2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Aug 24, 2021 at 4:34 PM
    r1ch999999
    r1ch999999 New Member
    Rich
    I had a Focus for about 6 months before it qualified as a lemon. It had a video in jack, I could watch movies on it. It was crappy resolution, but it worked.
  2. Aug 24, 2021 at 4:39 PM
    Tundra TTH
    Tundra TTH New Member
    Nope. Same 6 speed they had for years
    Cpl_Punishment likes this.
  3. Aug 24, 2021 at 5:13 PM
    Blitz79
    Blitz79 New Member
    Dang! I was hoping for more pics today.
  4. Aug 24, 2021 at 5:21 PM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    We need better emojis. This site needs a bull emoji, a poop emoji, and udders emoji (cause Toyota is milking the crap out of this release)
    Ahab and ZappBrannigan like this.
  5. Aug 24, 2021 at 5:54 PM
    GaryC
    GaryC New Member
    Kicking an old post but I've gotta ask where guys come up with silly stuff like this? On what do you base your claim that "you're likely to experience serious issues with the induction system"? After owning several vehicles with intercooled turbochargers I've never had to do one single bit of maintenance to the induction systems, and one of them is right at 400,000 miles now. I have changed the air filter about 10 times in that one, I suppose that's the fault of the turbo also?
    Turbos don't wear out any faster than anything else on the vehicle and intercoolers don't get clogged with oil on any properly designed engine. Same thing with leaks and "boost drops off" whatever that means. Sure, it's mechanical and things can break, but they're not any more prone to breakage than the induction system on your 5.7.
    This is right up there with worrying about your muffler bearings failing.
  6. Aug 24, 2021 at 6:07 PM
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    If true this would be huge. Most of us are expecting 6 to 8 months delay at least between introduction and the hybrid being available.
    Now for you to find out if it's a PHEV or just a regular one
  7. Aug 24, 2021 at 6:13 PM
    ezdog
    ezdog New Member
    Gateway To The West
    I tried to get this answer for sure but they just do not know enough details yet. He does think he will be able to test drive a truck next month at a dealer show though which if true is also pretty huge!
    We spoke the other day at some length and then again Today and I tried pretty hard to pry more details out but I am fairly sure if he knows anything else that he would tell me too.
    He is also expecting to get pricing next month.
  8. Aug 24, 2021 at 6:35 PM
    FortyNorth
    FortyNorth New Member
    Northern ON
    2014 Tundra Super White SR5
    Wallygator and g6t9ed[QUOTED] like this.
  9. Aug 24, 2021 at 9:06 PM
    JuicyJ
    JuicyJ New Member
    Uh, I used to be an ASE mechanic....so, I worked on cars for a living throughout the 90's into early 2000's.
    And a boosted engine at 400K with no work needed?? Is it an old Ford 7.3 or something?
    Your post is condescending of my experience and I think you fancy yourself a SME
  10. Aug 24, 2021 at 10:04 PM
    ZappBrannigan
    Canada, by way of Hawaii
    2018 1794 MGM
    NVS light bar
    Visit a Subaru forum. That should answer your initial question.
    Wallygator, JuicyJ and Cpl_Punishment like this.
  11. Aug 24, 2021 at 10:08 PM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    The current pool of V35A-FTS engines in service is pretty small being only offered in one single slow selling Lexus sedan. Tough to draw any durability conclusions off of the current data set.
    A lot of computer controlled waste gates on modern turbos have a bad habit of becoming rattle traps when the actuating components wear out.
    Otherwise the problem I’ve observed with turbo charged engines in service with high mileage is poor maintenance. My employer uses a 3rd party contractor to transport train crews to mines, hotels, etc and this contractor has quite a few Ford Expeditions in service. They see a lot of miles and a lot of idling, most are well north of 300K miles. The Fords with the 3.5L TTV6 do not last as long as the GM Suburban variants with the 5.3L NA V8 do.
    This contractor uses the cheapest oil they can buy, and does oil and filter changes on a schedule that isn’t frequent enough on the TTV6’s. At least that is my suspicion.
    A turbocharged engine is going to be less tolerant of poor quality lubricants and infrequent change intervals. Same story for a lot of engines with oil pressure activated cam phasing, or displacement on demand.
    Enthusiasts like we find on a forum probably won’t have a lot of problems because we usually keep up with OCI’s if not change oil sooner. The problem will be the Schmuckatelli’s of the world who don’t stay on top of these things and when they do remember go to Jiffy Lube for some mystery oil and bargain basement filter. Those folks are going to have problems keeping a TTV6 as trouble free as possible, especially since they’re used to Toyota products that have historically been pretty tolerant of more indifference (with some exceptions like the 3.0L and 3.3L V6).
  12. Aug 24, 2021 at 10:23 PM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    It’s a solid transmission, no complaints from me. I did a lot of research on it before buying one. Feels similar to the Tundra transmission except it doesn’t try to cook itself on mountain passes.
    :poking:
    ColoradoTJ and JJtruckon like this.
  13. Aug 25, 2021 at 5:30 AM
    Tundra TTH
    Didn’t realize that. That stinks. Surprised Allison let them do that, but I guess they wanted the other business. How does that come up in a meeting. We want to put your trademark badge on our truck, but we’re not going to use your transmission in the truck. What happens if the trans is a piece of crap, Allison’s brand suffers. GM’s 1/2 ton 8 and 10 speeds are far from stellar.
    Wallygator likes this.
  14. Aug 25, 2021 at 5:38 AM
    Tundra TTH
    Didn’t say it wasn’t a reliable transmission. Just would be nice to have a reliable 8-10 speed to help pick mileage up a little.
  15. Aug 25, 2021 at 5:45 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    Yeah, everyone loves to compliment my wood.
  16. Aug 25, 2021 at 8:02 AM
    BCTRD
    BCTRD New Member
    B.C.
    2021 MGM Tundra TRD Sport
    18"BBS Forged wheels, factory running boards, VLED's, Rigid Pro Led mod (D2 SAE), diff breather mod, Husky mats, DIY Cquartz UK 3.0, Husky liners, OCD organizers,
    Very well put and has been proven in the commercial marine industry as well.
    Anyone that runs their oil out to the max OCI or waits until the dipstick has color and consistency of Bunker C will assist in having the Consumer Reports idiots tripping over themselves to reduce the advertised reliability the new motors.
    Plugged VCT solenoids due to extended OCI's in some motors is a known issue.
    My brother's a mechanic and the shit people bring in for service wondering why it doesn't run or last would blow your mind.
    If this is going into the 2022 https://www.motorreviewer.com/engine.php?engine_id=192 and can get even close to 200,000 it may be a winner.
  17. Aug 25, 2021 at 8:56 AM
    Breathing Borla
    Northern Illinois
    I wonder if we are headed for premium fuel in this thing, thats like a full dollar more around here at times.
  18. Aug 25, 2021 at 9:03 AM
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    It’s a 7,000lb brick. I get 15mpg in mine and the ford 7.3 with the 10 speed doesn’t get any better mileage, so I’d rather have the reliable 6l90 tranny any day of the week.
  19. Aug 25, 2021 at 9:07 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought I heard of some guys struggling to tow 7000 lb campers with their 6.6 gassers and wondering if more gears would help.
  20. Aug 25, 2021 at 9:18 AM
    aggie_tundra
    2021 2500 Custom
    Nah. Mine is around 7,000-7,500lbs loaded and 32’ long and no issues.
  21. Aug 25, 2021 at 9:59 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    That's good. There was a thread on that issue at GM Trucks a while back but I'll be darned if I can find it now.
  22. Aug 25, 2021 at 10:07 AM
    WAtundra4x4
    WAtundra4x4 Retired from active retirement.
    Den
    Wet side WA
    2018 Cement Tundra TRD crewmax limited
    Forward looking camera, Stub Antenna, 3M clearshield. A few other non lifted items.
    my brother, RIP, was never a auto/truck enthusiast since his boss mustang. He had is for years but sold it after moving to NYC for awhile. One of his last cars was a Toyota Tercel. That beater would not die, deer wiped out his outside mirror after he stopped for it. The check engine light as far a he was concerned was when you added a quart of oil. He would leave his car by my house while he was traveling and working out of state. I changed the oil on it once, saw clumps of rust coming out…. A fresh batch of oil and it was purring along.
    I just wanted to say there are several thoughts of auto maintenance or lack of thoughts. I’d say the general population don’t give a crap as long as it runs and does not leave them stranded. The designers should build a bulletproof no frill car that just runs. My brother hated all the new electrical “features” on the newer cars.
  23. Aug 25, 2021 at 11:08 AM
    Cock-A-Doddle-Do
    Cock-A-Doddle-Do New Member
    Brett
    Cypress, Texas
    2021 TRD Off Road CM -Super White
    ^THIS^
  24. Aug 25, 2021 at 12:44 PM
    Coal Dragger
    Kung Fu Dick
    Allison doesn’t have much choice, they’re owned by GM.
  25. Aug 25, 2021 at 7:12 PM
    A-A-Ron
    Aaron
    Seattle
    It is rather Tundra like in approach, not the greatest mileage but reliable. I’m getting about 16mpg with commuting in a HD truck, can do a little better on long trips without my trailer. Probably too expensive and overkill to put the “Allison” on the 6.6 gas.
  26. Aug 25, 2021 at 7:16 PM
    18" TRD Off Road Wheels
    It'll probably be similar to what I've been told the Ecoboost says in the manual: Midgrade is ok to run, but for best performance (MPGs and towing) premium is recommended.
    ColoradoTJ and Wallygator like this.
  27. Aug 25, 2021 at 7:17 PM
    A-A-Ron
    Aaron
    Seattle
    Same for me. I could see someone complaining if they were over 10k in trailer weight though. I think it’s rated for up to a 16k 5th wheel, no way I would go close to that without a diesel.
  28. Aug 25, 2021 at 7:51 PM
    Tundra TTH
    When GM had the 8.1 it was an option. The 6.6 has 60 more hp and 10 lb/ft more torque then the 8.1 had. Question would be, how much and how many would opt for it.
  29. Aug 26, 2021 at 2:42 AM
    Wallygator
    Nice list of speculation. :thumbsup:
  30. Aug 26, 2021 at 5:42 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    Question: is the 3.5 a timing chain or belt ? (hoping chain)
Thread Status:
