2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Oct 4, 2021 at 3:32 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    But it clearly says TRD OR... If it was a Pro, they would have said so.
  2. Oct 4, 2021 at 3:36 PM
    D_GOOSE
    D_GOOSE New Member
    Agreed but they show the pro...again I doubt it's the PRO but I can a hope right?
    Also a V6 has to cost less than a V8 motor even with twin turbos???
  3. Oct 4, 2021 at 3:43 PM
    D_GOOSE
    D_GOOSE New Member
    I think we will see the PRO around 60k MSRP
    trekkar and Dilleytech like this.
  4. Oct 4, 2021 at 4:19 PM
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
    Drive a Toyota Hybrid? The hybrid system is constantly being used at all speeds. My wife’s RAV4 for example, on a long slight down hill at 60-70 mph it will at times only be electric. 0-25 mph it’s often only electric, if your easy on the gas pedal. I know the Tundra is an entirely different animal but I can assure you the Tundra Hybrid system will be used extensively at all speeds.
    TK1979 likes this.
  5. Oct 4, 2021 at 4:21 PM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Good point.
    Damn it! I should've known that.
    I guess I know what side of the bell curve I am on.
  6. Oct 4, 2021 at 4:41 PM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Local radio station runs promotions here for a free f-150 valued up to $52k or whatever. The flyer has pictures of an F-150 Lariat. However it is for a stripped down base model XLT with MSRP of $37k or so. Several other of these sweepstakes do the same thing.
    The TRD OR advertised is probably the lowest trim TRD OR package you can get. So this tells me a SR5 TRD OR will be in the mid fifties.
    The new Pro will not sniff $56k MSRP.
    Cpl_Punishment and JuicyJ like this.
  7. Oct 4, 2021 at 4:45 PM
    JuicyJ
    JuicyJ New Member
    I noticed that the SR5 is extremely well equipped now, I saw 14" infotainment, front camera, LED headlights, LED fogs, heated seats.....
    Wouldn't surprise me if it's the most expensive "SR5" ever, by several thousand dollars
  8. Oct 4, 2021 at 5:06 PM
    FO LO
    FO LO New Member
    17 CM w/ 5.7 and 4.30s
    How am I supposed to put a brush guard on this thing with all the standard sensors and lazers?? I still want to be able to use cruise...
  9. Oct 4, 2021 at 5:15 PM
    Topherwv
    Topherwv New Member
    Yes, it was confirmed that the limited use of the battery was Fake News.
    Tundra'25 and TK1979 like this.
  10. Oct 4, 2021 at 5:27 PM
    4WDWalrus
    4WDWalrus New Member
    The Silver Walrus
    TRD shift knob OEM Fender Flares Truxedo Pro X15
  11. Oct 4, 2021 at 5:27 PM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Make it out of PVC? :notsure:
  12. Oct 4, 2021 at 5:32 PM
    JuicyJ
    JuicyJ New Member
    How long do you think a hybrid system with a tiny 1.8kW/hr can contribute to towing, up an extended grade?
    For reference, 1.8kW is slightly more than a toaster oven.
    I can't wait until TFL takes it on the Ike Gauntlet and the hybrid system gives up in less than 5 minutes.
    The Simple Engineer likes this.
  13. Oct 4, 2021 at 5:34 PM
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    One thing I noticed in this video when the driver says to passenger that you have to slam door, is it didn't sound 'heavy' !? I know they said TRD Pro has Aluminum doors, is that the same on all trims ? ... there was a video from the debut on the blue Platinum model where the driver noticed and said when he closed the door .."it sounds like getting into a tank" and seemed really well insulated and quiet from inside.
  14. Oct 4, 2021 at 5:35 PM
    JuicyJ
    JuicyJ New Member
    The chassis was under bending force, that's why the door didn't close as expected
  15. Oct 4, 2021 at 5:37 PM
    Topherwv
    Topherwv New Member
    Yeah, I don't know. I'm not going to read too much into anything until I see it put through it's paces.
    JuicyJ[QUOTED] likes this.
  16. Oct 4, 2021 at 5:41 PM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    It's bigger than the Ford powerboost which is only 1.5 kWh. I think you are confusing kw or watts which is the power and kwh which is the storage capacity.
  17. Oct 4, 2021 at 5:43 PM
    JuicyJ
    JuicyJ New Member
    I'm not confused.
    I know exactly what kW/hr means.
    sleepybear723 likes this.
  18. Oct 4, 2021 at 5:46 PM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    That's what I did when I bought my 17' and I saved a good bit over what dealers around me wanted.
    Rust and toyota frames is nothing new, if your not heavy on preventative maintenance its pretty bad on the yota's. Not saying there are not exceptions but they tend to be pretty bad.
  19. Oct 4, 2021 at 5:55 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I wonder if Toyota said the IForce Max can be hybrid only up to 18 mph and some YouTuber misinterpreted that as the hybrid only works up to 18 mph.
    RavingOx and stecky like this.
  20. Oct 4, 2021 at 6:05 PM
    Roverwest
    Roverwest New Member
    13 FJ Trail Team
    I didn't know something like that existed. My tint guy cuts it manually. He tints for several of the dealers around me. Dude is good. Comes to your house and costs like 80 to do two front windows. Takes him about 30 minutes. Did my wife's car 6 years ago and still looks like new.
    JuicyJ likes this.
  21. Oct 4, 2021 at 6:29 PM
    Jaxyaks
    Jaxyaks New Member
    The electric motor can run the truck without the gas engine up to 18mph at 18mph the gas engine kicks in. To me a more ideal set up would be able to use just the electric motor up to 35/40 mph. (around town speeds) and then have the engine kick in.
  22. Oct 4, 2021 at 6:30 PM
    Tundratic
    Tundratic New (ish) member
    Canada
    2010 SR5 TRD OR 2023 Limited TRD OR
    Apologies if this was already posted. Hard to keep up!
    But interesting break down of sales numbers and how each company is affected by supply chain shortages:
    https://youtu.be/wExKP2ziqzM
    edit:
    Coles Notes: Toyota and a few other imports are crushing it, so don’t panic too much.
    Oh and RIP infinity
  23. Oct 4, 2021 at 6:35 PM
    Pipo6007
    Pipo6007 New Member
    South Florida
    2021 Lunar Rock TRD PRO
    Line X and BAK flip
    My 2021 does the same thing on the flat pavement. They are not heavy doors that’s for sure.
  24. Oct 4, 2021 at 6:58 PM
    JuicyJ
    JuicyJ New Member
    Tundra'25 and TexAggie[QUOTED] like this.
  25. Oct 4, 2021 at 7:05 PM
    backlash
    backlash New Member
    Nick
    Does anyone have experience with aluminum body panels? How much easier do they dent than steel panels?
  26. Oct 4, 2021 at 7:05 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    In the case of my truck, if the HVAC fan is on, the doors require more effort to close due to the positive air pressure in the cab. If another door or a window is open, it requires far less effort to close the door as the compressed air has a path out of the cab.
  27. Oct 4, 2021 at 7:44 PM
    RavingOx
    RavingOx Member
    WNC
    2022 Tundra Platinum in Black
    No, no, no…everyone is getting this wrong. Toyota said the hybrid can only go 18mph. And they don’t mean “up to 18mph,” they mean exactly 18mph. You press the gas and instantaneously you’re going 18mph. How fast do you want to go? Well, Toyota talked to real truck owners and the only thing they could agree on was 18mph. Forward? 18mph. Reverse? 18pmh. Towing? 18mph. Want to go a a different speed? No, you want to go 18mph!
  28. Oct 4, 2021 at 8:01 PM
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    Probably was embarrassed about getting the stats wrong….
  29. Oct 4, 2021 at 8:18 PM
    lrtexasman
    lrtexasman New Member
    Larry
    Rockwall, Texas
    2023 Tundra Crew Limited 4x4
    Ford charges more for the 3.5 TT than they do the 5.0.
  30. Oct 4, 2021 at 10:19 PM
    Dano84
    Dano84 New Member
    You'll just pay alot more for a properly designed bumper that will relocate said sensors and radar.
    Tundra'25 and Tamadrummer88 like this.
Thread Status:
