2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Sep 7, 2021 at 8:39 AM
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    The 6MT is way better - I’ve put a lot of miles on both 50k AT, 117k+ MT
    If toyota swapped the factory gearing in the AT from 3.91 to 4.88, it would make a world of difference. The AT and MT feel like completely different trucks. Hard to believe it’s the same motor.
    JuicyJ[QUOTED] likes this.
  2. Sep 7, 2021 at 9:00 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I've read before that Toyota typically run rich which helps with reliability.
    JuicyJ and Ace402[QUOTED] like this.
  3. Sep 7, 2021 at 9:00 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I must have missed that you use it for hunting. Can't hunt out of a 4R?
  4. Sep 7, 2021 at 9:38 AM
    tonychap33
    tonychap33 New Member
    Tony
    I've heard in the next 2 weeks it will be revealed, I'm ready to order now!
  5. Sep 7, 2021 at 9:45 AM
    Pine Tree State
    Pine Tree State New Member
    2021 SR5 TRD Sport CM
    70mph in my Taco was 18mpg. My 55mph commute was 24mpg. When I sold the truck at ~45,000 miles the lifetime average MPG was 22.5
    Elevatormatt and NewImprovedRon like this.
  6. Sep 7, 2021 at 9:46 AM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    The 10 speed negates the need for multiple rear end gears - want better fuel economy ECO mode can push for higher gear selection, go into towing it picks the right RPM range for torque, go into sport and it picks the gears based on max HP.
    The difference the other manufacturers get with the fuel economy is because they use the same transmission. With 4 speed and even 6's it really made a huge difference to pick the right rear end. With 10's the rear end selection won't change performance very much because there's so many combinations that the same rear end gear can do all power, torque, and fuel economy.
    The biggest hurdle for the Tundra fuel economy is how draggy the driveline is. Take your foot off the gas at 65 and it feels like you hit the brakes and it slows to 40 right away. Take your foot off the gas at 65 in an F150 and it feels like the truck goes into neutral, it just coasts so effortlessly.
  7. Sep 7, 2021 at 9:48 AM
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    You just explained why Toyota is going with a TTV6. Those mpg numbers are lower than a HD 3/4 ton. Hopefully with this new engine and not always being in the boost it will get mid 20’s hwy, and 19-20 combined.
  8. Sep 7, 2021 at 10:08 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Well, the guy that test drove one for two weeks and his neighbors don't believe us :rolleyes:
    NewImprovedRon likes this.
  9. Sep 7, 2021 at 10:29 AM
    JuicyJ
    JuicyJ New Member
    We have 10AT 5.0 F-150s at work. They "hunt" often, but it's unnoticeable because the truck is so smooth, and the gears are close.
  10. Sep 7, 2021 at 10:31 AM
    JJtruckon
    JJ
    2018 Tundra
    Undercoating
    Sure, on a flat road with no head wind going 55 and resetting the trip meter. Yes 24 mpg. Any real world driving, the taco does not get 24 mpg hwy. You buy the taco for durability, not mpg or comfort. If the durability goes away, well…
    Westerntowboss likes this.
  11. Sep 7, 2021 at 10:34 AM
    BigArt
    BigArt New Member
    2008 Tundra Crewmax Limited
    No, it was posed in the 2022 Tundra section.
  12. Sep 7, 2021 at 10:34 AM
    Melikeymy beer
    Muscogee Nation
    You have had 3 people now with real world experience tell you what the mileage is under different driving conditions and all agree. Some people can not be helped.
  13. Sep 7, 2021 at 10:36 AM
    BayRunner
    2017 Tundra Platinum
    That’s because it was an agenda to simply discredit the Tacoma while ignoring the facts. As someone pointed out, something was wrong with that rental.
  14. Sep 7, 2021 at 10:38 AM
    Melikeymy beer
    Muscogee Nation
    That was me, and I was trying to be polite. I alluded earlier to some people that are "often wrong but never in doubt".
    Elevatormatt likes this.
  15. Sep 7, 2021 at 10:45 AM
    shellshock
    Iowa
    2019 TRD PRO
    low to mid 20s in a Tacoma is possible. I’ve got a couple tanks of 24+
    I average 20-22 mpg at 70 mph, at 55 it’ll be higher.
    I also know a bunch of guys struggling to get 15 mpg, but that’s what happens when you go 33-35s and add 1000+ lbs of weight
    these have a significant amount of stop and go city driving and still around 20
    Melikeymy beer likes this.
  16. Sep 7, 2021 at 10:46 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Yeesh, relax. There's no speculation, dude goes through a spec sheet posted on this board that lists the various 2022 models and options. He points out things that you probably never noticed when the spec sheet was posted here. I bet he's 100% correct, same as he's been in all of his videos I've seen.
    I don't know what you and your likers have against the guy. While posters here were posting ridiculously inaccurate speculation about the TNGA-F platform Chao calmly and accurately explained TNGA-F.
    Every Chao video I've seen has been accurate, I can't figure out where the hatred comes from. Do you have specific examples?
    MTRock, Coal Dragger and backlash like this.
  17. Sep 7, 2021 at 10:55 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I always get a kick out of people comparing mpg. I ran the number for a 21 tundra at 19mpg and the 22 at 25(dreaming of course) and it was around $570 a year if you drive 15k at $3 a gallon. And magazines always do this but never say the true figure. They just stick to mpg.
    Boerseun likes this.
  18. Sep 7, 2021 at 10:58 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I asked a marketing lady at the Toyota booth at the Cherry Creek Arts Festival this weekend when the new Tundra would be fully revealed. She said January :notsure::notsure::notsure::notsure::notsure:
    Black Wolf and Melikeymy beer like this.
  19. Sep 7, 2021 at 11:06 AM
    nodak67
    nodak67 New Member
    JR
    has anyone watched this video review of the 2021 tundra, the key take away was that he was heading out to plano texas to see the new 2022 tundra.
    i imagine he will be under an embargo until the 19 to release his review.
    quote from his post in comments...
    https://youtu.be/J7kVAI1c1JQ
  20. Sep 7, 2021 at 11:08 AM
    radon222
    radon222 '21 CrewMax / '18 4Runner
    Ed
    NW Arkansas
    2021 CrewMax TRD OffRoad
    Stock for now
    What's really funny is that had you watched the video you would have seen that his source of info came from right here! tundras.com :rofl:
    DoMoToyota and Acedude like this.
  21. Sep 7, 2021 at 11:09 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    Yeah, if you're in boost a lot from what I've seen with Ford 3.5's at fuelly.com the mpg isn't much better than the 5.7l Tundra. I have zero experience with turbo engines, but I did some research on Ford boards and what constantly comes up is "With the Ecoboost you get either Eco or Boost, can't get both at the same time." It's CAFE related, mfg's have to meet fleet standards tested at 55mph on flat ground at sea level.
  22. Sep 7, 2021 at 11:14 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought it was 48 mph.
  23. Sep 7, 2021 at 11:29 AM
    nodak67
    nodak67 New Member
    JR
    currently have a 2018 platinum. well pricing a 2021 platinum with the same options we have now runs up to 57k msrp (moonroof, classic running boards, front bumper/hood protection) and our 2018 was 53k msrp (before discounts, after discount it was 47.5k then trade in brought it down another 12k i think before tax credit for trade in). i imagine pricing will jump considerably since they are giving more options to add to the price. adding pano roof (i dont think they will offer the normal moonroof anymore), PVM, heated steering wheel and then the classic running boards, front bumper/hood protection will probably push the 2022 plat close to 60k. we have a budget of 65k depending on trade in value they give us for our 2018 plat with only 34k miles. we are betting on the low side of about 40k trade in value for ours, but i have seen a high of 43k.
  24. Sep 7, 2021 at 11:40 AM
    Terndrerrr
    Terndrerrr 925000 miles to go
    Music City
    6UR-FE
    Didn't we go through this already? I'll quote myself:
    Also, I remember this post from @50 Buck. I don't have a link to the video he's referring to though.
    g6t9ed, Roverwest, Black Wolf and 2 others like this.
  25. Sep 7, 2021 at 11:41 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    I don't know the exact testing specs but looking at fuelly.com for real world mpg's the Ford 3.5's the majority are about 3mpg's better compared to the Tundra 5.7l.
    Ford Ecoboost the majority are in the 17-19 mpg range, Tundra 14-17 range. As I've said before, I'll let the fearless among us here beta test the beast and decide if it's worth it to go from the V8 to the new platform.
  26. Sep 7, 2021 at 11:57 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    TFL just put out that they are going to exclusively reveal a new Truck on this Thursday. They wernt allowed to say the brand or clues. Just pointed to the Ram TRX when talking about this all new reveal.
    Some speculate it's the new Raptor. Others the new Tundra.
    https://youtu.be/vaBqxUZPfis
  27. Sep 7, 2021 at 12:00 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    This has to be photo shopped. Lol. Even with higher suspension and bigger tires. Looks nothing like the Pro picture floating around.
  28. Sep 7, 2021 at 12:09 PM
    He pretends to have scoops or more info than other sources. His video after the first official pic was released (white Pro) had a ton of shots of current gen trucks and features being presented as new. Extreme close ups on items that a non Tundra owner/enthusiast might not know are current tech. Then big super far off shots of trucks going on trails and hills from a distance that made them nearly impossible to identify.. It equates to a fan made trailer.
    In the comments of that video someone commented that they were hoping to see more interior shots. There were NO interior shots in the video from the new truck; only current gen. Did he clarify that it was fanmade and he had no more info than anyone else? Nope! The lying sack actually said he had MORE interior shots and had forgotten to include them. He never had sh*t and he's deceptive for the sake of trying to run up views. He's a hack and will get no views from me.
    g6t9ed, deptrai, Black Wolf and 2 others like this.
  29. Sep 7, 2021 at 12:11 PM
    Melikeymy beer
    Muscogee Nation
    Go back and ask her what MPG her 3rd gen Tacoma gets.
  30. Sep 7, 2021 at 12:11 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    This is why I stick to the only guy on YouTube who knows trucks: Zip Ties and Bias Plies! :muscleflexing:
    Warreng, Gray223 and Terndrerrr like this.
Thread Status:
