2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Oct 12, 2021 at 6:31 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    I am not arguing your point. I believe everything you said is spot on. There is nothing offered that will make me get into a new Tundra.
    But when it’s time to purchase a new Tundra I would appreciate the gains…
  2. Oct 12, 2021 at 6:32 AM
    Same.
    Cpl_Punishment and Oey12[QUOTED] like this.
  3. Oct 12, 2021 at 6:38 AM
    moobaru
    moobaru Old geezer
    2022 F350 Power Stroke Tremor
    Angle of Approach/ Departure
    21.0/24.0 (Standard)
    26.2/24.2 (TRD Pro)
    craigy, Acedude and ryanwgregg like this.
  4. Oct 12, 2021 at 6:57 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Since HP=Torque*RPM/5252 they absolutely are. If diesel's could rev higher they would have massive HP numbers. Torque indicates how you off the line until the engine gets revved up, essentially in the 2-3k range, then it's HP that will be the better indicator.
    Looking at those 0-60 numbers it's clear the hybrid unit is clearly just a supplement to the gas engine and does not produce much drive. IMO this works much better for real life situations - how much does it matter how you get off the line? What matters much more is how it picks up when you're already at speed - whether it's to pass someone or to keep momentum going up a hill. The Toyota hybrid is all about function over style
    Acedude and Cpl_Punishment like this.
  5. Oct 12, 2021 at 6:58 AM
    moobaru
    moobaru Old geezer
    After looking at the spec sheet and standard features and options packages doesn't look like I will going with the Pro anymore.
    JuicyJ likes this.
  6. Oct 12, 2021 at 6:59 AM
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    I didn’t read that whole article, but as a counter argument, here is a video I didn’t watch completely either. Around the 4 minute mark I heard words that sounded like I was right.
    I’m pretty sure this is how internet disagreements are settled…
    GODZILLA and matthinkle like this.
  7. Oct 12, 2021 at 7:07 AM
    matthinkle
    matthinkle New Member
    Lighthouse Point, FL
    2022 1794 Hybrid
    I feel like I'm at the paralysis of the analysis stage. Every couple weeks I feel like I'm trying to read the tea leaves when these videos come out. I think I'm ready to just go drive the damn thing, see it in person, and stop comparing it to the F150.
  8. Oct 12, 2021 at 7:08 AM
    stecky
    stecky Tech Geek
    Dallas, TX
    2021 Nightshade CM MGM
    lol... could be
    GODZILLA likes this.
  9. Oct 12, 2021 at 7:09 AM
    moobaru
    moobaru Old geezer
    Payload
    4x2 Double Cab 1,860 – 1,940
    4x2 CrewMax 1,640 – 1,830
    4x4 Double Cab 1,810 – 1,885
    4x4 CrewMax 1,575 - 1,820
    TRD PRO: 1,600
    Sorry if formatting is messed up, I tried to get it lined up. Edit: It didn't keep my formatting
    ryanwgregg, Toyota1234 and matthinkle like this.
  10. Oct 12, 2021 at 7:16 AM
    moobaru
    moobaru Old geezer
    Another argument here is which fuel is required. From the Specs PDF
    Recommended Fuel 87-octane or higher
  11. Oct 12, 2021 at 7:18 AM
    Hextorm
    Hextorm New Member
    Blake
    White 2022 Tundra TRD Sport CrewMax
    No one buying the new model is doing it for gas savings alone. There are a lot of factors. Plus, this is the non-hybrid, so if gas savings is a big deal to you just go for the hybrid which will have even better numbers.
  12. Oct 12, 2021 at 7:22 AM
    Hextorm
    Hextorm New Member
    Blake
    No argument. 87 is fine. If you really care about HP and Torque you could probably squeeze a few extra out with buying premium, but it's not needed. Same as every other vehicle really.
  13. Oct 12, 2021 at 7:22 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    g6t9ed and Acedude like this.
  14. Oct 12, 2021 at 7:23 AM
    No one who thinks beyond the end of their nose is buying just for gas savings, but I promise you, there are plenty of idiots that do this. As far as the hybrid, current speculation is that it is geared more toward adding grunt than efficiency, so until it's mileage is known it is all speculation.
    Cpl_Punishment likes this.
  15. Oct 12, 2021 at 7:25 AM
    Hextorm
    Hextorm New Member
    Blake
    You lose an inch and half of headroom with the pano moonroof.
  16. Oct 12, 2021 at 7:26 AM
    All sun/moon/pano roofs cost headspace. They have to put the mechanicals for sliding and storage somewhere, and they aren't going to put a tumor on the outside of the roof for it.
    Terndrerrr, Cpl_Punishment and stecky like this.
  17. Oct 12, 2021 at 7:29 AM
    Hextorm
    Hextorm New Member
    Blake
    I'm aware of the reasoning. Just pointing out things I'm noticing from the spec sheet.
    Tundrastruck91 and deptrai like this.
  18. Oct 12, 2021 at 7:29 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Tundra'25 likes this.
  19. Oct 12, 2021 at 7:30 AM
    Hextorm
    Hextorm New Member
    Blake
    No active active aero on TRD Pro or SR models, standard on all others.
  20. Oct 12, 2021 at 7:31 AM
    Hextorm
    Hextorm New Member
    Blake
    Tow mirrors are a stand alone option on all trims except TRD Pro
    JuicyJ and Cpl_Punishment like this.
  21. Oct 12, 2021 at 7:32 AM
    moobaru
    moobaru Old geezer
    Didn't they say the back seat was a bit higher with the hybrid too? I think I remember them saying that but I didn't see it on the specs sheet. If it is true that will make the headroom even worse in the hybrid. (I know we have seen it in videos before but no actual measurement)
  22. Oct 12, 2021 at 7:34 AM
    Hextorm
    Hextorm New Member
    Blake
    I thought that too but there's not a difference on the spec sheet for hybrid vs. non hybrid, only crew max vs. double cab.
  23. Oct 12, 2021 at 7:36 AM
    moobaru
    moobaru Old geezer
    I'm also surprised that the HUD is not available on the Pro.
  24. Oct 12, 2021 at 7:36 AM
    Baldwin
    Baldwin New Member
    Be careful with those power delpoyed running boards on the Platinum and 1794. Coming from a current F150 owner here. They look to be the same running board manufacturer and are very prone to seizing up. I soak mine in penetrating oil every few months.
    Tundrastruck91, Acedude and JuicyJ like this.
  25. Oct 12, 2021 at 7:36 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Nice as long as SR5 have it
  26. Oct 12, 2021 at 7:38 AM
    Hextorm
    Hextorm New Member
    Blake
    I noticed that none of the testers thus far have had it. No one has really even mentioned it which is surprising because I really like HUDs a lot. What's crazy is it's not standard on any of the trims.
  27. Oct 12, 2021 at 7:39 AM
    Xspurt
    Xspurt New Member
    Looks like they're offering TWO sizes of sunroof but if I'm reading it right the normal, non-pano roof is limited to the Limited. I was thinking 1794 but now maybe a loaded up Limited. I do trust Toyota's engineering of the pano more than the big 3 but I'd still prefer a single pane roof with a manual sunshade.
    So now we wait (and throw out incredible, endless guesses) for the MPG numbers on the hybrid. That is a nice increase for the standard though, I hope there are no real gotchas but only time will tell.
    Very sorry to see no blue offerings. Dark blue is too close to black for me so pass on that. Why do car makers hate lighter blues (don't answer, I'm just lamenting).
  28. Oct 12, 2021 at 7:41 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Interesting that the SR gets a de-tuned engine. Guess for fleet vehicles?
    Acedude, Tundra'25 and rideandfly like this.
  29. Oct 12, 2021 at 7:43 AM
    matthinkle
    2022 1794 Hybrid
    I might be alone in this sentiment, but I feel like good electric trucks with 500 miles of range can't come soon enough. We're maybe gaining 5 mpg from the hybrid?
    Treadlife likes this.
  30. Oct 12, 2021 at 7:43 AM
    stecky
    stecky Tech Geek
    Dallas, TX
    Notable that memory seats isn't available on Limited since pre-production Limiteds had memory seats.
    Also, I don't see anything about memory side mirrors.
Thread Status:
