2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Feb 2, 2021 at 12:46 PM
    #2011
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    It looks like there will be driver's side grab handle. That's one of the check list items. :thumbsup:
  2. Feb 2, 2021 at 12:49 PM
    #2012
    18" TRD Off Road Wheels
    Good eye! You just made so many people happy. :laugh:
  3. Feb 2, 2021 at 1:22 PM
    #2013
    rideandfly
    rideandfly New Member
    Sure it's realistic.
    Occasionally I could load additional weight (gear) on some trips if I had higher payload with the Tundra. It's easy to gain TV & Trailer weight on camping trips if you're not careful, fire wood, gen-sets, Kayaks, solar panels and it's important where it's loaded.
    Also use an electronic sway device because a sway device is required for trailers over 2000 pounds.
    Weigh-in at a CAT scale with empty trailer water tanks, ready to camp with trailer connected, full Tundra 38 gallon fuel tank, and two people on board for local camping trip. A WDH is not required loading the Tundra as per Tundra operator manual as follows.
    Tundra front axle: 3420 pounds
    Tundra rear axle: 3460 pounds
    Trailer wheels: 4440 pounds (Trailer tongue weight on TV)
    TV & Trailer combined weight: 11,320 pounds
  4. Feb 2, 2021 at 1:32 PM
    #2014
    I think you misunderstand what I am saying and the recommendation that I highlighted. WDH is recommended if your trailer is more than 50% of your GVWR (Truck only), not your GCVWR (truck and trailer). The highest GVWR on at 2007+ Tundra that I am aware of is 7200 lbs, so you'd be looking at a WDH recommended on a 3600 lb trailer.
    With the recommendation of a WDH for any trailer over 50% of the TV's GVWR you would have to have a 15,000 lb GVWR to bypass a WDH on trailers up to 7500 lbs. That's not a realistic ask.
    szabo101 and Cpl_Punishment like this.
  5. Feb 2, 2021 at 2:55 PM
    #2015
    rideandfly
    Did not misunderstand, my Trailer weighs in around 4900 to 4950 pounds when not connected to the Tundra and is over 50% of the gross weight of the Tundra. It tows like a dream behind the Tundra at any speed tested without WDH, but some trailers would need a WDH as per your document recommendations due to suspension, loading, length, ect.
    A friend purchased a new 2019 or 2020 GMC Serria 1500 1/2 ton pickup a few years ago. He showed me his operators manual and I was surprised to see the WDH requirement to be higher than my Tundra. I remembered it as 7500 pounds, but after checking the following link found it to be 7000 pounds, my mistake. Always wondered if GMC could do it with a 1/2 ton pickup, why can't Toyota.
    Any increase in WDH weight requirement would be fine with me on new Tundras along with increased payload. .
    Check out page 17 lower RH page notes. SAE J2807 standard has probably been superseded by a later standard.
    https://www.gmc.com/content/dam/gmc...dfs/GMTB18CT100-2018-gmc-trailering-guide.PDF
  6. Feb 2, 2021 at 2:58 PM
    #2016
    Ah, I see. I am a bit more conservative and would use one long before the official requirements. Honestly, I'm not sure what the Tundra's current requirement for a WDH is. I just use the 50-60% rule of thumb.
    Malinois38 likes this.
  7. Feb 2, 2021 at 3:00 PM
    #2017
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I believe the manual recommends a WDH if your trailer weighs over 5000 lbs, so a bit higher than the 50% of GVWR.
    GODZILLA[QUOTED] likes this.
  8. Feb 2, 2021 at 4:36 PM
    #2018
    toyoboyo
    toyoboyo New Member
    Please Toyota, give us this with 240hp/270tq
    These Tacoma lovers saying no to MOAR POWR don't deserve.
  9. Feb 2, 2021 at 11:24 PM
    #2019
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Nah, that's just an old 2013 cab they used for the test mule. They'll actually remove the passenger and rear handles in the production versions for weight savings. :thumbsup:
  10. Feb 2, 2021 at 11:35 PM
    #2020
    OnespeedTRD
    Don
    San Diego
    If Ken Block was sponsored by Toyota this would be his truck!
    Instead, he drives this monster!
    Cpl_Punishment and Boerseun like this.
  11. Feb 3, 2021 at 5:53 AM
    #2021
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Rams payload with the max payload option is 2300 lbs . I would think Fords is higher than that .
  12. Feb 3, 2021 at 6:54 AM
    #2022
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought I heard some F150s with the max payload package were pushing 3000 lbs.
  13. Feb 3, 2021 at 7:18 AM
    #2023
    Breathing Borla
    AZ
    with Toyota's one size fits all type deal, you guys are going to be out of luck to get payload anywhere near that.
    they really should offer a payload package for the guys who want more
    GODZILLA likes this.
  14. Feb 3, 2021 at 8:40 AM
    #2024
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    The max tow package on the Ram is 18,000 lbs and I think Ford is higher than that . But the max tow is just what it says , if you want to tow that much then you can’t take too much else with you .
  15. Feb 3, 2021 at 8:45 AM
    #2025
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    I believe Ken Block recently ended his sponsorship with Ford, will be interesting to see what he does next.
    LarryDangerfield likes this.
  16. Feb 3, 2021 at 8:49 AM
    #2026
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Yep 3,325 lbs to be exact . I just looked it up .
  17. Feb 3, 2021 at 9:06 AM
    #2027
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    Ok this makes me curious...I don't have a trailer. I don't tow. I know several people who do, and I know a few who readily admit they're a bit over GVWR or GCWR but their trucks handle it just fine.
    Here's my question: do you know anyone who has had to pay a fine for being over GVWR or GCWR? Like they've been forced onto scales and found to be overweight and had to pay a fine? In a non-commercial half ton pickup? I'm not saying they're not out there; I've just never heard of such a thing.
    The only people I know of who catch any grief whatsoever or have to weigh their trucks at all are guys driving commercial trucks with DOT weight numbers on the door.
    What laws are there exactly for Joe Schmoe in a Tundra pulling a 28' trailer that puts him over payload? I would think that if our door jambs were the law, then we'd have mandatory checks just like commercial trucks do.
    Boerseun likes this.
  18. Feb 3, 2021 at 9:07 AM
    #2028
    Sephon
    Sephon Don't be an American't
    Northwest PA
    2020 Black Tundra TRD Pro
    Icon Rebounds w/285/75 BFG KO2’s, Coachbuilder +2
  19. Feb 3, 2021 at 9:10 AM
    #2029
    monaco730
    monaco730 New Member
    16 Inferno Tundra
    Fox shocks, TRD Exhaust, TRD grill, TRD shift knob, weathertech floor/bed liners, ARE topper, FrontRunnerOutfitters cargo rack, Relentless cargo bars, color matched front bumper/side mirrors, fuel wheels, nitto RGs, K&N intake
    Mountun Goat likes this.
  20. Feb 3, 2021 at 9:15 AM
    #2030
    trekkar
    trekkar New Member
    northeast CT
    Damn, i think I was more excited about the tundra than the game.
    Still hoping
    You won’t see any "cars" in Toyota’s Super Bowl ad this year.
    Krezz, Boerseun, Doccountry69 and 2 others like this.
  21. Feb 3, 2021 at 9:18 AM
    #2031
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    kago92, lonedrake, MTRock and 2 others like this.
  22. Feb 3, 2021 at 9:21 AM
    #2032
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I know around here recreational vehicles are exempt from having to weigh in at the stations on the highway. But I think folks are concerned about what type of questions will be asked if they're in a collision. I think that's a little paranoid as I suspect the average cop or insurance agent wouldn't even think of GVWR, GCWR or payload but I still wouldn't overload my truck simply for safety reasons.
  23. Feb 3, 2021 at 9:21 AM
    #2033
    trekkar
    trekkar New Member
    northeast CT
    A tundra that competes with the raptor/trx would have gave me hope
    shellshock and Larly5000 like this.
  24. Feb 3, 2021 at 9:28 AM
    #2034
    Laws applied manufacturers and their ratings. The US is obsessed with regulation and manufacturing has to meet requirements that keep lots of products from reaching our market. Like, for example, the Hilux, diesel Jeep Renegades and Ford Rangers, or VWs with a tow rating.
  25. Feb 3, 2021 at 9:31 AM
    #2035
    Never gonna happen. Toyota doesn't chase performance.
  26. Feb 3, 2021 at 9:32 AM
    #2036
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Seeing a kick ass new Tundra revealed during the Super Bowl would be very uplifting and give me hope and strength.
  27. Feb 3, 2021 at 9:37 AM
    #2037
    2021 work truck
    2021 work truck New Member
    22 Tundra Crewmax 6.5
    33" Tires, Black Toyota Rims, TRD shocks
    I don't think Toyota would ever chase "1 upping" the TRX. However competing with the new raptor isn't unthinkable. If the Tundra gets better suspension, new technology, twin turbo with added torque from hybrid system... Bye bye raptor
    Cpl_Punishment likes this.
  28. Feb 3, 2021 at 9:48 AM
    #2038
    Terndrerrr
    Music City
    6UR-FE
    This is what I thought. It's not illegal to be over what the manufacturer recommends, but it's potentially (probably) unsafe and might leave you without insurance in the event of an accident.
    Fully agreed on the trigger happy regs that just seem to be piling up in the US. It seems the regs you're talking about here are related to diesel. I was asking more about recreational towing with a half ton. It seems that we are left to our discretion to follow the manufacturer's recommendation (i.e., the door jamb number is not the law).
    Dang. That was half the reason I was going to watch the game.
  29. Feb 3, 2021 at 9:55 AM
    #2039
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    New Raptor was debuted today.
    Toyota better step up their game.
    5-Link.
    146040421_466644774722993_62502340420666_761e14661436b5cdaab7297fb896b2786fa3ac51.jpg
    145560594_466644771389660_74474638511924_3ec15ccc0dbc167dcee816dcd690db83a4068049.jpg
  30. Feb 3, 2021 at 9:58 AM
    #2040
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    It’s 12,750 for a 1500, but nobody is gonna tow that much with a half ton safely.
Thread Status:
