    Terndrerrr
    Music City
    6UR-FE
    Understood. It’s not the parts suppliers or car bloggers I’m saying are the final arbiters. It’s the Toyota engineers who set the model codes (which are in the wiki link). Just showing many others on the web are supporting that we’re still in gen 2 as well.
  12. Feb 20, 2021 at 5:47 PM
    #2862
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    We have scales where I work. I weighed my 2019 Tundra Platinum. It had Line-X bedliner, soft tonneau cover, and running boards. With me in it, full tank of gas it weighs 6,440 pounds. I also weighed it at a Pilot with Cat scales right after filling up and got pretty much the same number.
    The very thing people complaining about needing to go on a diet is what makes it the best tow rig for a 1/2 ton pickup. It has 500 to 800 pounds in weight in the competition.
  13. Feb 20, 2021 at 5:59 PM
    #2863
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I'm curious if it weighs so much more because it's over built compared to the others or if things like the aluminum bodies etc save that much. My thought was that the Tundra could go on a diet so that adding a battery pack for the hybrid would not increase the weight of them that much.
  14. Feb 20, 2021 at 6:02 PM
    #2864
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    When GM went to aluminum, it reduced their weight by about 450 lbs.
  15. Feb 20, 2021 at 6:15 PM
    #2865
    Azblue
    The Dirty T ( ^_^)_且
    You mean Ford, right? As far as I know, GM is still steel.
  16. Feb 20, 2021 at 6:35 PM
    #2866
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    GM changed everything on their trucks that's hinged (and possibly the roofs as well? Can't remember for sure) to aluminum in 2019.
  17. Feb 20, 2021 at 6:44 PM
    #2867
    belanger9
    Edmonton, AB
    A bunch
    Ford went full aluminum, GM went just the hinged pieces. So any easily replaced pieces they have aluminum. It's what I'm hoping Toyota does with the Tundra. That way you don't need to worry about fixing aluminum, you just replace it - something that can't be done with 1/4 panels. Throw in a composite bed and it saves a bunch of weight right there.
  18. Feb 20, 2021 at 6:51 PM
    #2868
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    As long as Toyota can figure out how to do it without the roof creaking every time you go over a bump or the sliding rear window leaking.
    ryanwgregg and Lovetrucks like this.
  19. Feb 21, 2021 at 12:18 AM
    #2869
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Fully boxed frames from the competition as well as 6 lug hubs. Take that for what you wish.
    I am not a fan of aluminum but I’ll be damned if it isn’t lightweight.
    I miss iron block, iron head,gas engines. The threads never came out with the bolts and they were cheap and easy to rebuild.
  20. Feb 21, 2021 at 7:25 AM
    #2870
    Warreng
    Warreng New Member
    Ski-doo released the first facory 2stroke turbo last year. It makes 0 psi at sea level and full boost at 8000’ or so via a electronically controlled waste gate.
    Could be neat in an automotive application being able to “turn on” the boost when needed.
  21. Feb 21, 2021 at 7:39 AM
    #2871
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I didn't think it was still legal to sell new two strokes....?
    ryanwgregg and Warreng[QUOTED] like this.
  22. Feb 21, 2021 at 7:42 AM
    #2872
    Warreng
    Warreng New Member
    they are alive and well. The modern 2t sled motors are works of art. 165hp from 850cc’s.
  23. Feb 21, 2021 at 7:43 AM
    #2873
    Oey12
    Oey12 New Member
    Joey
    New York
    In regards to the six lugs...does it really make that much of a difference vs the competition (I THINK the highest is 13k by the 3.5 Ecoboost). So 2k less...in reality you would be insane to tow 12k with an F150. Even 10k in a Tundra is a crazy IMHO. If I had to tow the max with any vehicle, ESPECIALLY if it involved highway use, I would be getting a heavier duty truck.
    So what I am getting at is I don’t see how the 5 lugs hinder the Tundra when towing a reasonable weight for any 1/2 ton pickup (0 to 8k)... Just because The manufacturers tell us what the trucks can handle it doesn’t mean that you should.
  24. Feb 21, 2021 at 7:44 AM
    #2874
    belanger9
    Edmonton, AB
    A bunch
    That would be bs if they did, I can see Ski-Doo already got rid of the 550 2-stroke. I loved using that at work, so much better than the 600 4-stroke hair dryer they put in it now.
  25. Feb 21, 2021 at 8:00 AM
    #2875
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    My mistake. Maybe that's a European regulation or something.
  26. Feb 21, 2021 at 8:02 AM
    #2876
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    In my opinion, the primary advantage of 6 lugs would be the ability to find decently priced 18 or 20" wheels without having to buy from the stealership.
    ryanwgregg and Oey12[QUOTED] like this.
  27. Feb 21, 2021 at 8:02 AM
    #2877
    timsp8
    NY
    I am no expert, but I remember reading the 5 lugs allowed a larger lug size so it was just the same as having 6 smaller ones.
  28. Feb 21, 2021 at 8:10 AM
    #2878
    Oey12
    Oey12 New Member
    Joey
    New York
    Understandable...
    If that’s the case I definitely don’t see a significant difference in going with a 6 lug vs the current 5 lugs. Aftermarket wise I can see the desire for 6 lug but outside of that...
  29. Feb 21, 2021 at 9:20 AM
    #2879
    akmerle
    akmerle New Member
    Wasilla, AK
    2018 Tundra Platinum & 2024 GX550 OT
    Rumor is Polaris’s is releasing their factory turbo (and Matryx RMK) on March 1st and it will be low/mid 170’s. My tired iron 2013 RMK 800 will become the wife’s sled, and I’m snowchecking a new one!
    Warreng[QUOTED] and ryanwgregg like this.
  30. Feb 21, 2021 at 9:50 AM
    #2880
    belanger9
    Edmonton, AB
    A bunch
    Did we finally make this thread about a 2022 Tundra we know exists - the 2022 Ski-Doo Tundra :rofl:
Thread Status:
