2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. Jun 19, 2021 at 1:42 PM
    #7561
    18" TRD Off Road Wheels
    It all boils down to opinions and preferences. Everyone can have their own, but when people start calling others stupid for having a different view... that's just them showing their asses.
  2. Jun 19, 2021 at 1:43 PM
    #7562
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    TTV6 will for power at high altitude, but once you get into boost the MPG's are actually worse at high altitude. TFL has done the Ike Gauntlet with turbo's vs V8's and the V8's get slightly better MPG with the same trailer. Pick your poison kind of thing.
    Cpl_Punishment likes this.
  3. Jun 19, 2021 at 1:43 PM
    #7563
    Breathing Borla
    AZ
    not to be a jerk at all, but stop just talking about rear end gearing, its not that simple anymore with clogs in the trans.
    You have to look at final ratios. like I said in my other post my ram with a ZF8 and a 3.92 was damn near shorter overall in 2nd that my tundra is in 1st with a 4.30.
    its a different game out there now with 8 and 10 speeds.
    again, that said, they have to get the tune right, but I bet they have it right!! They know this thing is going to have to pull like a mother-phucker or they can just pack up and go home. I bet they have it nailed!!!
  4. Jun 19, 2021 at 1:45 PM
    #7564
    This is generally going to be offset by the MPGs when not towing, but then that is offset by the turbos frequently needing premium fuel. Quite the conundrum.
  5. Jun 19, 2021 at 1:45 PM
    #7565
    bigblue14
    bigblue14 New Member
    Craig
    2022 1794 Advanced Package
    TRD lift and AFE airbag arms, 285/65 Cooper AT3s
    So how soon until someone comes out with a LS swap for these?
    Ace402 and Cpl_Punishment like this.
  6. Jun 19, 2021 at 1:45 PM
    #7566
    GaryC
    GaryC New Member
    I expect towing to be significantly improved on the new truck.
    Why do you expect a smaller fuel tank? I don't see a reason for them to do that. Rear end gearing is only part of the equation, there's a new transmission coming and the gearing in it matters just as much as the rear end. Turbochargers enhance the towing experience a lot in my experience, they make power at a lower RPM so you don't have to rev the heck out of it. There's a reason every OTR truck on the interstate is turbocharged. I don't know what fuel economy the new truck will get towing but it can't be much worse than my 5.7 gets now. I care more about fuel economy for the 98% of the time I'm not towing with it though, 15 mpg has gotten really, really old and if it'll get 22-23 mpg that'll be a HUGE win.
    I agree that a half ton isn't what someone needs if they're towing significant weight on a constant basis. That being said, the 5.7 isn't the towing monster some here make it out to be. Boosted engines and towing naturally go together because the power can be made lower in the RPM band, that's the main reason I expect the new engine to outperform the 5.7.
  7. Jun 19, 2021 at 1:48 PM
    #7567
    Jaxyaks
    Jaxyaks New Member
    It doesn't mean that it will be the same size, The new Tundra shares the same platform and its more than likely larger than the Land Cruiser, they are also going to use the same platform for the 4 runner and Tacoma...Using the same platform does not necessarily mean the same size. I meant that the interior may be similar as well as capabilities.
    Cpl_Punishment and Acedude like this.
  8. Jun 19, 2021 at 1:48 PM
    #7568
    FYI: Comparing gassers to diesels is as bad as howling about axel gearing without accounting for the transmission.
  9. Jun 19, 2021 at 1:54 PM
    #7569
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    It is predictable and comical.
    We don’t know hard details yet, but the crowd that doesn’t like new things hates it for a variety of speculative reasons.
    Funny most of the pushback is from guys with either nearly newer Tundras that probably wouldn’t buy a new one regardless of what it was; or guys with 1st Gen Tundras that are clearly never buying a new truck ever for any reason.
    twolf likes this.
  10. Jun 19, 2021 at 1:54 PM
    #7570
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    I didn't realize the new Tundra and LC were the same platform also. Since the new LC is being sold places where the Tundra is not, it wouldn't make sense to share a platform. They're built and sold in different countries. Got any concrete primary source on that before I stick it in the old memory bank?
  11. Jun 19, 2021 at 1:58 PM
    #7571
    GaryC
    GaryC New Member
    Not really. I own both and while there are significant differences the same principles apply. A turbocharger does the same thing on both of them and greatly broadens the powerband. Many here probably are too young to remember when diesel pickups came without turbos. Ford made a 7.3 IDI diesel that was a dog before they got the 7.3 Powerstroke which was a much, much better engine.
    Far too many here pee down their legs about turbochargers without reason, they've been around about 100 years and if designed right they'll outlast the engine. There's nothing magical about a normally aspirated V8, a boosted V6 can easily be built to outperform one. I'd have preferred it be an inline 6 but the V6 doesn't bother me.
  12. Jun 19, 2021 at 2:05 PM
    #7572
    Breathing Borla
    AZ
    guy just pulled up across the street from my house in a red GMC AT4, slick looking truck...
    cant wait to test out that against a new 2022 tundra, truck shopping is awesome, some really nice rigs out there from everyone, well except Nissan, just never got the titan, HA!
  13. Jun 19, 2021 at 2:09 PM
    #7573
    Xspurt
    Xspurt New Member
    Yeah, those haven't bounced back yet unfortunately! Powder Valley Inc. is where I measure the pulse on those.
  14. Jun 19, 2021 at 2:09 PM
    #7574
    Breathing Borla
    AZ
    who cares about MPG, show me the power, I get at the most 12 now anyway, with only sandbags in the back to smooth this thing out a touch, LOL.
    JJtruckon and Black Wolf like this.
  15. Jun 19, 2021 at 2:19 PM
    #7575
    According to Car & Driver the Pro comes with Falken Wildpeak AT's on 18s. Pro MSRP $50K + and the base model at $36K. Not crazy msrp's but the Pro will no doubt be higher due to demand. If there still is a used truck shortage, then a trade in tunny should be high. Dealers will still want used tunnies to sell. They need used stock trucks on their lots....sticking with my boring V8.
  16. Jun 19, 2021 at 2:30 PM
    #7576
    Jaxyaks
    Jaxyaks New Member
    As I understand it, They are using the TNGA-F platform for all the body on frame vehicles, The LC was the first introduced and it looks like the Tundra is gong to be the second. According to their schedule next will be the Sequoia and 4 runner, and then the Tacoma. The 4 runner is also not made in America they are all made at the same plant in Japan.
  17. Jun 19, 2021 at 2:31 PM
    #7577
    Jaxyaks
    Jaxyaks New Member
    If you think the new tundra is a fun release, just wait until they intro the next Tacoma and it only has a 4 cylinder turbo available for the powerplant..lol
    JJtruckon likes this.
  18. Jun 19, 2021 at 2:31 PM
    #7578
    Wallygator
    The truck is ugly, yes, but Toyota will sell every single one they make without issue. An just cuz it's ugly doesn't mean I won't own one, I mean I drive a 2020, not too worried about looks
    Black Wolf likes this.
  19. Jun 19, 2021 at 2:35 PM
    #7579
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    I’m torn on what to do. Get a truck now or Hope one of these is available. I don’t think I’ll get one at MSRP if at all. I still like the 2021 looks.
  20. Jun 19, 2021 at 2:36 PM
    #7580
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    Who cares if the mpg decrease when towing in the mountains. All that torque, this changes the quality and safety for towing.
    Probably 1-3% of Tundras are used daily for towing. 6-9mpg towing and 22-25 hwy otherwise. No brainer.
    Give this Taco Grande 3 years and the majority will love the engine.
    twolf and Wallygator like this.
  21. Jun 19, 2021 at 2:36 PM
    #7581
    Jaxyaks
    Jaxyaks New Member
    I am just hoping this new tundra at least matches the titans payload and towing.
  22. Jun 19, 2021 at 2:42 PM
    #7582
    Wallygator
    Yeah I have a feeling with the hybrid option that thing is gonna be a beast.
  23. Jun 19, 2021 at 2:44 PM
    #7583
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    Didn't the current tundra get about 3-4 mpgs towing during the Ike gauntlet test? Twin turbo can't do too much worse than that can it?
  24. Jun 19, 2021 at 2:47 PM
    #7584
    Matches fugly already....ha
    Wallygator likes this.
  25. Jun 19, 2021 at 2:47 PM
    #7585
    JJtruckon
    JJ
    2018 Tundra
    Undercoating
    Toyota will not require premium fuel. They do to much research on their buying demographic. Just look at this truck. It was basically built out of buyer surveys.
  26. Jun 19, 2021 at 2:49 PM
    #7586
    JJtruckon
    JJ
    2018 Tundra
    Undercoating
    Could have been lower. :turtleride:
  27. Jun 19, 2021 at 2:49 PM
    #7587
    Link to buyer surveys that Yota used?
    deptrai likes this.
  28. Jun 19, 2021 at 2:50 PM
    #7588
    Not sure if Ford requires it for general use either, but if you want the numbers on the spec sheets then it is required.
    deptrai likes this.
  29. Jun 19, 2021 at 2:50 PM
    #7589
    Wallygator
    Dude cover up your address.
  30. Jun 19, 2021 at 2:51 PM
    #7590
    trekkar
    trekkar New Member
    northeast CT
    To me the 22 looks so much better, but if there were deals on the 21 I’d buy one today. I’m just not paying msrp on a sr5 or any other 21. Heck I don’t think I’m willing to pay msrp on a 22. May take me a while to get a new one
Thread Status:
