2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Oct 12, 2021 at 8:46 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Where the crawl control Tacoma TRD off-road have crawl control
  2. Oct 12, 2021 at 8:47 AM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    The yellow sticker is the real payload. it includes all factory installed options and will reduce above payloads.
    GODZILLA and Cpl_Punishment like this.
  3. Oct 12, 2021 at 8:48 AM
    07TT
    07TT New Member
    Michael
    ‘07 Slate Blue levelling risers and only Gdyr Duratracks
    levelling risers and only Gdyr Duratracks, Xliner, xtang tourneau cover,
    Supra. My bad.
  4. Oct 12, 2021 at 8:48 AM
    Tundratic
    Tundratic New (ish) member
    Canada
    2010 SR5 TRD OR 2023 Limited TRD OR
    Not that it’s a huge improvement, but Andre from TFL did the 0-60 in 6.8s in the TRD pro.
    keeping in mind Ford’s well documented history of fudging their payload/towing numbers, I wouldn’t be shocked if their 0-60 times were just as “accurate”.
    probably pushed it out the back of a plane for their test
    (relax f150 owners, ‘twas a joke)
    RavingOx, Terndrerrr, Oey12 and 4 others like this.
  5. Oct 12, 2021 at 8:50 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    The spec sheet says otherwise right now. I think we are hoping it is a misprint like no TRD Offroad option for Limited 4x4. Spec sheets have been wrong before!
    ff4life4 and GO.XPLRE like this.
  6. Oct 12, 2021 at 8:51 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Hom much does a comparable Ford Powerboost in Platinum/King Ranch/Limited trim cost?
    How much does a Ram Limited 1500 with option cost?
    How much is a GMC 1500 Dierra Denali?
  7. Oct 12, 2021 at 8:51 AM
    Baldwin
    Baldwin New Member
    Only at highway speeds
    worktruckwhite likes this.
  8. Oct 12, 2021 at 8:51 AM
    07TT
    07TT New Member
    Michael
    Isn’t the Lexus 400 a V8?
  9. Oct 12, 2021 at 8:52 AM
    worktruckwhite
    worktruckwhite bryceCtravels.com
    Charleston, SC
    2010 White Crewmax
    At this rate I'm planning on swapping in another engine, tranny, or frame. Whichever goes first! Never selling this truck now.
    Tundrastruck91, trekkar and JJtruckon like this.
  10. Oct 12, 2021 at 8:53 AM
    UATundra
    UATundra New Member
    Yeah I understand that, I was just asking because the document you posted Toyota states that the max payload for a 4x4 crew cab is 1,810-1,885 lbs. I'm surprised that a stripped limited could be that high honestly. I guess they're referring to a SR or SR5.
  11. Oct 12, 2021 at 8:55 AM
    rideandfly
    rideandfly New Member
    Having maximum torque 405 lb ft torque @ 2000RPM and maximum 348HP at 2400RPM with a gas engine would work well towing my 4900 pound travel trailer
    Acedude and The Simple Engineer like this.
  12. Oct 12, 2021 at 8:55 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    Man you better watch saying that in here, I got chastised for saying the double cab we looking like it would offer less room then the current gen. Looks like that's what it will turn out to be though, including the crew Max losing a little room as well.
    ff4life4 likes this.
  13. Oct 12, 2021 at 8:57 AM
    Tundratic
    Canada
    Not to worry. It says it right on the spec sheet you posted in brackets (Crewmax only).
    There’s been lots of videos online that have been showing the SR5 Crewmax with the power vertical rear window. It’s there, just in the Crewmax not the DC, same as 2 and 2.5 Gen.
  14. Oct 12, 2021 at 8:58 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  15. Oct 12, 2021 at 8:58 AM
    knoxville36
    Knoxville, TN
    A Chevy 1500 in WT trim, double cab/standard bed, comes in at $41,800 MSRP. That is the ugly rubber interior, no frills as basic as you can get with a little 2.7 or 4.3 V6 and comparable to an SR.
    Sadly enough the SR, has more features and is much nicer.
    I don't like the prices either, but the world we live in.
    Acedude likes this.
  16. Oct 12, 2021 at 8:58 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
  17. Oct 12, 2021 at 8:59 AM
    Hextorm
    Hextorm New Member
    Blake
    White 2022 Tundra TRD Sport CrewMax
    Well the King Ranch and Platinum are in the mid 60s MSRP. Limited is the only one that crosses the $70k mark.
    The only Ram that crosses the $70k mark is the Raptor, and most other trims are at lower than $60k.
    Denali's are in the mid 60s range as well for MSRP.
    All manufactures also have entry points in the low 30s which is nowhere near the $40k mark you're claiming. You're dealer buddy is wrong and off by at least $5k across all trims. Wait and see.
  18. Oct 12, 2021 at 9:04 AM
    trazerr
    trazerr New Member
    Oregon
    The "-" means that option is not available in that trim though. Yes, we see/know its only on the crewmax. Thats why right above it it has double cab only in brackets for the small slider. DC gets small slider. Crewmax gets vertical slider (trim dependent per spec sheet).
    We have seen the SR5 with it in videos so that is why we think it was an error in the spec sheet. It still makes us all wonder though.
    Cpl_Punishment and ff4life4 like this.
  19. Oct 12, 2021 at 9:04 AM
    stecky
    stecky Tech Geek
    Dallas, TX
    2021 Nightshade CM MGM
    Acedude likes this.
  20. Oct 12, 2021 at 9:09 AM
    Hextorm
    Hextorm New Member
    Blake
    Did you miss the part where they said it was showing Prius levels of MPG but they couldn't tell if it was accurate because the whole system is pre-production and was acting different?
    g6t9ed and doublethebass like this.
  21. Oct 12, 2021 at 9:12 AM
    Baldwin
    Baldwin New Member
    Thats like 40MPG. Must be a very narrow sample window to get that average.
    I believe they did mention in that video that the EV mode can kick in on the highway? I was surprised to hear that.
    Tundra4Runner likes this.
  22. Oct 12, 2021 at 9:15 AM
    Hextorm
    Hextorm New Member
    Blake
    Yeah I think it just proves that the entire dash numbers are still wonky and we shouldn't put any weight into them at all. It's nearly full and showing less 400 miles of range, and we know the tank size is 32 gallons so quick napkin math is estimating 12 mpg. That's obviously way off.
    Breathing Borla likes this.
  23. Oct 12, 2021 at 9:16 AM
    Jerry Atric
    Jerry Atric New Member
    I'm lost? 632km is 392.7 miles. 392.7 divided by 32 gallons (tanks size) is 12.25mpg?
  24. Oct 12, 2021 at 9:16 AM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    How'd you figure 40mpg?
  25. Oct 12, 2021 at 9:17 AM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    Negative.
  26. Oct 12, 2021 at 9:17 AM
    moobaru
    moobaru Old geezer
    2022 F350 Power Stroke Tremor
    In Canadialand fuel is calculated liters per 100KM so you can convert that to MPG.
    JuicyJ, GODZILLA and rocky.mtn like this.
  27. Oct 12, 2021 at 9:18 AM
    Tamadrummer88
    Tamadrummer88 New Member
    Soon to be 2022 or 2023 Tundra, 2020 Camry Hybrid, 2020 4Runner TRD Pro
    Pretty common with hybrids. My Camry Hybrid can coast in EV mode on the Highway and I can keep it there by feathering the throttle, but only for a very short period.
  28. Oct 12, 2021 at 9:20 AM
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    I get that but what's on the screen isn't calculating to 40mpg.
  29. Oct 12, 2021 at 9:23 AM
    moobaru
    moobaru Old geezer
  30. Oct 12, 2021 at 9:23 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought there was talk of an SR5 TRD OR package a while back. Maybe even some pre-production trucks that were shown?
Thread Status:
