2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Aug 10, 2021 at 7:21 AM
    trazerr
    trazerr New Member
    Oregon
    2024 Toyota Tundra Platinum LR
    Gas tank on the right side with exhaust on the left. We figured they moved the tank over to the right, but its confirmed now at least for this model.
    Sumo91 likes this.
  2. Aug 10, 2021 at 7:34 AM
    JuicyJ
    JuicyJ New Member
    I like seeing what appears to be a locker!
    TheBeast, ryanwgregg and Mountun Goat like this.
  3. Aug 10, 2021 at 7:35 AM
    NoRcptn
    NoRcptn Better than mediocre poster
    NorCal
    2017 Platinum
    GFC, Dobinsons IMS, RW's 285/75/17
    :rofl::rofl::rofl::rofl:
    gj953 likes this.
  4. Aug 10, 2021 at 7:46 AM
    JuicyJ
    JuicyJ New Member
    Looks that way, weight savings there will be used to increase payload
  5. Aug 10, 2021 at 8:05 AM
    IsaiahCanada
    IsaiahCanada New Member
    Isaiah
    Calgary, Alberta
    2021 Tundra SR5 Crewmax 4x4
    2.5 inch lift, TRD front and rear sway bars, 33 inch Open Country AT3 305/55R20 and dual TRD exhaust.
    I wonder if the locker will be backwards compatible? Toyota could make some good money on that one.
    Mountun Goat likes this.
  6. Aug 10, 2021 at 8:10 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    The rear pics are pretty much exactly the same as the spy shots posted on TFL Truck back in March.
  7. Aug 10, 2021 at 8:15 AM
    mountainpete
    My big question: is that a steel or composite bed?
    Cpl_Punishment likes this.
  8. Aug 10, 2021 at 8:27 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Carbon fiber!
  9. Aug 10, 2021 at 8:34 AM
    JuicyJ
    JuicyJ New Member
    The primary issue with that is did Toyota revise the rear end so much that it is not backwards compatible? Toyota probably made a few changes to the gearset for efficiency sake, obviously going to be taller gearing, and the fact that the axle is now multilink.... If I was to bet, I'd put a little money on it not being interchangeable
  10. Aug 10, 2021 at 8:35 AM
    JuicyJ
    JuicyJ New Member
    $90k truck!
  11. Aug 10, 2021 at 8:36 AM
    LarryDangerfield
    Tyler
    Northern Wisconsin
    You just wait
    Starting price!
    JuicyJ[QUOTED] and IsaiahCanada like this.
  12. Aug 10, 2021 at 8:39 AM
    BroTun13
    BroTun13 New Member
    Erik
    Beaumont, CA
    2021 White Tundra SR5
    Are those coilovers still 2.5? They look closer to 2.0 but maybe it's just a bad angle.
  13. Aug 10, 2021 at 8:43 AM
    Alloutdrs1
    Alloutdrs1 New Member
    Andrew
    Virginia Beach, VA
    If you zoom in on this picture at the bed for and that right side wheel well, the bed looks just like the Tacoma bed. My guess is same composite style as the taco.
    mountainpete likes this.
  14. Aug 10, 2021 at 8:54 AM
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Hot Take:
    2.93 final drive mated to a "world beating" 8spd slush box. No locker/LSD available because "there just wasn't any demand from our customers". The new gear ratios and extra gear-hunting programming ensure that you never see north of 1200rpm outside of tow/haul mode. Fortunately the 3.5V6TT makes torque at 1000rpm thanks to a pair of tiny turbos out of a Japan-only kei car, but they fizzle out north of 4k rpm.
    Carbon fiber composite bed is in the works, but will need another 15 years R&D to ensure it meets Toyota-spec. Target max 1500lb payload in Regular cab long bed.
    EPA rated 22mpg highway (<55mph) because the composite bed hasn't left planning yet. The only lightweight modifications are the change to coil springs and aluminum front knuckles.
    SR trim RWD RC starts at $38k. TRD Pro appearance + shocks package bumps an SR5 to $75k.
    Thesandaddict likes this.
  15. Aug 10, 2021 at 8:59 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
  16. Aug 10, 2021 at 9:03 AM
    Coal Dragger
    Kung Fu Dick
    Axle looks about the same size as the current truck, although the drain plug is on the the opposite side of the pumpkin. Hopefully they retained the 10.5” ring gear and 4.30:1 rear end, a 10 speed up front should have enough ratios to make that possible and still get good fuel economy.
    The skid plate doesn’t appear to have an access hatch for the oil filter, so Toyota screwed us again on that.
    papasmurf likes this.
  17. Aug 10, 2021 at 9:04 AM
    WaterlooTundra
    WaterlooTundra I love this truck
    I just got a 2021 cuz I don't want to be the V6 twin turbo guinea pig.
  18. Aug 10, 2021 at 9:06 AM
    mountainpete
    Unless it's accessible from the top?
  19. Aug 10, 2021 at 9:06 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Rear shock mount sitting too low for any off road tho
    Sumo91 likes this.
  20. Aug 10, 2021 at 9:07 AM
    WaterlooTundra
    Toyota reliability is unmatched. I considered a GMC 2500 but still can't get myself to take that level of risk.
  21. Aug 10, 2021 at 9:08 AM
    Coal Dragger
    Kung Fu Dick
    The oil filter on the V35A-FTS ‘21 variant in the Land Cruiser 300, which is probably what we’re getting, is located at the bottom of the engine block in the front on the driver’s side.
  22. Aug 10, 2021 at 9:10 AM
    Coal Dragger
    Kung Fu Dick
    Appears similar to the mounting location on a Ford Raptor.
  23. Aug 10, 2021 at 9:11 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    [QUOTE="Coal Dragger, post: 2357081, member: 63259"the skid plate doesn’t appear to have an access hatch for the oil filter, so Toyota screwed us again on that.[/QUOTE]
    That's a bummer, huge gripe of mine. Makes so much unnecessary extra work, my 21' t4r is the same way so I'm gonna have to install aftermarket skids.
  24. Aug 10, 2021 at 9:12 AM
    mountainpete
    Thanks - I saw it forward facing on the diesel but not on the gas... I will need to take a second look at those photos :)
  25. Aug 10, 2021 at 9:14 AM
    Melikeymy beer
    Melikeymy beer No cooler for you!
    Muscogee Nation
    2019 Platypus Tundra
    Same material as the Tacoma, I'm guessing. More weight savings and higher payload.
  26. Aug 10, 2021 at 9:16 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I’m buying but in a couple years. I’ll be buying a PRO or other high end trim level. I can’t wait for the more comfortable ride of rear coil springs. I don’t care about losing the V8 and I’ve decided that with the PRO I will MOD less and that’s what I want. I’m going to leave the next one as close to OEM as I can.
    VanceLee and ToyoMafia like this.
  27. Aug 10, 2021 at 9:17 AM
    Coal Dragger
    Kung Fu Dick
    Quite a bit of information here:
    https://toyota-club.net/files/faq/19-09-10_faq_df_v6_eng.htm
    Cliff notes (type ‘17 is LS500, type ‘21 is LC 300):
  28. Aug 10, 2021 at 9:17 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    those bed crack when I throw a cider block in.
  29. Aug 10, 2021 at 9:19 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Why they have 4 bumps stop on the back
    LarryDangerfield likes this.
  30. Aug 10, 2021 at 9:25 AM
    Jonross227
    Jonross227 New Member
    Looks like they kept the same weak ass cam tabs on the front. Oh joy
Thread Status:
