2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Jun 23, 2021 at 9:15 AM
    #8101
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    @TundraLaw
    Just out of curiosity, can you post a picture of your actual payload sticker on your new PowerBoost?
    I would love to see what it really truely is just for the heck of it!
    Cpl_Punishment likes this.
  2. Jun 23, 2021 at 9:15 AM
    #8102
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Will your back/neck hurt as much, nope, but will your heart be racing because the truck drives like it has a mind of it's own, absolutely. The air suspension is great for asphalt roads (not sure on concrete) but get more into washboard stuff and the softer suspensions end up pogo-ing and throw the truck around. It's in the shocks that makes the biggest difference and it's only the really advanced designs you find in the Raptor and TRX where the bumps can be absorbed but the truck not thrown around.
    The roads are so varied there's just not a one size fits all suspension setup, then throw in how different people want the vehicle to feel and the best the manufacturers can do is throw very basic setups out there.
  3. Jun 23, 2021 at 9:15 AM
    #8103
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Only real issue I've ever had with expansion joints is sliding across them after falling off my crotch rockets. Like getting hit with a bat when they are uneven.
  4. Jun 23, 2021 at 9:20 AM
    #8104
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I get it , I only suggested the test drive because my old Rebel with the air ride definitely road better than my new one ( not that the new one is bad ) . Anyway the 2022 Tundra with the coil springs should ride MUCH better than the 2021 and older Tundras .
    TK1979 likes this.
  5. Jun 23, 2021 at 9:48 AM
    #8105
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    Just looked at my trusty old 2007, no leaks evident anywhere. The only oil I could find was residue around the oil fill spout and cap, and that is 100% operator error.
  6. Jun 23, 2021 at 10:50 AM
    #8106
    Coal Dragger
    Kung Fu Dick
    I had no intention of disparaging anyone or any group, and if that is how you interpreted it I offer my apology.
  7. Jun 23, 2021 at 10:55 AM
    #8107
    Coal Dragger
    Kung Fu Dick
  8. Jun 23, 2021 at 11:04 AM
    #8108
    belanger9
    Edmonton, AB
    A bunch
    Give Ford 2 years, they'll crank it up to 485 HP and 650 lb ft. They just have to have the biggest numbers, even if just barely.
    That's just getting crazy, a lot like the magical 1000 lb ft for diesels. Just a ridiculous number that has no bearing on 99% of driving.
  9. Jun 23, 2021 at 11:06 AM
    #8109
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    But that 1% is just stupid amazing !!!!
  10. Jun 23, 2021 at 11:12 AM
    #8110
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    The 1st Amendment grants every U.S. Citizen the right to offend anyone, being offended is a product of your own mind. :hattip:
  11. Jun 23, 2021 at 11:21 AM
    #8111
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    As correct as you are about the amendment, I don't believe forums are held to such open standards. Just like political talk is banned accordingly.
  12. Jun 23, 2021 at 12:30 PM
    #8112
    Coal Dragger
    Kung Fu Dick
    I am sure it’s possible, having no idea what the Ford F-150 transmission bell housing has room for, nor how much flexibility there is in the frame cross members. If Ford wanted to match or exceed those numbers from Toyota (assuming they are even remotely accurate), it will take a significantly more powerful electric motor than what they are currently using. Currently the F-150 PowerBoost electric motor makes a nominal 30hp and 70lb-ft, so we’re talking about more than doubling the output and with electric motors that’s not as easy as just turning up something. Either more voltage on the same size unit made to take the higher voltage, or a physically larger motor of the same voltage. Neither solution would be easy or cheap unless the frame and transmission architecture allow quite a bit of room to grow.
    The other option is turning up the boost, but that presents issues too.
  13. Jun 23, 2021 at 12:35 PM
    #8113
    BayRunner
    2017 Tundra Platinum
    This does not apply on private platforms. Private platforms can make their rules or standards anything they want and the only “right” that we/you have is the right to accept or decline the use using those rules.
    akmerle, Jimes, 17TundraDCEd and 4 others like this.
  14. Jun 23, 2021 at 12:36 PM
    #8114
    NativeHoustonian58
    NativeHoustonian58 New Member
    Native
    2021 Super White Tundra TRD Sport
    Blackout package, TRD Exhaust, Katskins leather, Fuel rims, Nitto Ridge Runners
    No likey that 2022 design.
  15. Jun 23, 2021 at 12:57 PM
    #8115
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    I don’t understand the tundra rough ride comments. It’s all interpretation, but I thought my tundra rode great. I’m in the minority though :crapstorm:
  16. Jun 23, 2021 at 1:04 PM
    #8116
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    And if my Aunt had balls, she'd be my uncle.
    The issue is not mpg, it never was. The issue is will the pint size ICU live for 200 to 300 thousand miles of work.
    THAT is the issue.
    Anyone buying a truck based on MPG needs to re think they're sanity in this type of purchase.
    That kind of logic would make anyone who came out with an inline 4 get all the truck sales in the nation.
    Joro43 and TK1979 like this.
  17. Jun 23, 2021 at 1:09 PM
    #8117
    Kung
    KG, VA
    Nowadays, she might still be your aunt. LOL
    Joro43, Cjames17, jpod and 9 others like this.
  18. Jun 23, 2021 at 1:14 PM
    #8118
    Jonross227
    Jonross227 New Member
    Ford will have to do a redesign and use a bigger motor to increase power and actually make it usable for a full size truck. They're already using the highest voltage(450v) that I know of meaning their motor is pretty small. Prius hybrid is around 200v, rav4 prime is about 350, and teslas max out at 375. These other unreleased ev's may be running more but Ford is at the top of my knowledge.
    Knowing them they will probably add more boost too. Unreliable trucks with a dedicated fan base keeps them in profits.
  19. Jun 23, 2021 at 1:14 PM
    #8119
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    hell she might be your aunt in the morning, your uncle at lunch time and back to your aunt by dinner. you know because of the fluidity and what not.
    rynoesco, JuicyJ, TK1979 and 6 others like this.
  20. Jun 23, 2021 at 1:14 PM
    #8120
    Coal Dragger
    Kung Fu Dick
    Yeah I got chastised for inadvertently hurting feelings, so if your aunt with testicles identified as your uncle I suggest you just roll with it.
    Joro43, jpod, TK1979 and 5 others like this.
  21. Jun 23, 2021 at 1:16 PM
    #8121
    mech_engineer09
    Ohio/Pennsylvania
    2020 MGM Platinum
    lol
    TK1979, Doofus and ZappBrannigan like this.
  22. Jun 23, 2021 at 1:29 PM
    #8122
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    I disagree, MPG is the issue, but its not coming from consumers. Considering over 50% of F150's sold are V8's its not the customer causing the change, but CAFE standards forcing automakers to change.
    Doofus and gj953 like this.
  23. Jun 23, 2021 at 1:52 PM
    #8123
    Coal Dragger
    Kung Fu Dick
    Agreed. I think many of us on here think the perfect solution to a thirsty truck with lots of power is a larger fuel tank.
    EPA CAFE standards don’t care what consumers actually want though.
    GODZILLA, specter208 and Nm6300'asl like this.
  24. Jun 23, 2021 at 1:57 PM
    #8124
    belanger9
    Edmonton, AB
    A bunch
    It rides like a truck, it is definitely the stiffest of the half tons. I personally prefer the stiffer ride, to me it inspires confidence in the road as it gives a very good feel of the road. All I want from the next gen is to stay connected to the road - don't sacrifice that to ride softer.
  25. Jun 23, 2021 at 2:04 PM
    #8125
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    No need to bring operator error into this.
    It applies everywhere. Being offended is all in your head.
    Doofus likes this.
  26. Jun 23, 2021 at 2:06 PM
    #8126
    Larly5000
    Larly5000 Local Scumbag
    NV
    07 Crewmax
    Agreed. Newer GM trucks(aside from magnetic stuff, which is super nice) ride like a boat. Disconnected, floaty...Preference I guess, not my cup of tea.
  27. Jun 23, 2021 at 2:12 PM
    #8127
    Jonross227
    I will agree CAFE standards are making a major push for increased mpg but to say the customers aren't causing the change isn't 100% true. If it was the 3.0 duramax wouldn't be selling as fast as they can build them.
    A full sized truck getting upper 20's on the interstate back and forth to work that will still pull their ski boat or travel trailer with no issue on the weekend is what a big section of the truck market wants.
    I'd say a big reason the v8 is still the biggest seller is 1) fleet sales and 2) the eco boost gets the same fuel mileage as the v8.
  28. Jun 23, 2021 at 2:25 PM
    #8128
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I know I'm driving a full size truck, but mpgs do matter to me as a consumer. I won't go buy a new truck to get better gas mileage, but when it comes time to buy a new truck in a couple years and one truck gets 15 mpgs and the other close to 30, that will make a difference in my decision. That will save me anywhere from $100-200 a month. I think it matters to a lot of people too. On other forums, as soon as a Tundra is mentioned, people bash the gas mileage, maybe because it is the only thing to complain about, but people are aware of the mpgs.
    CENAIR and Doofus like this.
  29. Jun 23, 2021 at 2:26 PM
    #8129
    Kelvin
    Kelvin New Member
    Hey man, I’m Asian and also really short, while I didn’t take offense to your comment it doesn’t mean I shouldn’t have. I’ve grown immune to race related insults as they’ve been thrown at me my whole life. Hell, when I was around 10 and going home I got yelled at by homeless Vietnam vets to go back to my own country. I deal with it. But while I can take a joke, there are many others that can’t.
    If I wasn’t such a pessimist I might even have portrayed your comment as a complement. There are many out there that go for Asian women for the sole purpose that they’re small.
    Anyways, with today’s cancel culture you really need to watch it. I say this because for the last several years I sit at home alone after work because I’ve offended too many people. And to all that people that stood up to his asinine comment, I also appreciate you.
    Back on topic - the 2022 is ugly and I wouldn’t fuck it with YOUR dick
    Cavalrysr5, shellshock, Kung and 4 others like this.
  30. Jun 23, 2021 at 2:36 PM
    #8130
    twolf
    twolf New Member
    I can't find a source for this number and I find it extremely hard to believe, quite frankly.
    If you go to any Ford dealer the majority of the trucks are the 2.7, there are typically about as many 3.5s and then usually a few 5.0 trucks.
    Also if you go on Autotrader and select New/Used 2018-2022 there are 1371 trucks for sale. 409 of those are 5.0s--29%.
    "Heading into 2018, Ford’s truck marketing manager Todd Eckert tells Automotive News that the 2.7-liter EcoBoost will be the most popular F-150 engine followed by the 3.5-liter EcoBoost. Together, they’ll claim 65 percent of all F-150 sales, leaving 10 percent for the new entry-level 3.3-liter, and roughly 25 percent for the five-point-oh."
Thread Status:
