2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Dec 7, 2020 at 6:12 PM
    #781
    aggie_tundra
    aggie_tundra Always Tired
    2021 2500 Custom
    Just for comparison my 2020 F250 with the 6.2 gas engine has a payload of 3,299lbs
    Hbjeff and ColoradoTJ like this.
  2. Dec 7, 2020 at 6:18 PM
    #782
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    That sounds right as I looked at a 6.2 and 7.3 also and remember payload compared to GM as close to the same. Not enough difference in what I Was going to be doing.
    aggie_tundra[QUOTED] likes this.
  3. Dec 7, 2020 at 6:22 PM
    #783
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Maybe it's the driver, not the truck? :p
  4. Dec 7, 2020 at 6:44 PM
    #784
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    Tow / haul I get as I don’t do that either , but I’m not sure I understand why you would drop a gear on the interstate . When I use the gear selector I select 8 gears so the transmission shifts normally to 8th but doesn’t activate “eco mode” which is cylinder deactivation .
    I get that it’s crappy to have to do that every time you put the truck in drive but I’m with you on the long term reliability ( right or wrong ) I prefer having all 8 cylinders there .
    As far as fuel economy goes I’ve gotten 26 MPG out of mine but our speed limit is only 60 MPH around here so that helps quite a bit .
    From what I’ve read on this forum I do respect your point of views Colorado TJ .
  5. Dec 7, 2020 at 6:46 PM
    #785
    Outbound
    Aaron
    Northern Alberta
    I thought that too, then I drove the truck and got the same fuel economy or lack thereof. We've both gotten similar mileage to each other when driving our other trucks. :notsure:
  6. Dec 7, 2020 at 7:11 PM
    #786
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    I thought if you put a GM in L6/8/10 (depending on your transmission), it would still drop cylinders.
  7. Dec 8, 2020 at 3:20 AM
    #787
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    So by legal definitions it is a class 3 (GVWR 10000 to 14000), or more commonly known as a 1 ton. And in some areas as @Midmo_tundra pointed out this can cause legal issues. We're just pointing it out so those who are doing their research (for personal or commercial purposes) don't think they can treat a GM 2500 the same as a half ton. If I had consistent use for more payload or towing I'd be in a 1 ton myself since in Alberta there's no additional restrictions for personal Class 3 trucks (commercial there should be, but if you just haul a regular trailer or just payload the cops at the inspection stations won't go and get you when you skip by).
    Kinda on topic with this though, in Alberta a coworker - in a 1 ton with 2 quads on a sled deck - got pulled over by a cop for speeding, this cop happened to have a DOT (forget what they're called in Alberta) inspector with him; so while they had him pulled over for speeding they figured they may as well do a commercial inspection, since we drove 1 tons (and vehicles over 10000 lbs GVWR have different regulations) he got hit with a lot of penalties - we didn't do log books, and his straps had loosened slightly (they have to be tighter than tight, any play is an issue) were 2 of the penalties he got hit with, and in the end he got fined somewhere in the $3-4k range, because he was driving a vehicle of over 10000 lbs GVWR.
    Midmo_tundra and Cpl_Punishment like this.
  8. Dec 8, 2020 at 6:48 AM
    #788
    Wallygator
    I fixed it for you.
  9. Dec 8, 2020 at 6:51 AM
    #789
    Wallygator
    The deal breaker for any GM product should be the remembrance of how they took an immense amount of taxpayer money and never paid it back. That and closing plants in the US to make new plants over seas. GM can suck it!
  10. Dec 8, 2020 at 8:16 AM
    #790
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    I honestly don’t know about GM or Ford I only know the Ram from personal experience .
  11. Dec 8, 2020 at 8:27 AM
    #791
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    And I on the other hand know nothing about Ram. Haha
    Lovetrucks[QUOTED] likes this.
  12. Dec 8, 2020 at 8:39 AM
    #792
    Midmo_tundra
    Midmo_tundra New Member
    Missouri
    The gas tank is actually only 24 gallons, they decreased it from ~26 on the previous generation to 24 on 2019+ crew cabs.
    Cpl_Punishment likes this.
  13. Dec 8, 2020 at 9:16 AM
    #793
    Lovetrucks
    Lovetrucks Member
    2019 Ram Rebel
    That’s just another weight saving thing for a little better gas mileage .
  14. Dec 8, 2020 at 9:57 AM
    #794
    Midmo_tundra
    Missouri
    Exactly my thoughts haha. Still blows my mind GM doesn’t offer a 30+ gallon optional tank on the 1500s
  15. Dec 8, 2020 at 11:14 AM
    #795
    19crewmaxTRD
    19crewmaxTRD Tundra Enthusiast
    Seth
    2019 white tundra crewmax
    We, as a small business who really struggled during the recession had a really hard time buying a gm product because of the bail out. But after being burned by our fords and rams having an abysmally small gas tank (22 gallons) for a big thristy v8, it was the only option left. If we could have found a bigger aftermarket tank for the ram we would have bought another one, but there isn’t anything out there for the gas 3/4 tons.
  16. Dec 8, 2020 at 11:38 AM
    #796
    aggie_tundra
    2021 2500 Custom
    I’ve noticed that. The aftermarket options for gas 3/4 tons is very very small. I think the Ram has a 31 gallon tank now regardless of bed length, but that’s still small. At least ford puts in a 48 gallon tank in long bed trucks. Not sure about Chevy.
  17. Dec 8, 2020 at 11:48 AM
    #797
    19crewmaxTRD
    Seth
    Our 2012&2013 Fords 6.7 had 45 gallon tanks (diesel)
    Our new 2019 ram 6.7 has a 50 gallon tank (diesel)
    Our new 2019 ram 6.4 has a 22 gallon tank (gas)
    Our new 2020 Chevy 6.6 has a 38 gallon tank (gas)
    We got burned buy the ram gas truck and didn’t think any company would put that small of a tank on a cab a chassis, especially after being used to 40 gallon plus tanks on our diesel trucks.
  18. Dec 8, 2020 at 11:52 AM
    #798
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Since we're not talking about the 2022 Tundra anymore; just wanted to share a couple of pictures of the Toyota that I wanted - but never became a reality. The Toyota A-BAT:
  19. Dec 8, 2020 at 11:54 AM
    #799
    19crewmaxTRD
    Seth
    Your what’s wrong with this world. All joking aside that thing is an abomination.
  20. Dec 8, 2020 at 12:09 PM
    #800
    The Californian
    Eric
    By todays standards for sure, but back in 2007 when they first showed it - it was the tits.
    GODZILLA and Mountun Goat like this.
  21. Dec 8, 2020 at 12:30 PM
    #801
    BobsYourUncle
    BobsYourUncle New Member
    2021 Super White Tundra TRD Pro
    That kind of looks like a FJ Cruiser hooked up with a Chevrolet Avalanche and they had a love child...
    Mountun Goat likes this.
  22. Dec 8, 2020 at 1:18 PM
    #802
    timsp8
    NY
    Looks like a ridgeline.
  23. Dec 8, 2020 at 1:30 PM
    #803
    ezdog
    ezdog New Member
    Gateway To The West
    Like a Roided out Ridgeline to me?
  24. Dec 8, 2020 at 1:37 PM
    #804
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    kinda, or a roided out subaru outback “pickup”
  25. Dec 8, 2020 at 1:45 PM
    #805
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
  26. Dec 8, 2020 at 1:53 PM
    #806
    ezdog
    ezdog New Member
    Gateway To The West
    I forgot about the Brat and Baja!
  27. Dec 8, 2020 at 1:58 PM
    #807
    timsp8
    NY
    I like that. If it was just me, I’d take that and sc it with a camper in the back.
  28. Dec 8, 2020 at 2:41 PM
    #808
    ezdog
    ezdog New Member
    Gateway To The West
    A standing sleeper camper?
    Wallygator, Hbjeff and Mountun Goat like this.
  29. Dec 8, 2020 at 3:00 PM
    #809
    The Californian
    Eric
    It's like the truck camper version of a Japanese Soaking Tub; It's Japanese Sleeping Camper.
    Hbjeff, Lovetrucks and Mountun Goat like this.
  30. Dec 8, 2020 at 4:08 PM
    #810
    ezdog
    ezdog New Member
    Gateway To The West
    I had one of these once!
    It was nice but pretty Squirrely!
    mkiCa7eC7BUI9nM7DprIFaXSiNcXnZrUwayf4_7r_80bea67de1972f613bb892553fd419691c68ee68.jpg
Thread Status:
