2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Oct 14, 2021 at 11:17 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    I like that she removed the engine cover to view the plumbing. Looks much cleaner than the ridiculous tangle the Ford TT's have. Still a pretty busy engine bay, just no way around it with twin turbos.
    The crush space between bumper and radiator seems excessive. Plenty of electric fans and cooling, and I hear there's an air-to-fluid trans cooler hidden in there somewhere.
    Don't know what a sparkplug change will require, V8 iridiums can go 100k miles easily. Do turbo engines need more frequent changes?
    I haven't seen the oil filter location, the Pro engine skid doesn't have a filter door. Easy-peasy oil filter change or PITA on the TTV6? I don't like having to drop the skid for an oil filter change.
  2. Oct 14, 2021 at 11:50 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    We know TRD pro crawl control is notorious to get out of any situation, is it so good that Toyota said screw the recovery gear space and tow hooks???idk bruh
    malibu dan and Acedude like this.
  3. Oct 14, 2021 at 11:53 AM
    3rdgenTo3rdgen
    3rdgenTo3rdgen New Member
    2016 Tacoma TRD sport
    Saw a picture of this on my IG. They stated it had a factory 3 inch lift with 35's.
  4. Oct 14, 2021 at 11:53 AM
    timsp8
    NY
    Some said it’s the same engine Toyota already makes for the LC I think. Any confirmation? If so, anyone know where the oil filter is on it?
  5. Oct 14, 2021 at 11:58 AM
    Hextorm
    Hextorm New Member
    Blake
    White 2022 Tundra TRD Sport CrewMax
    Now color match that chrome grill and it's perfect
  6. Oct 14, 2021 at 12:05 PM
    styner1989
    styner1989 Member
    2020 SW Platinum Crewmax 4x4
    I am not sure if this is going to work. I found this the other day when trying to find location of filter and it is at bottom front.
    Acedude[QUOTED] likes this.
  7. Oct 14, 2021 at 12:09 PM
    MemphisViking
    MemphisViking New Member
    Eventual Tundra
    If those are still the 20" wheels they don't look so bad with 35s.
  8. Oct 14, 2021 at 12:29 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    Those are the factory 20" wheels for the Limited TRD OR
  9. Oct 14, 2021 at 12:29 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    I believe TRD skid plates have the window.. but the 2022 non production models so far haven’t..:notsure:
  10. Oct 14, 2021 at 12:31 PM
    MemphisViking
    Eventual Tundra
    I thought they probably were. I knew they looked like the TRD wheels, but I supposed it was possible they had swapped out some 18s from the SR5. I couldn't tell just by looking.
  11. Oct 14, 2021 at 12:32 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  12. Oct 14, 2021 at 12:33 PM
    gunmetalgolfer
    gunmetalgolfer New Member
    Thought I would jump in on this thread now that we have some real data from Toyota to look at (spec sheet). I am new here, been reading for about a month as my long time truck (98 dodge ram 2500) died about 6 weeks ago so I now have to buy a new truck at the worst possible time in history to have to buy one. With that said, I think this Tundra stacks up nicely and thought you may appreciate perspective from a person considering the Tundra.
    Drove a couple F150's w/3.5 in XLT trims which is the only way to get a height adjustable seat in a Ford. Nuts that no XL seat goes up and down and its just too high in its fixed position. My 98 Dodge had a height adjustable seat, WTF. The F150 tow rating for the 3.5 is 11,300 with 3.55's and for 2k you can add the Max Tow package and get it to 13,800 with 3.73's but you get a modified 3 leaf pack suspension with it and its noticeably bouncier/stiffer than the stock F150 (drove them back to back). Payload in the Max Tow truck was only 1439 (1507 on non max tow one) so my heaviest trailer which is 8k would chew most of that. A 13k trailer would be overweight with no one driving, I can't see towing more than 10k with that payload but Max Tow supposedly adds a beefier 3/4 floating axle so probably worth it for durability. The sticker was 53K for either truck (more options on non Max Tow) and these were XLT's!!!
    Drove an F250 XLT and the towing is only 12,500 with the standard 6.2. Not interested in the diesel (cost or hassle) and can not find a 7.3 which would add another 2k to the price (which was 52k) but adds about 2k towing. Payload was only 2850 as well, you have to move to an F350 to get back to the 3750 payload my 98 Dodge had. The ride of the F250 was awful, the back literally jumps out regularly over normal road imperfections when driving unladen. I cannot imagine driving that thing everywhere, my Dodge was not good either but somehow seemed better than that F250.
    The Tundra SR5 looks like it will come in at 11,200 towing. The payload should be north of 1600 (the Pro says it will have 1600) which works fine for an 8k trailer. It has a standard height adjustable seat from what I can see, LED headlights which I love (need XLT High trim in Ford to get those which is a 6k package). Initial reviews say the ride quality is great and should be about the same gas mileage as F150 and way better than F250. Right now that truck would cost me 45k in the configurator for a 2021 model so if they did not go nuts on price uptick or try to gouge me with market price adjustments its an awesome option.
    My Dodge was extremely reliable so the Ford horror stories scare me to death. I do all my own maintenance and most repairs and am worried about a brand new engine and transmission in their 1st year with the Tundra. I am handy but am not fixing tranny's or serious engine/turbo work in my garage. Do you think the 1st year will be a bunch of recalls and issues and will the thing last? My dodge had over 200k when they towed it away. If the price is right, the Tundra will be my next truck and I am worried about expected teething problems and their long term impacts.
    Thanks everyone
  13. Oct 14, 2021 at 12:39 PM
    almightydollar
    almightydollar New Member
    2015 4-Runner Limited
    Still trying to figure out why they thought it was a good idea to add a splash of silver to the grill surround
    Radworker, JuicyJ and Armstrs like this.
  14. Oct 14, 2021 at 12:41 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Nuggets of interesting technical knowledge but omg the yelling!
  15. Oct 14, 2021 at 12:43 PM
    balong48
    balong48 New Member
    2011 Classic Silver Metallic 4Runner Limited
    Sweers wanted the truck to have facial hair cause he does
  16. Oct 14, 2021 at 12:48 PM
    Jaxyaks
    Jaxyaks New Member
    Any reason you didn't look at a Ram 2500 with the 6.4? It has the coil link suspension and rides very nice for a 3/4 ton truck, you can also get 14K towing with the 4:10 gears. If your looking for a heavy towing gas truck, you may want to make sure to drive a Ford with the 7.3...its a whole other animal for gas powered HD trucks....
    Hammerdog likes this.
  17. Oct 14, 2021 at 1:00 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I will admit the upper level rams are really nice looking, but I still am hesitant to seriously look at them. My bil bought his ram about a month after I bought my Tundra in 16. My Tundra is still like new except for a few scratches, his truck is a pos. Paint is peeling off, rattles, etc. It just has not held up longterm like my Tundra. If I bought a new truck every 2-3 years I would look at them, but I want to keep my trucks for 10 years and to me Tundras are the best choice for that.
  18. Oct 14, 2021 at 1:03 PM
    Outbound
    Aaron
    Northern Alberta
    I don't get it either. Frig off with the chrome! If I were to buy a new truck from the dealer, I'd have them swap that surround out for a color matched one before I took delivery. They can send the chrome back to Sweers or whoever thought it was a good idea with a note that says "stick this where the sun don't shine so it'll stop blinding us!"
    JuicyJ, BSW9 and Breathing Borla like this.
  19. Oct 14, 2021 at 1:11 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    :crapstorm:
    I blacked out this truck so my next one will most likely have chrome. All depends on the colour - it really looked dumb on my Inferno one when I bought it, but on a deep red or blue I really like it.
    No way they can make everyone happy with only 10 or so trim and package combos. Hell Ford has about 100 and people still do their own tweaking after buying.
  20. Oct 14, 2021 at 1:12 PM
    matthinkle
    matthinkle New Member
    Lighthouse Point, FL
    2022 1794 Hybrid
    This is why I can't wait for the configurator. Just let me go play around and figure out how I best like it.
  21. Oct 14, 2021 at 1:14 PM
    gunmetalgolfer
    I did and I do like it, alot. The ride was real good, better than the F150 stock (non max tow). The main reason I can't buy a Ram, RUST!!! Loved my 98 Dodge but the front doors were rusted through (6-12 inches of the bottoms were just gone), the bed rusted off and was welded and tacked back on twice as the mounting holes rusted away from the connectors, my tailgate was swiss cheese and I had no wheel wells. Wheel wells were gone after 10 years, I barely remember what the truck looked like with them.
    I am not a Ford fan at all (don't want to be), but I do believe the aluminum will not rust and I believe the steel still will rust just as bad given the same New England weather conditions over the next 20 years. So the Tundra composite bed with aluminum supports, HUGE plus. Aluminum front doors and hood, big plus. Fender flares on the Tundra are plastic so as long as they are well made I won't have two 5 inch, 3 foot long semi circles over my wheels with duct tape on them to pass inspection. Not sure what the tailgate is made of (don't see that posted anywhere) but that could still be a problem but better than everything rusting.
    Having said that I did test several Ram 2500's, again the base model had no adjustable seat (WTF) so a Bighorn lightly optioned was 53k with the 6.4. Thats still 8k more than the current Tundra (2021 prices) and no LED headlights which should be standard these days. I doubt I would do the 4.10's but the 3.73's still get 14k on towing and payload was similar to Ford at about 2900 for the one I drove. Definitely an option but everytime I drive down the road and see a truck with no wheel wells or a rusted door frame/tailgate I feel like someone is trying to tell me to NOT do that again.
    Tundrastruck91 and Acedude like this.
  22. Oct 14, 2021 at 1:21 PM
    matthinkle
    2022 1794 Hybrid
    On the Tacomas with the composite bed, do those owners do a bed mat or a liner or anything? Or do they just leave it as-is?
  23. Oct 14, 2021 at 1:22 PM
    styner1989
    styner1989 Member
    I had bed mat in the tacomas I owned. I could not handle how much stuff slides around without it.
    TexAggie and matthinkle[QUOTED] like this.
  24. Oct 14, 2021 at 1:22 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I did bed mat when I had mine. They are SLICK. If you don't have a mat, you have to tie everything down. Didnt have any issues with the bed except how slick it was. But I also have a mat in my Tundra with a spray in liner for the same reason.
    TexAggie likes this.
  25. Oct 14, 2021 at 1:29 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I crack my bed when I throw a cinder block into my bed and it’s so slick you could ice skate inside the bed with socks
  26. Oct 14, 2021 at 1:34 PM
    matthinkle
    2022 1794 Hybrid
    Thanks. I was going to add the rubber interior mats. I'll add a bed mat to the order when I get the truck.
  27. Oct 14, 2021 at 1:37 PM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    I will never own another truck without the rubber interior mats.
  28. Oct 14, 2021 at 1:38 PM
    matthinkle
    2022 1794 Hybrid
    I don't even live in a place with snow and I love them. I can't even imagine what it'd be like with cloth mats in winter.
  29. Oct 14, 2021 at 1:40 PM
    moobaru
    moobaru Old geezer
    2022 F350 Power Stroke Tremor
    Rains a lot around where I live, they are great for muddy boots/shoes.
  30. Oct 14, 2021 at 1:45 PM
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Just spoke to my dealer. There will be no special ordering. The only option I have is to hope one comes in before 12/31 and just take it. For tax reasons I need to take delivery before EOY. Need a back up plan. Any ideas? 2500 GMC at4? ram 2500?
    ColoradoTJ likes this.
Thread Status:
