2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Aug 10, 2021 at 9:29 AM
    Jaxyaks
    Jaxyaks New Member
    The only problem with that is that you can't use that higher payload without bracing it up...lol
  2. Aug 10, 2021 at 9:32 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    This truck isn't going to be about that...
    Melikeymy beer likes this.
  3. Aug 10, 2021 at 9:35 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Seems like it would be a nice feature to have, certainly have liked it on our 4th Gen 4Runners and this Sequoia. Technically, the Toyota Torsen Center Diff is full-time 4WD, not AWD, because it uses a transfer case with 4LO, has Center Diff Lock, technically different than AWD. On this '19 Sequoia the selector has three settings - 2WD, 4HI, 4LO. 4HI is actually full-time 4WD and there's a CDL button that can be engaged at any speed to lock the Torsen and then it's just like a Tundra's 4HI. 4th G 4Runner V8's don't even have a 2WD selection, are always in full-time 4HI w/CDL button, or 4LO. Those 4thG V8's go a lot of miles and never in RWD.
    Not sure why the Seq, LC and 4Runner had it for many trouble-free years and carried through different generations but not for the Tacoma and Tundra.
  4. Aug 10, 2021 at 9:46 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
  5. Aug 10, 2021 at 9:46 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    OIC, another fuel sipping soccer dad truck
  6. Aug 10, 2021 at 9:56 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I don’t understand, how is it possible to have a full time 4wd with 2wd drive mode
  7. Aug 10, 2021 at 10:00 AM
    TaquitoBandito
    Joel (AKA Bif)
    Aw, man. We are all going to have to get special "skinny" license plates now.
  8. Aug 10, 2021 at 10:15 AM
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    It’s only full time 4WD in the sense that you can leave it in AUTO4WD forever . It puts power to the rear wheels until it senses wheel slip then it automatically engages 4WD . It’s not actually running 4WD all the time .
    Cpl_Punishment likes this.
  9. Aug 10, 2021 at 10:15 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  10. Aug 10, 2021 at 10:18 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    My Tacoma with a composite bed had more payload than my Tundra does. A Tacoma's payload can be almost 1700 lbs.
  11. Aug 10, 2021 at 10:22 AM
    Melikeymy beer
    Muscogee Nation
    Yes. Totally girly. No hairy backs.
  12. Aug 10, 2021 at 10:33 AM
    mountainpete
    Yup. 1685 lbs in 4x2 Access Cab 4-Cyl Engine 6-Speed Automatic Transmission 6-Ft. Bed.
  13. Aug 10, 2021 at 10:36 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    That's the way the 1/2 ton market has and is going to. 3/4 ton truck if you want to do truck things.
    Elevatormatt and belanger9 like this.
  14. Aug 10, 2021 at 10:47 AM
    Kratos
    Kratos Woof
    2021 MGM Limited Nightshade
    Have they released any info on expected MSRP for the 2022?
  15. Aug 10, 2021 at 10:49 AM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    About tree-fiddy.
  16. Aug 10, 2021 at 10:49 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    I hope they put some real springs on the sr and SR5, or in their tow package
  17. Aug 10, 2021 at 10:51 AM
    Kratos
    Kratos Woof
    If it's less than a 10k bump at the higher trim levels I'd be surprised
    gj953 likes this.
  18. Aug 10, 2021 at 10:53 AM
    Oey12
    Oey12 New Member
    Joey
    New York
    2020 SR5 TRD OFFROAD
    Yes, I would agree the the 1/2 ton market is much “softer” than it was 30 years ago but what isn’t any 1/2 ton capable of as a truck? They can tow quite a load, carry 1000 pounds or more (1/2 ton), and do some off-roading. The market has change therefore the manufacturers have to keep up (by making them DD friendly). The other point that is rarely mentioned is look at the size any weight of the “toys” we haul and or tow. Everything from travel trailers, ATVs/UTVs, and hell even mountain bikes are significantly bigger and heavier than years ago. This I feel isn’t any manufacturers fault or problem…
    Terndrerrr and Cpl_Punishment like this.
  19. Aug 10, 2021 at 11:02 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    It’s always been the case.
    A 1/2 ton today has as much power, and capacity short of payload that a 3/4 ton did 15-20 years ago. Trucks keep getting bigger and more capable, but even 20 years ago if you were towing and hauling frequently a 1/2 ton wasn’t the ideal tool for the job. It’s still not the ideal tool for that job, but some guys who are really brand loyal to Toyota don’t seem to be able to accept it.
    Ford, GM, and Ram fans don’t spend any time lamenting the capabilities of the 1/2 tons offered by their brand of choice. They understand they’re basically made for daily use unladen or lightly loaded, with occasional use for heavier tasks or heavier trailer towing. Not a tough concept, and easier to accept when your brand of choice offers bigger trucks if you need more capability. If an F-150 owner decides he and the wife want a bigger camper for their growing family, he can go out and buy a nice F-250/350/450 depending on his budget and needs. He spends no time lamenting the fact his smaller truck is small, assuming he has the means to get a new truck.
    Toyota faithful, unfortunately are not given room to grow within Toyota truck offerings. So we see a lot of members here going to lengths to increase the payload of their Tundra 1/2 ton to accomplish 3/4 ton duties. Bless you guys and gals for trying, but I have to ask: if a 3/4 ton or 1 ton Toyota HD pickup were available would we even be having the conversations and angst over 1/2 ton payload? I doubt it. Instead we would hopefully have threads with titles like “Traded in my 1/2 ton Tundra for the 1 ton Tundra, and got the camper we’ve been wanting”.
    Maybe someday Toyota will give a lot of you that room to grow within the brand.
    akmerle, AggiePhil and Doofus like this.
  20. Aug 10, 2021 at 11:02 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Beat on a 1/2 ton and then a 3/4 ton, load up a 1/2 ton and then a 3/4ton it's a big difference. The 1/2tons are getting lightened up to make those mpg and increase payloads that when you do push them loaded up they are not the most sure footed. The 1/2 tons have become the new cars since no one buys those anymore. Which is fine I'm just saying if your gonna be working this thing I don't think it's gonna be for you. Each have the own place.
    I agree with you that our toys have changed, and in most instances are out pacing the trucks. I think the pin weight in most 5th wheel campers now is even pushing or exceeding 2500hd limits pushing those guys too 3500's.
  21. Aug 10, 2021 at 11:05 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    Well said, I agree with you. I doubt we would ever see an HD tundra, they are barely chasing the 1/2 ton market.
    Kung, Xspurt and Cpl_Punishment like this.
  22. Aug 10, 2021 at 11:06 AM
    G10dra
    G10dra Not a New Member
    Is it me or does this frame looks patched up
  23. Aug 10, 2021 at 11:06 AM
    Coal Dragger
    Kung Fu Dick
    Yeah doesn’t seem to be a lot of enthusiasm from Toyota for the North American truck market.
  24. Aug 10, 2021 at 11:17 AM
    Gene5253
    Gene5253 New Member
    Gene
    Boise ID
    2020 Tundra CM Limited
    Just curious what year you could not get 2% off a Tundra? I got 14% off a new 2020 Tundra Limited in March of last Year.
  25. Aug 10, 2021 at 11:20 AM
    A-A-Ron
    A-A-Ron Done messed up
    Aaron
    Seattle
    2021 Ford F-250 Lariat Diesel
    RAM has coils in rear of their 3/4 tons. Just because they are coils doesn’t mean they aren’t “real springs”, especially for 1/2 ton capacity. The current Tundra leaf springs are probably the weakest part of the suspension.
  26. Aug 10, 2021 at 11:26 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    What make u think Toyota going to put some HD coil springs on the tundra, what I mean of real spring, is some higher spring rate…
    Lovetrucks likes this.
  27. Aug 10, 2021 at 11:29 AM
    Dilleytech
    Dilleytech New Member
    Any time I have talked to a dealership for a Tacoma or tundra they have said absolutely no wiggle room. You pay sticker or the next guy does. Not to say there’s not some deals to be found. MSRP is standard for Toyota.
  28. Aug 10, 2021 at 11:31 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Yup, depends which state you’re in. Cali don’t have nothing, lucky to get msrp out the door
    JuicyJ likes this.
  29. Aug 10, 2021 at 11:36 AM
    Coal Dragger
    Kung Fu Dick
    They probably won’t, it’s a 1/2 ton. If you need more truck than that Toyota doesn’t have anything for you.
  30. Aug 10, 2021 at 11:46 AM
    The Californian
    Eric
    I got lucky with mine and ended up getting out the door at MSRP including all taxes, and fees on my 2020 TRD Pro.
Thread Status:
