2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Jun 20, 2021 at 8:37 PM
    #7801
    JuicyJ
    JuicyJ New Member
    The F-150 has 3 frames available, the difference being the thickness/gauge. It's pretty confusing, the F-150 forums cover it pretty well, but IIRC the PB F-150 is using the middle option frame, and it does lose a significant bit of capacity, but it's not 500 pounds when compared to a truck with the same frame. I think the PB option is about -300 pounds.
    Wallygator likes this.
  2. Jun 20, 2021 at 9:04 PM
    #7802
    greatlakes
    greatlakes New Member
    West Michigan
    I'm okay reading all the negative comments from current owners on the looks/engine/big screen/whatever. Maybe that means I will have my choice of colors when the 22's hit the lots...:fingerscrossed:
  3. Jun 20, 2021 at 9:09 PM
    #7803
    Downytide
    Downytide New Member
    GTA
    Lunar Rock that whines
    The engine alone is 480lb ft at those rpm range, the electric motor is about 80hp/160lb ft, the beauty of this combo is the motor has max torque at 1rpm, so when you leave the line, you probably have 300lbft of torque from the moment your right foot is off the brake pedal, 1st 2nd and 3rd will probably used to accelerate from stop to 25mph, while the engine barely revs past 1500rpm but with combine torque of almost 400lb ft.
  4. Jun 20, 2021 at 9:17 PM
    #7804
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    Was just going off the specs found on their website - CCSB 4x4 with 3.5 EB or 3.5 PB, and a few other options. Each time it was 500 lbs less in payload capacity.
  5. Jun 20, 2021 at 9:25 PM
    #7805
    TundraLaw
    TundraLaw New Member
    Northern Nevada
    Ford hybrid is 570lbft torque.
    JJtruckon likes this.
  6. Jun 21, 2021 at 4:44 AM
    #7806
    Ahab
    Ahab New Member
    Ahab
    2021 Tundra SR5
    There is nothing wrong with a double cab. Having a crew cab does not make you better or "more legit". If I wanted to label as you do I could call the double cab the "soccer mom" but I do not need to label to feel better about myself. :bucket:
  7. Jun 21, 2021 at 5:01 AM
    #7807
    Nm6300'asl
    Nm6300'asl New Member
    2022 DC SR5 4x4
    Oem tonneau, side steps, spray in liner. Trd skidplate.
  8. Jun 21, 2021 at 5:18 AM
    #7808
    DannyD303
    DannyD303 New Member
  9. Jun 21, 2021 at 6:40 AM
    #7809
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
  10. Jun 21, 2021 at 6:56 AM
    #7810
    kstateskier
    kstateskier New Member
    Bradley
    Kansas City, MO
    2022 Tunda 1794 - Dark Metallic Grey
    That thing got up to speed fairly quick... Those LC's aren't light either.
    Ahab and DannyD303 like this.
  11. Jun 21, 2021 at 8:08 AM
    #7811
    DannyD303
    That was my thought too.
    kstateskier[QUOTED] likes this.
  12. Jun 21, 2021 at 8:32 AM
    #7812
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Unless the new one starts with 1200 lbs payload before the batteries are installed...
  13. Jun 21, 2021 at 8:36 AM
    #7813
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    The wife wants to ditch our car now. There's a '21 Platinum for 56k a few hours away, should I do that until the 2022 bugs are done or just hold out? Other option is a local F150 Lariat. But idk much about the F150 and their redesign seems to have some issues too. And their V8 is hit or miss on oil consumption.
  14. Jun 21, 2021 at 8:40 AM
    #7814
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I'd go with the Platinum, but that's just my opinion.
  15. Jun 21, 2021 at 8:42 AM
    #7815
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    I'd jump on that platinum! You know what your getting and you know the resale will be strong, so either you keep it long term for the v8 or trade in a few years and get a good return.
  16. Jun 21, 2021 at 8:53 AM
    #7816
    JJtruckon
    JJ
    2018 Tundra
    Undercoating
    If you don’t “have” to buy something right now and just “want” to buy something. I’d wait until this time next year. Simple supply and demand situation. Inventory will be up next year across most brands which should lead to increased incentives. Basically any purchase right now is a losing situation when it comes to price. Unless you have that sentimental feelings towards a 14 yo truck, get the Platinum.
  17. Jun 21, 2021 at 8:59 AM
    #7817
    Jaxyaks
    Jaxyaks New Member
    I agree, the bottom is about to fall out of the automotive market, they are going to have to dump way too much inventory at the same time on the market. And if they don't get some of it dumped in the next couple of months there is going to be a TON of 2021 vin numbers dumped on dealer lots from multiple brands. I know people say that toyota does not have this issue, but the market will force them to address this issue to keep up their own sales numbers.
    It is definitely a sellers market right now, but the buyers market is right around the corner for more than just cars.
  18. Jun 21, 2021 at 9:02 AM
    #7818
    Jaxyaks
    Jaxyaks New Member
    If I needed to buy something until the bugs were worked out of the 2022 I would buy a used tundra (if it needed a full size) probably high mileage used (under 20K) if for no other reason than risking taking a bath on a new one.
  19. Jun 21, 2021 at 9:04 AM
    #7819
    Xspurt
    Xspurt New Member
    The Fords are doing fine. They fixed the 5.0L oil issue a while back and I believe it only affected 18s and 19s anyway. They did add cylinder deactivation to the 21 5.0L though. The only other issue is the rust on the rear axle and diff but there are easy homebrew fixes for that too.
    One of the lesser known youtube guys (THIS ONE) thinks Toyota is going to keep the 8 cylinder but with improvements. He feels since the big 3 still offer it, Toyota would be nuts to get rid of it. Who knows, he could be way off.
    Wallygator, Doofus and JJtruckon like this.
  20. Jun 21, 2021 at 9:04 AM
    #7820
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    I don't have to have it right now. Just would be nice to trade in the lease that's offering me $4-5k in upside value right now.
    Boerseun and JJtruckon like this.
  21. Jun 21, 2021 at 9:09 AM
    #7821
    BayRunner
    2017 Tundra Platinum
    The oil problem was in the ‘20 F150 as well.
  22. Jun 21, 2021 at 9:12 AM
    #7822
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Can someone answer this reply from the dealer. I inquired to their online price and on top of a bunch of other crap they added like $1200 freight charge for this reasoning. Am I wrong or doesn't the original window sticker charge of $1695 cover all the shipping to port for options too ?
    "Hello, no it is at our dealership now, the Freight is what they charge to get it from the port in Houston, for example, it was built in San Antonio and then shipped to the port in Houston where they may add or take off certain options per the dealer or customer, it is then shipped to our dealership from there"
  23. Jun 21, 2021 at 9:15 AM
    #7823
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    I wouldn't even get into the weeds on that, just stick with out the door pricing at $56k. They'll say they can't do that, but like you said your not in a rush to buy.
  24. Jun 21, 2021 at 9:16 AM
    #7824
    Jaxyaks
    Jaxyaks New Member
    I agree, I would just tell them what you want to pay for it.
  25. Jun 21, 2021 at 9:16 AM
    #7825
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    Just for my own sanity, the original charge covers all that right. I see people with new builds following theirs from SATX to Houston port for install and then delivery.
  26. Jun 21, 2021 at 9:19 AM
    #7826
    Xspurt
    Xspurt New Member
    Just more stupid slimeball tricks. Don't fall for it. Don't pay MSRP or over. I'm seeing near normal build times in this thread alone. We're over the hump. Chips are shipping. Companies are getting caught up. Dealers are milking this for all it's worth but their cow is about empty ... unless you fall for their nonsense. Yes, many dealer lots are thin but they don't have a line of people there either, except for some pockets here and there which make it newsworthy. I'm not trying to slap rose colored glasses on everyone but I am trying to take the dark blue ones off of some because there is light at the end of the tunnel and we're almost through it.
    AggiePhil and JJtruckon like this.
  27. Jun 21, 2021 at 9:19 AM
    #7827
    TexAggie
    TexAggie New Member
    Eric
    2017 CM
    MSRP covers everything to the original dealer, if the dealer adds something after delivery that is not included, if the dealer trades with another dealer the cost associated with transporting the trade is not included in MSRP.
  28. Jun 21, 2021 at 9:20 AM
    #7828
    18" TRD Off Road Wheels
    The shipping charge on the door sticker is the only one that should be one it. If there is anything added beyond that sticker then it's just a "market adjustement" (read: price gouge) under a new name.
  29. Jun 21, 2021 at 9:28 AM
    #7829
    DrZoidberg
    Dave
    SATX
    Tesla MYP
    You'd get a kick out of the price on a Lunar Rock TRD Pro in CA I got quoted. Brand new LR TRD Pro, had a few options like the bed liner and inlay. Asking $79.9k.
  30. Jun 21, 2021 at 9:41 AM
    #7830
    fbingha
    fbingha New Member
    Bakersfield, CA
    It's fine.
    Let's zoom in on the grill and not find a transmission radiator in there.
Thread Status:
