2022 Tundra
Discussion in '3rd Gen Tundras (2022+)' started by 0.S.T., Apr 6, 2020.
Who has actually used the front tow hooks?
  1. Never
    204 vote(s)
    52.6%
  2. 1-5 times
    111 vote(s)
    28.6%
  3. More than 5 times
    45 vote(s)
    11.6%
  4. Almost daily
    7 vote(s)
    1.8%
  5. I'm an off-roader and definitely need it.
    28 vote(s)
    7.2%
  6. I mall crawl
    17 vote(s)
    4.4%
Multiple votes are allowed.
Thread Status:
Not open for further replies.
  1. May 26, 2021 at 1:08 PM
    #5251
    BayRunner
    2017 Tundra Platinum
    A Ford eh! Tell that to my friend who’s brand new F150 sat at the dealer shop for over 4 months because it was burning oil like gas. Took a lawyer to get them to put a new long block in. He now stares at my Tundra with envy and frets when his will break again.
    TK1979 and Cpl_Punishment like this.
  2. May 26, 2021 at 1:10 PM
    #5252
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    Or you could just get the TRD Pro in a different color.
    Cpl_Punishment and monaco730 like this.
  3. May 26, 2021 at 1:14 PM
    #5253
    AggiePhil
    AggiePhil Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    Same color they painted fire engines back in the 70s and 80s. Supposed to be better for safety.
    TK1979 and vanapagan like this.
  4. May 26, 2021 at 2:39 PM
    #5254
    OVTune
    OVTune New Member
    Mat
    2016 FFV CM
    OVTune RD Vehicle
    I own 2 tundras and 0 fords.
  5. May 26, 2021 at 3:13 PM
    #5255
    lrtexasman
    lrtexasman New Member
    Larry
    Rockwall, Texas
    2023 Tundra Crew Limited 4x4
    I was all set to buy the GM 3.0 until my mechanic at work (we have a huge fleet of all brands) said several of the wet oil pump belts have had to be changed already (supposed to last at least 100k), he had to drop the transmission to get to the belt. Let me know it would be a very expensive repair if it failed early. I've been on all the 1/2 ton diesel forums and the 3.0 Powerstroke seems to be having the fewest problems (2019 and later models). The DEF systems on all the new 1/2 tons are literally ticking time bombs for expensive repairs.
    TK1979 and Jwjeffy905 like this.
  6. May 26, 2021 at 3:32 PM
    #5256
    akmerle
    akmerle New Member
    Wasilla, AK
    2018 Tundra Platinum & 2024 GX550 OT
    I agree on waiting for things to sort themself out on the Gen 4 for a year or two.
    But I for one am not enamored with the supposed 38 gallon tank on my Platinum that only takes 30 gallons and gives less than 500 miles of range.
    Yeah, I’m hoping it goes away for a better system. Preferably something without a gas cap, that doesn’t need over 6 gallons in reserve to cool the fuel pump, and that truly gives over 500 mile range (or 300 miles towing).
    TundraLaw, Hobbesdsm and AggiePhil like this.
  7. May 26, 2021 at 3:46 PM
    #5257
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    The 38-gallon tank takes 38 gallons of gas.
  8. May 26, 2021 at 4:01 PM
    #5258
    Tundra TTH
    Tundra TTH New Member
    My bladder won’t go as far as 300mi before refill on the highway
  9. May 26, 2021 at 4:02 PM
    #5259
    akmerle
    akmerle New Member
    Wasilla, AK
    True, but it’s not a useable 38 gallons. 30 gallons for range, then the rest is for fuel pump cooling. So it’s still effectively a sub 500 mile range / 30 gallon range tank.
    Love your truck BTW, keep up the good work!
    AggiePhil likes this.
  10. May 26, 2021 at 4:04 PM
    #5260
    18" TRD Off Road Wheels
    Incorrect. It is usable. Plenty of people have gone beyond the "distance to empty" number and put 35+ gallons in it. The computer is conservative and everyone keeps assuming that makes it unusable.:facepalm:Go read some of the MPG threads.
  11. May 26, 2021 at 4:14 PM
    #5261
    akmerle
    akmerle New Member
    Wasilla, AK
    I’ve read them, along with the 38 gallon tank experience threads.
    Toyota being Toyota, I don’t doubt their computer as conservative. But when my gas gauge needle is below “E”, and my DTE is at zero, and it barely takes 30 gallons it also makes me lend more credence to the massive reserve being used for fuel pump cooling. A 100+ mile reserve is ridiculous.
    But who knows. The running past 0 DTE causing fuel pump issues may be akin to the 2019+ lack of transmission “coolers” causing transmission failures, and 10k mile oil changes grenading motors. Toyota engineers are smarter than I am, so I’ll just quit bitching and fill up when they say.
    umarali likes this.
  12. May 26, 2021 at 4:31 PM
    #5262
    belanger9
    belanger9 New Member
    Edmonton, AB
    2016 TRD Off Road Inferno
    A bunch
    It's because of where the fuel pickup is. If you go to empty on the gauge and park nose down on a steep slope you won't pick up any fuel. It's Toyota safeguarding against idiots saying I have fuel in my tank but it won't pick it up, not realizing it's because of how they parked. If you have more than empty you will have fuel at the pickup on typical steep slopes.
    shellshock and JJtruckon like this.
  13. May 26, 2021 at 4:55 PM
    #5263
    JJtruckon
    JJtruckon New Member
    JJ
    2018 Tundra
    Undercoating
    So 21% of the fuel tank is to safeguard against idiots? What other auto manufacturer does this type of creative engineering?
    akmerle likes this.
  14. May 26, 2021 at 4:56 PM
    #5264
    Theonlyway
    Theonlyway New Member
    User
    I thought he was insinuating you don’t have one unless you add one, so yes, if it’s standard on 5.7, I have one.
    JJtruckon likes this.
  15. May 26, 2021 at 5:01 PM
    #5265
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Have you tried throwing a jerry can in the bed and driving until you run out of gas to see how far you can actually go?
    Wallygator and shellshock like this.
  16. May 26, 2021 at 5:10 PM
    #5266
    akmerle
    akmerle New Member
    Wasilla, AK
    No sir.
    While I am annoyed at the gas tank, I am not annoyed enough to run out of gas on purpose or intentionally run my fuel pump dry.
    If it is because of some weird fuel pick up location design issue. It would be my luck I would run out of gas on some steep up / down hill where I’d need 8 gallons to hit the fuel pickup……. When I only packed a 5 gallon can.
    nobodyintexas likes this.
  17. May 26, 2021 at 5:18 PM
    #5267
    MTRock
    MTRock 1889
    Montana
    2024 Tacoma TRD Off Road
  18. May 26, 2021 at 5:36 PM
    #5268
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    How do you know the reserve is for fuel pump cooling and not to ensure you don't get stranded in the middle of Wyoming?
    Wallygator, shellshock and JJtruckon like this.
  19. May 26, 2021 at 5:38 PM
    #5269
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    It was included in the tow package (which may have been standard on the 5.7, depending on where your truck was first sold) until 2019.
  20. May 26, 2021 at 5:53 PM
    #5270
    lrtexasman
    Larry
    Rockwall, Texas
    Top choice right now. The reveal will hopefully confirm what I’m hoping to get.
    2undra, gj953 and MTRock like this.
  21. May 26, 2021 at 8:31 PM
    #5271
    shellshock
    shellshock Guy who drives a lot
    Iowa
    2019 TRD PRO
    Except if you are towing, gonna be less than 100 miles of range left when the light comes on. More like 50.
    even if you use 6 of the 8 gallons, that’s still only 80-120 miles of range.
    I wouldn’t want it to wait to come on with only a gallon or two left..
    belanger9 and Cpl_Punishment like this.
  22. May 27, 2021 at 8:35 AM
    #5272
    Cg13055
    Cg13055 @yota.parts.distributor
    South Florida
    Mcfly Tundra @yota.parts.distributor
    2012’4.0 Tundra-2004’4.7 crewcab-2021 2.7 Tacoma
    You guys need to contact IPT transmission in NJ and upgrade your valve body!! OEM is the reason for TC failure!!!
  23. May 27, 2021 at 2:39 PM
    #5273
    JJtruckon
    JJ
    2018 Tundra
    Undercoating
  24. May 27, 2021 at 2:41 PM
    #5274
    belanger9
    Edmonton, AB
    A bunch
    Great point. It's nice knowing that there's this buffer in case. Had a few times in my work trucks where I thought I only needed the same fuel as the day before and I'm at 5/8ths of a tank so don't fuel up in the morning but then halfway through the day they send me further away so suddenly I'm paranoid about fuel. If it was in a Tundra I'd know I have that buffer to get back no problem.
    shellshock[QUOTED] likes this.
  25. May 27, 2021 at 3:56 PM
    #5275
    The Californian
    Eric
    Jwjeffy905 and Cpl_Punishment like this.
  26. May 27, 2021 at 4:44 PM
    #5276
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    You don't need it anymore or full disclosure ... the tv will tell you the truth and don't question things or you will be labeled a bad name.
    #nocriticalthinkingallowed
    GODZILLA likes this.
  27. May 27, 2021 at 7:00 PM
    #5277
    Mitch09
    Mitch09 New Member
    NC
    2022 SR5 TRD Off-road
    Saw this on the Toyota Instagram earlier.
  28. May 27, 2021 at 7:48 PM
    #5278
    Lebby
    Lebby New Member
    Mitch09[QUOTED] and Mountun Goat like this.
  29. May 27, 2021 at 8:29 PM
    #5279
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    Toyota sent me an email today asking if I want more information on the great new Tundra.
    The great new 2021 Tundra :thumbsup:
    Cg13055, Lifer, Wallygator and 4 others like this.
  30. May 28, 2021 at 7:33 AM
    #5280
    harrydunn
    harrydunn New Member
    Columbia, MO
    Because I was inverted.
    Call it, Friendo.
Thread Status:
